hello
I’m stuck on getting the HAT running on USB 3.0. If I connect it directly, it claims that cable not good. So it fails back to usb 2.0. Tested the ports on Raspberry with a SanDisk which reports correctly. If I add a USB 3.0 Hub and connected the HAT & SanDisk to it. It reports:
root@raspberrypi:~# lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
|__ Port 2: Dev 2, If 0, Class=Hub, Driver=hub/4p, 5000M
|__ Port 2: Dev 3, If 0, Class=Mass Storage, Driver=uas, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 2: Dev 3, If 0, Class=Hub, Driver=hub/5p, 480M
|__ Port 1: Dev 22, If 0, Class=Mass Storage, Driver=uas, 480M
|__ Port 3: Dev 19, If 0, Class=Mass Storage, Driver=uas, 480M
dmesg
[ 131.424423] usb 1-1.2.1: new high-speed USB device number 4 using xhci_hcd
[ 132.365126] usb 1-1.2-port1: Cannot enable. Maybe the USB cable is bad?
[ 132.464802] usb 1-1.2.1: new high-speed USB device number 5 using xhci_hcd
[ 133.405421] usb 1-1.2-port1: Cannot enable. Maybe the USB cable is bad?
[ 133.405897] usb 1-1.2-port1: attempt power cycle
[ 134.655853] usb 1-1.2-port1: Cannot enable. Maybe the USB cable is bad?
[ 134.755581] usb 1-1.2.1: new high-speed USB device number 7 using xhci_hcd
[ 134.755812] usb 1-1.2.1: Device not responding to setup address.
[ 134.975852] usb 1-1.2.1: Device not responding to setup address.
[ 135.195726] usb 1-1.2.1: device not accepting address 7, error -71
[ 135.196165] usb 1-1.2-port1: unable to enumerate USB device
[ 135.495817] usb 1-1.2.1: new high-speed USB device number 8 using xhci_hcd
[ 136.436462] usb 1-1.2-port1: Cannot enable. Maybe the USB cable is bad?
[ 136.536151] usb 1-1.2.1: new high-speed USB device number 9 using xhci_hcd
[ 137.476782] usb 1-1.2-port1: Cannot enable. Maybe the USB cable is bad?
[ 137.477284] usb 1-1.2-port1: attempt power cycle
[ 138.727164] usb 1-1.2-port1: Cannot enable. Maybe the USB cable is bad?
[ 138.826851] usb 1-1.2.1: new high-speed USB device number 11 using xhci_hcd
[ 138.827075] usb 1-1.2.1: Device not responding to setup address.
[ 139.047079] usb 1-1.2.1: Device not responding to setup address.
[ 139.266979] usb 1-1.2.1: device not accepting address 11, error -71
[ 139.267452] usb 1-1.2-port1: unable to enumerate USB device
[ 139.567059] usb 1-1.2.1: new high-speed USB device number 12 using xhci_hcd
[ 140.507643] usb 1-1.2-port1: Cannot enable. Maybe the USB cable is bad?
[ 140.607369] usb 1-1.2.1: new high-speed USB device number 13 using xhci_hcd
[ 141.547934] usb 1-1.2-port1: Cannot enable. Maybe the USB cable is bad?
[ 141.548427] usb 1-1.2-port1: attempt power cycle
[ 142.798270] usb 1-1.2-port1: Cannot enable. Maybe the USB cable is bad?
[ 142.897983] usb 1-1.2.1: new high-speed USB device number 15 using xhci_hcd
[ 142.898202] usb 1-1.2.1: Device not responding to setup address.
[ 143.118230] usb 1-1.2.1: Device not responding to setup address.
[ 143.338096] usb 1-1.2.1: device not accepting address 15, error -71
[ 143.338512] usb 1-1.2-port1: unable to enumerate USB device
[ 143.638175] usb 1-1.2.3: new high-speed USB device number 16 using xhci_hcd
[ 143.778597] usb 1-1.2.3: Device not responding to setup address.
