So I took it down and followed these steps:
Used Seatool and Windows diskmanage to make sure the 4 drives work
Fresh 32gb SD card
used 2020-05-27-raspios-buster-lite-armhf.img
sudo apt-get update
sudo apt-get upgrade -y
curl -sL https://rock.sh/get-rockpi-sata | sudo -E bash -
shutdown -h now
installed hat
systemctl status rockpi-sata.service
rockpi-sata.service - Rockpi SATA Hat
Loaded: loaded (/lib/systemd/system/rockpi-sata.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2020-07-07 08:44:03 BST; 7min ago
Main PID: 448 (python3)
Tasks: 6 (limit: 4915)
Memory: 23.1M
CGroup: /system.slice/rockpi-sata.service
├─448 /usr/bin/python3 /usr/bin/rockpi-sata/main.py on
├─793 /usr/bin/python3 /usr/bin/rockpi-sata/main.py on
├─794 /usr/bin/python3 /usr/bin/rockpi-sata/main.py on
├─795 /usr/bin/python3 /usr/bin/rockpi-sata/main.py on
└─796 /usr/bin/python3 /usr/bin/rockpi-sata/main.py on
lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 04a0:9005 Digital Equipment Corp.
Bus 001 Device 003: ID 046d:c408 Logitech, Inc. Marble Mouse (4-button)
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
lsblk
mmcblk0 179:0 0 29G 0 disk
├─mmcblk0p1 179:1 0 256M 0 part /boot
└─mmcblk0p2 179:2 0 28.7G 0 part /
and the hat has blue red blue red blue red leds from left to right facing the led end of the board.
I also added the
Fix Quad SATA HAT disk serial number
KERNEL==“sd*”, ATTRS{idVendor}==“1058”, ATTRS{idProduct}==“0a10”, SUBSYSTEMS==“usb”, PROGRAM="/root/serial.sh %k", ENV{ID_SERIAL}=“USB-%c”, ENV{ID_SERIAL_SHORT}="%c"
and /root/serial.sh
This changed the led pattern from a red/blue on each end to the pattern listed above.
dmesg -c
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2020.07.07 01:14:38 =~=~=~=~=~=~=~=~=~=~=~=
dmesg -c
[ 0.000000] Linux version 4.19.118-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1311 SMP Mon Apr 27 14:26:42 BST 2020
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
[ 0.000000] cma: Reserved 256 MiB at 0x000000001ec00000
[ 0.000000] On node 0 totalpages: 1012736
[ 0.000000] DMA zone: 1728 pages used for memmap
[ 0.000000] HighMem zone: 816128 pages, LIFO batch:63
[ 0.000000] random: get_random_bytes called from start_kernel+0xc0/0x4e8 with crng_init=0
[ 0.000000] percpu: Embedded 17 pages/cpu s36928 r8192 d24512 u69632
[ 0.000000] pcpu-alloc: s36928 r8192 d24512 u69632 alloc=17*4096
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1011008
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 cma=256M video=HDMI-A-1:1920x1080M@60,margin_left=48,margin_right=48,margin_top=48,margin_bottom=48 smsc95xx.macaddr=DC:A6:32:67:82:B8 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=bcde2535-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 3735552K/4050944K available (8192K kernel code, 690K rwdata, 2420K rodata, 2048K init, 860K bss, 53248K reserved, 262144K cma-reserved, 3264512K highmem)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0x(ptrval) - 0x(ptrval) (10208 kB)
.init : 0x(ptrval) - 0x(ptrval) (2048 kB)
.data : 0x(ptrval) - 0x(ptrval) ( 691 kB)
.bss : 0x(ptrval) - 0x(ptrval) ( 861 kB)
[ 0.000000] ftrace: allocating 28928 entries in 85 pages
[ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000021] Switching to timer-based delay loop, resolution 18ns
[ 0.000264] Console: colour dummy device 80x30
[ 0.000742] console [tty1] enabled
[ 0.000801] Calibrating delay loop (skipped), value calculated using timer frequency… 108.00 BogoMIPS (lpj=540000)
[ 0.000837] pid_max: default: 32768 minimum: 301
[ 0.001128] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001162] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001954] CPU: Testing write buffer coherency: ok
[ 0.002379] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.003030] Setting up static identity map for 0x200000 - 0x20003c
[ 0.003207] rcu: Hierarchical SRCU implementation.
[ 0.004091] smp: Bringing up secondary CPUs …
[ 0.004952] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.005906] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.006812] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.006932] smp: Brought up 1 node, 4 CPUs
[ 0.006999] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.007022] CPU: All CPU(s) started in HYP mode.
[ 0.007043] CPU: Virtualization extensions available.
