@somecdnguy
I’ve opened a separate Topic for DietPi after you mentioned about it;
Thank you.
Question:
-Did you manage to enable wifi and connect for installation ?
I did modify + enabled wifi through
dietpi.txt
But couldn’t find
dietpi-wifi.txt
Do you know if that file exists or maybe named differently ?
Because this file didn’t exist, i went to config settings in installation and enabled wifi and added my wifi information., all seems good but couldn’t manage to actually connect after configuring everything.
Let me know what your experience was and how you resolved this problem with zero ?
ok, back again with solution about dietpi-wifi.txt if anyone needs;
The dietpi-wifi.txt file gets removed during initial boot setup, since it contains unencrypted wifi credentials… it‘s a (very good) feature.
My mistake was to boot and try to configure wifi settings from the boot menu and then go back to folder structure to look for wifi text file.
But, because i booted ones it did not exist and i couldnt find it.
It needs to be edited before first boot to activate and add credentials for wifi.
On my first try, the initial install failed because it couldn’t do the update.
I had configured my wifi through the dietpi-config menu and it connected ok, and even passed the connection test.
It kept failing on the ping (9.9.9.9) command that it uses to check the connection before updating.
Today, I re-flashed my SD card and preconfigured my wifi in dietpi-wifi.txt. Same problem happened.
Searched online and lots of people reported wifi issues but I saw no real causes/solutions.
Then, I found someone reported the same problem I was having. His workaround was to ping a local ip and, since the ping cmd was successful, the update worked!
So, I pinged my router and it worked for me too, then I was able to complete the install.
It happened again when I tried installing apps, so I had to do the workaround again.
I installed LXDE and a few apps and it works like a charm so far. Next step is to try connecting to it using VNC. Ultimately, I’m just going to use my Zero as a print server anyway but I wanted to play with it first.
SSH works fine.
VNC works fine.
CUPS works fine. I had to manually install HPCUPS and HPLIP for my HP printer because there was only a short list in the DietPi version of CUPS.
Overall, my experience with DietPi has been very good.
No issues beyond that strange ping problem during the install/update.
In my Debian Buster install, the Zero would get really slow after ~15 minutes, to the point where the desktop wouldn’t respond anymore. Hasn’t happened in DietPi after more than an hour tinkering.
I would highly recommend DietPi, especially for a low RAM Zero. (mine is 1GB)
It works pretty good on my side too. Very fast, interface is simple and lot of stuff came ready out of box. As an examle i had diffucult time setting up Docker on other distros and dietpi was ready to go.
Next i will be giving a try on SSH on my end too. Its great to know it works fine…Thanks !!
I didnt have this problem yet…
Honestly, Debian was getting very slow on my end too. (4GB )
Only problem i have with Dietpi (problem might be myself too) im not an expert…When i tried to add custom desktop resolution, it didnt like it at all. The screen was flickring and going black and goes back to 1920x1080, no matter what i do…I just need to do some more reading for solution…
Are you trying to switch to 4K or a lower res? I’d expect a lower res to work. For 4K, you probably need to increase the amount of RAM for the GPU. I read a post on the DietPi forum saying can do this in dietpi-config or the /DietPi/config.txt file, but I haven’t tried it.
I noticed i get very good performance with this resolution - specially in Manjaro,
and at the sametime when i first boot up dietpi or any other distro, it does start as 3840x2160 because of my monitor. Which Radxa zero glitches and keeps distorting the screen ( i will post a separate topic for this)
But in DietPi;
when I tried to add 2560x1440 16:9 60Hz settings it always revert back to 3840x2160 or if i changed the resolution to 1920x1080 it reverts back to that as default.
Can you direct me to that source if you remember..
dietpi-config does not support >1080p resolution yet (as of Oct 2020), so it sounds like you have to manually edit the config.txt file, which looks complicated.
If you had the res you wanted working in another distro, “Copy the config.txt from the OS that worked fine with your monitor over to DietPi”.
I’ll keep looking for my previous reference. There was also something in it about having to copy the updated config.txt file from the SD to the DietPi RAM disk to have it take effect.
I found my original reference: https://dietpi.com/phpbb/viewtopic.php?t=789
It’s about how to make changes stick at the next boot, more than changing the GPU RAM.
It’s confusing because it sounds like the guy was trying both dietpi-config and raspi-config to change the GPU memory split.
Anyway, my GPU RAM suggestion sounds like a red herring because I also found this statement that says “If you use dietpi-software to install some application, gpu_mem will be set automatically according best practice.”. So, basically, the DietPi software install process is smart enough to adjust the GPU RAM based on the installed packages.
That’s from here: https://dietpi.com/phpbb/viewtopic.php?t=7638
Thank you.
Looks like this topic is trying to resolve exactly problem i have with 2K res. I dont have any other config.txt file from raspberry os or anything. but i will try to add it to Dietpi OS
It is very common with new boards for there to be problems that need solving. So in that regard, I’m not all that surprised. As for the Pi’s well… They have an army of people working and playing on those.
My honest first thought when I saw this board was, Kodi box.
