Hi guys
Can not be drives on HAT connectedt over USB HUB?
I’m adding HUB there because I want more USB3 ports because I runing DietPi from SSD drive and also I have another USB3 drive.
When I connect hat drives with USB 3.0 cables to USB 3.0 HUB, they are not recognized. Other drives which is connected to HUB are recognized.
Thank for reply, but I’m little bit lost there
Sorry whats the difference between “connection” and “extension” cable?
Am I right that “connection” cable have two male connector an “extention” have one male and one female?
For me it is working also with “connection” cable because I have hat still connected on my RPI.
So RPi can find disk only when theu’re connected to two USB3 or USB2 ports
hi, thank you
If you are capable to connect HAT with two male/male cables
then it does not match the experiences I made with HAT and RPI 4
mine does not worked like that and - sry - than I can not support.