[ 0.007896] devtmpfs: initialized
[ 0.018733] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.018958] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.019000] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.026400] pinctrl core: initialized pinctrl subsystem
[ 0.027355] NET: Registered protocol family 16
[ 0.030543] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.032087] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.032119] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.032344] Serial: AMBA PL011 UART driver
[ 0.035620] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.050029] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-06-01 13:23, variant start
[ 0.060046] raspberrypi-firmware soc:firmware: Firmware hash is 6379679d1ec6a8c746d7e77e015f5b56b939976f
[ 0.102986] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[ 0.106167] vgaarb: loaded
[ 0.106552] SCSI subsystem initialized
[ 0.106770] usbcore: registered new interface driver usbfs
[ 0.106841] usbcore: registered new interface driver hub
[ 0.106925] usbcore: registered new device driver usb
[ 0.108345] clocksource: Switched to clocksource arch_sys_counter
[ 0.187365] VFS: Disk quotas dquot_6.6.0
[ 0.187474] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.187669] FS-Cache: Loaded
[ 0.187875] CacheFiles: Loaded
[ 0.188551] simple-framebuffer 3e4e0000.framebuffer: framebuffer at 0x3e4e0000, 0x6e7000 bytes, mapped to 0x(ptrval)
[ 0.188590] simple-framebuffer 3e4e0000.framebuffer: format=a8r8g8b8, mode=1824x984x32, linelength=7296
[ 0.198421] Console: switching to colour frame buffer device 228x61
[ 0.207114] simple-framebuffer 3e4e0000.framebuffer: fb0: simplefb registered!
[ 0.216343] NET: Registered protocol family 2
[ 0.217075] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.217183] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.217322] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.217461] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.217654] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.217748] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.218024] NET: Registered protocol family 1
[ 0.218676] RPC: Registered named UNIX socket transport module.
[ 0.218747] RPC: Registered udp transport module.
[ 0.218804] RPC: Registered tcp transport module.
[ 0.218860] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.218935] PCI: CLS 0 bytes, default 64
[ 0.220761] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.223031] Initialise system trusted keyrings
[ 0.223283] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 0.232662] FS-Cache: Netfs ‘nfs’ registered for caching
[ 0.233252] NFS: Registering the id_resolver key type
[ 0.233333] Key type id_resolver registered
[ 0.233389] Key type id_legacy registered
[ 0.233453] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.238097] Key type asymmetric registered
[ 0.238160] Asymmetric key parser ‘x509’ registered
[ 0.238323] bounce: pool size: 64 pages
[ 0.238489] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.238735] io scheduler noop registered
[ 0.241380] io scheduler deadline registered (default)
[ 0.244156] io scheduler cfq registered
[ 0.246753] io scheduler mq-deadline registered (default)
[ 0.249385] io scheduler kyber registered
[ 0.285314] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, threshold 0x00000000c0000000
[ 0.287864] brcm-pcie fd500000.pcie: could not get clock
[ 0.290540] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 0.293141] brcm-pcie fd500000.pcie: MEM 0x600000000…0x603ffffff -> 0xf8000000
[ 0.348368] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
[ 0.351220] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 0.353631] pci_bus 0000:00: root bus resource [bus 00-01]
[ 0.356148] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[ 0.358776] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 0.358919] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 0.361704] PCI: bus0: Fast back to back transfers disabled
[ 0.364225] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.366948] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 0.367072] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.367390] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 0.370168] PCI: bus1: Fast back to back transfers disabled
[ 0.372735] pci_bus 0000:01: busn_res: [bus 01] end is updated to 01
[ 0.372785] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 0.375376] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 0.378008] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.380624] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 0.383452] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ 0.386151] pcieport 0000:00:00.0: Signaling PME with IRQ 53
[ 0.388891] pcieport 0000:00:00.0: AER enabled with IRQ 53
[ 0.391623] pci 0000:01:00.0: enabling device (0140 -> 0142)
[ 0.398477] iproc-rng200 fe104000.rng: hwrng registered
[ 0.401288] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 0.404298] vc-sm: Videocore shared memory driver
[ 0.407274] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 0.420254] brd: module loaded
[ 0.432822] loop: module loaded
[ 0.436083] Loading iSCSI transport class v2.0-870.
