Suveju
1
Hello.
Is it possible to connect the “Coral Edge” module to the “M.2 Wireless” slot?
For example, one of these two options:
M.2 Accelerator with Dual Edge TPU - https://coral.ai/products/m2-accelerator-dual-edgetpu/
Connector M.2 E-key (with two PCIe Gen2 x1 lanes)
Dimensions 22 mm x 30 mm (M.2-2230-D3-E)
M.2 Accelerator A + E key - https://coral.ai/products/m2-accelerator-ae/
Connector M.2 (A + E key)
Dimensions 22 mm x 30 mm (M.2-2230-A-E-S3)
Thx.
jack
2
No. For the N10, the M.2 E Key is for SDIO wifi only. You can use 3A for the Coral Edge module.
https://wiki.radxa.com/Rock3/dev/install-coral-pcie-driver-and_edge_tpu-runtime-packages
jack
3
For N10, the M key(which is for SSD) may work with the Coral M Key module, but we did not test it.
Yes, this works. I have tested it.
Suveju
6
How is this possible?
“M.2 Accelerator A + E key” requires a PCIe interface, while “ROCK Pi N10” only has SDIO wifi
