Here’s the error after flash at boot time by shortcut the SPI1_CLK to GND:
emjay@emjay-on-lmc ~/rkdeveloptool $ lsusb
Bus 002 Device 008: ID 058f:6366 Alcor Micro Corp. Multi Flash Reader
Bus 002 Device 006: ID 0bda:8812 Realtek Semiconductor Corp. RTL8812AU 802.11a/b/g/n/ac WLAN Adapter
Bus 002 Device 004: ID 1a40:0101 Terminus Technology Inc. Hub
Bus 002 Device 003: ID 1b80:d3a8 Afatech
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 008 Device 003: ID 045e:074b Microsoft Corp.
Bus 008 Device 002: ID 045e:0736 Microsoft Corp. Sidewinder X5 Mouse
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 002: ID 056a:00b2 Wacom Co., Ltd Intuos3 9x12
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 077: ID 2207:330c
Bus 001 Device 002: ID 0409:005a NEC Corp. HighSpeed Hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
emjay@emjay-on-lmc ~/rkdeveloptool $ rkdeveloptool ld
DevNo=1 Vid=0x2207,Pid=0x330c,LocationID=104 Maskrom
emjay@emjay-on-lmc ~/rkdeveloptool $ rkdeveloptool db rk3399_loader_spinor_v1.15.114.bin
Creating Comm Object failed!
This computer has no usb3 ports only 1.1 or 2.0. But I did try with 2.0 mobo usb port at the back.. same result..! Even tried with the highspeed hub off, at no avail.
Method 2 requires a working system on SD or eMMC; None of those worked for me; black screen for both, no access to anything… Tried ARMbian and Manjaro ARM Kde… same result…!! I guess the board is not functional and I’ll just have to live with it… Right…!!
This is mostly like a usb/cable signal issue. As the device ID is detected, so it means the board is in maskrom mode. Where did you buy the USB A to A cable?
Thought about the cable of course, and did try two other ones (300mm and 1.5m), working of other devices, to no avail…
Utek Pacific is where I buy all my cables… Thanx for the thought tho…!!
I’m getting the same “Creating Comm Object failed” error when trying to flash a new image to the eMMC. Oddly, the Rock Pi 4 still boots to the current image installed on the eMMC, but I want to overwrite it with another linux image. I’m stuck at this error and it’s not allowing me to continue past the rkdeveloptool db rk3399_loader_v1.12.112.bin command. I should say that, in error, I tried to flash the rk3399pro bin file, however the eMMC wasn’t attached and I soon realised my mistake and downloaded the proper .bin file. Have I bricked my Rock Pi 4? Seeing as I’m still able to boot the Rock Pi 4 into the Manjaro Linux installation currently on the eMMC, is there any way to fix this message from within my current Linux install?
I am getting the same error, must the USBa-to-USBa be a 3.0 specification? Currently have only a USB-2.0 specification male-to-male cable, but also the problem may be the old Linux laptop that I was using which has no USB-3.0 port and only 2.0 ports. Please advise…
Hiya Ricklar,
I tried it the other way round, USB3, then USB2 on 3 different cable makes now, at no avail… It is slowly becoming annoying, to say the least…!