[ 0.440353] libphy: Fixed MDIO Bus: probed
[ 0.443288] bcmgenet fd580000.genet: failed to get enet clock
[ 0.445794] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
[ 0.448265] bcmgenet fd580000.genet: failed to get enet-wol clock
[ 0.450777] bcmgenet fd580000.genet: failed to get enet-eee clock
[ 0.453118] bcmgenet: Skipping UMAC reset
[ 0.455728] unimac-mdio unimac-mdio.-19: DMA mask not set
[ 0.468377] libphy: bcmgenet MII bus: probed
[ 0.508939] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrval)
[ 0.512325] usbcore: registered new interface driver r8152
[ 0.514837] usbcore: registered new interface driver lan78xx
[ 0.517325] usbcore: registered new interface driver smsc95xx
[ 0.519995] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.522410] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 0.527037] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
[ 0.529808] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of irq 54
[ 0.533110] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.535530] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.537914] usb usb1: Product: xHCI Host Controller
[ 0.540403] usb usb1: Manufacturer: Linux 4.19.118-v7l+ xhci-hcd
[ 0.542873] usb usb1: SerialNumber: 0000:01:00.0
[ 0.545833] hub 1-0:1.0: USB hub found
[ 0.548378] hub 1-0:1.0: 1 port detected
[ 0.551265] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.553572] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 0.556015] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 0.558874] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 0.561347] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.563815] usb usb2: Product: xHCI Host Controller
[ 0.566289] usb usb2: Manufacturer: Linux 4.19.118-v7l+ xhci-hcd
[ 0.568723] usb usb2: SerialNumber: 0000:01:00.0
[ 0.571570] hub 2-0:1.0: USB hub found
[ 0.574030] hub 2-0:1.0: 4 ports detected
[ 0.577661] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.580289] dwc_otg: FIQ enabled
[ 0.580298] dwc_otg: NAK holdoff enabled
[ 0.580307] dwc_otg: FIQ split-transaction FSM enabled
[ 0.580319] Module dwc_common_port init
[ 0.580564] usbcore: registered new interface driver uas
[ 0.583079] usbcore: registered new interface driver usb-storage
[ 0.585610] mousedev: PS/2 mouse device common for all mice
[ 0.589155] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 0.593188] sdhci: Secure Digital Host Controller Interface driver
[ 0.595539] sdhci: Copyright© Pierre Ossman
[ 0.598259] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 0.601066] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.606359] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.608934] hidraw: raw HID events driver © Jiri Kosina
[ 0.611454] usbcore: registered new interface driver usbhid
[ 0.613808] usbhid: USB HID core driver
[ 0.616931] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[ 0.621109] [vc_sm_connected_init]: start
[ 0.631327] [vc_sm_connected_init]: end - returning 0
[ 0.634858] Initializing XFRM netlink socket
[ 0.637103] NET: Registered protocol family 17
[ 0.639547] Key type dns_resolver registered
[ 0.642229] Registering SWP/SWPB emulation handler
[ 0.645140] registered taskstats version 1
[ 0.647429] Loading compiled-in X.509 certificates
[ 0.656729] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 0.659162] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2
[ 0.666664] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 0.669539] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
[ 0.672576] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 0.675040] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 0.701556] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.3
[ 0.703978] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.4
[ 0.724785] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 0.728957] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.732914] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.738107] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 0.740507] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 0.744298] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.745251] of_cfs_init
[ 0.749209] of_cfs_init: OK
[ 0.752132] Waiting for root device PARTUUID=bcde2535-02…
[ 0.796863] random: fast init done
[ 0.842805] mmc1: new high speed SDIO card at address 0001
[ 0.851020] mmc0: new ultra high speed DDR50 SDHC card at address 0007
[ 0.854387] mmcblk0: mmc0:0007 SD32G 29.0 GiB
[ 0.858146] mmcblk0: p1 p2
[ 0.879769] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 0.882211] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 0.890049] devtmpfs: mounted
[ 0.899827] Freeing unused kernel memory: 2048K
[ 0.918391] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 0.920848] Run /sbin/init as init process
[ 1.101061] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.103399] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.105781] usb 1-1: Product: USB2.0 Hub
[ 1.110340] hub 1-1:1.0: USB hub found
[ 1.113051] hub 1-1:1.0: 4 ports detected
[ 1.438393] usb 1-1.3: new low-speed USB device number 3 using xhci_hcd
[ 1.450983] systemd[1]: System time before build time, advancing clock.
[ 1.557664] NET: Registered protocol family 10
[ 1.561417] Segment Routing with IPv6
[ 1.576393] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c408, bcdDevice=14.00
[ 1.578952] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.581427] usb 1-1.3: Product: USB Trackball
[ 1.583851] usb 1-1.3: Manufacturer: Logitech
[ 1.596699] input: Logitech USB Trackball as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:046D:C408.0001/input/input0
[ 1.599664] hid-generic 0003:046D:C408.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech USB Trackball] on usb-0000:01:00.0-1.3/input0
[ 1.608616] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 1.615201] systemd[1]: Detected architecture arm.
[ 1.638152] systemd[1]: Set hostname to .
