Hey there,
I’m planning to built a NAS with the Quad sata Hat on a raspberry pi 4 4gb. Currently I’m running a NAS on a Banana Pi but the transfer speed is limited to 40 mb/s, so I want to replace it.
I will use 3,5 " HDDs in a custom case, so I don’t use the top board.
I’m planning to use the Sata Hats cpu fan for the raspberry Pi CPU and a Noctua 5v PWM fan as a case fan.
I have now a few questions:
- Can I use the public installation script for the Sata hat without using the top hat(oled, topfan).?
- can I use the the installation script and the config file to control my Noctua fan, connected to the 10 pin connector?
- is the CPU fan and the case fan controlled by the same signal? Which you can edit from the config file.
kind regards