[ 1.698429] usb 1-1.4: new low-speed USB device number 4 using xhci_hcd
[ 1.837176] usb 1-1.4: New USB device found, idVendor=04a0, idProduct=9005, bcdDevice= 1.10
[ 1.840116] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.842943] usb 1-1.4: Product: USB Keyboard
[ 1.845754] usb 1-1.4: Manufacturer: SONiX
[ 1.861159] input: SONiX USB Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:04A0:9005.0002/input/input1
[ 1.929167] hid-generic 0003:04A0:9005.0002: input,hidraw1: USB HID v1.11 Keyboard [SONiX USB Keyboard] on usb-0000:01:00.0-1.4/input0
[ 1.942174] input: SONiX USB Keyboard Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:04A0:9005.0003/input/input2
[ 2.008581] input: SONiX USB Keyboard System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:04A0:9005.0003/input/input3
[ 2.011996] input: SONiX USB Keyboard Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:04A0:9005.0003/input/input4
[ 2.015425] hid-generic 0003:04A0:9005.0003: input,hidraw2: USB HID v1.11 Keyboard [SONiX USB Keyboard] on usb-0000:01:00.0-1.4/input1
[ 2.300750] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.312080] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.315820] systemd[1]: Listening on udev Kernel Socket.
[ 2.323767] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.327399] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 2.335623] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 2.348906] systemd[1]: Created slice system-getty.slice.
[ 2.363889] systemd[1]: Listening on Syslog Socket.
[ 2.372249] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 2.380758] systemd[1]: Listening on udev Control Socket.
[ 3.170846] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.301296] systemd-journald[122]: Received request to flush runtime journal from PID 1
[ 3.806372] Driver for 1-wire Dallas network protocol.
[ 3.813904] media: Linux media interface: v0.10
[ 3.814585] gpio-4 (onewire@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 3.816052] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.818179] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 3.818195] [vc_sm_connected_init]: start
[ 3.821175] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x0000ffff
[ 3.824873] [vc_sm_connected_init]: installed successfully
[ 3.825510] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00000fff
[ 3.826551] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x0000ffff
[ 3.827029] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x0000ffff
[ 3.843042] videodev: Linux video capture interface: v2.00
[ 3.940932] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.942880] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.961636] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.973588] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.002305] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 4.002339] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 4.018557] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 4.018595] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 4.030380] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 4.030431] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 4.031838] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.063238] bcm2835_audio soc:audio: card created with 4 channels
[ 4.066553] bcm2835_audio soc:audio: card created with 4 channels
[ 4.148050] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.220010] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 4.243423] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 4.310198] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 4.327725] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 4.328661] usbcore: registered new interface driver brcmfmac
[ 4.342874] vc4-drm soc:gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 4.342894] checking generic (3e4e0000 6e7000) vs hw (0 ffffffffffffffff)
[ 4.342904] fb: switching to vc4drmfb from simple
[ 4.343171] Console: switching to colour dummy device 80x30
[ 4.352664] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 1
[ 4.352679] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 4.352688] [drm] No driver support for vblank timestamp query.
[ 4.352711] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
[ 4.573063] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 4.589807] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 2 2020 23:30:41 version 7.45.202 (r724630 CY) FWID 01-72f6ece2
[ 4.593352] Console: switching to colour frame buffer device 240x67
[ 4.630048] vc4-drm soc:gpu: fb0: DRM emulated frame buffer device
[ 5.938510] Under-voltage detected! (0x00050005)
[ 6.384633] random: crng init done
[ 6.384646] random: 7 urandom warning(s) missed due to ratelimiting
[ 6.530452] uart-pl011 fe201000.serial: no DMA platform data
[ 6.623420] 8021q: 802.1Q VLAN Support v1.8
[ 6.865040] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 7.338619] bcmgenet: Skipping UMAC reset
[ 7.449337] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
[ 7.450218] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.079253] i2c /dev entries driver
[ 8.488589] bcmgenet fd580000.genet eth0: Link is Down
[ 12.648628] bcmgenet fd580000.genet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 12.648675] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 14.455137] Bluetooth: Core ver 2.22
[ 14.455221] NET: Registered protocol family 31
[ 14.455231] Bluetooth: HCI device and connection manager initialized
[ 14.455254] Bluetooth: HCI socket layer initialized
[ 14.455269] Bluetooth: L2CAP socket layer initialized
[ 14.455317] Bluetooth: SCO socket layer initialized
[ 14.473766] Bluetooth: HCI UART driver ver 2.3
[ 14.473781] Bluetooth: HCI UART protocol H4 registered
[ 14.473873] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 14.474117] Bluetooth: HCI UART protocol Broadcom registered
[ 14.777569] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 14.777583] Bluetooth: BNEP filters: protocol multicast
[ 14.777606] Bluetooth: BNEP socket layer initialized
dmesg: read kernel buffer failed: Operation not permitted
pi@raspberrypi:~ $