[ 143.998466] usb 1-1.2.3: Device not responding to setup address.
[ 144.218323] usb 1-1.2.3: device not accepting address 16, error -71
[ 145.128962] usb 1-1.2-port3: Cannot enable. Maybe the USB cable is bad?
[ 145.129380] usb 1-1.2-port3: attempt power cycle
[ 146.379217] usb 1-1.2-port3: Cannot enable. Maybe the USB cable is bad?
[ 146.478942] usb 1-1.2.3: new high-speed USB device number 19 using xhci_hcd
[ 146.550560] usb 1-1.2.3: New USB device found, idVendor=152d, idProduct=0561, bcdDevice=81.36
[ 146.550586] usb 1-1.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 146.550603] usb 1-1.2.3: Product: External
[ 146.550618] usb 1-1.2.3: Manufacturer: JMicron
[ 146.550632] usb 1-1.2.3: SerialNumber: DD564198838B4
[ 146.573815] scsi host1: uas
[ 146.575892] scsi 1:0:0:0: Direct-Access JMicron Tech 8136 PQ: 0 ANSI: 6
[ 146.578640] sd 1:0:0:0: Attached scsi generic sg2 type 0
[ 146.581882] scsi 1:0:0:1: Direct-Access JMicron Tech 8136 PQ: 0 ANSI: 6
[ 146.582244] sd 1:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 146.582978] sd 1:0:0:0: [sdb] Write Protect is off
[ 146.582998] sd 1:0:0:0: [sdb] Mode Sense: 67 00 10 08
[ 146.584486] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 146.585500] sd 1:0:0:0: [sdb] Optimal transfer size 33553920 bytes
[ 146.586506] sd 1:0:0:1: Attached scsi generic sg3 type 0
[ 146.588863] sd 1:0:0:1: [sdc] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 146.589642] sd 1:0:0:1: [sdc] Write Protect is off
[ 146.589684] sd 1:0:0:1: [sdc] Mode Sense: 67 00 10 08
[ 146.590984] sd 1:0:0:1: [sdc] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 146.592363] sd 1:0:0:1: [sdc] Optimal transfer size 33553920 bytes
[ 146.599914] sdb: sdb1
[ 146.606512] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 146.613540] sdc: sdc1
[ 146.618731] sd 1:0:0:1: [sdc] Attached SCSI disk
[ 146.868993] usb 1-1.2.1: new high-speed USB device number 20 using xhci_hcd
[ 147.439333] usb 1-1.2.1: device descriptor read/64, error -71
[ 147.659569] usb 1-1.2.1: Device not responding to setup address.
[ 147.879427] usb 1-1.2.1: Device not responding to setup address.
[ 148.099286] usb 1-1.2.1: device not accepting address 20, error -71
[ 148.639405] usb 1-1.2.1: new high-speed USB device number 21 using xhci_hcd
[ 148.739834] usb 1-1.2.1: Device not responding to setup address.
[ 148.959676] usb 1-1.2.1: Device not responding to setup address.
[ 149.189544] usb 1-1.2.1: device not accepting address 21, error -71
[ 149.190036] usb 1-1.2-port1: attempt power cycle
[ 150.069730] usb 1-1.2.1: new high-speed USB device number 22 using xhci_hcd
[ 150.101595] usb 1-1.2.1: New USB device found, idVendor=152d, idProduct=0561, bcdDevice=81.36
[ 150.101622] usb 1-1.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 150.101640] usb 1-1.2.1: Product: External
[ 150.101656] usb 1-1.2.1: Manufacturer: JMicron
[ 150.101670] usb 1-1.2.1: SerialNumber: DD564198838B3
[ 150.112665] scsi host2: uas
[ 150.114577] scsi 2:0:0:0: Direct-Access JMicron Tech 8136 PQ: 0 ANSI: 6
[ 150.117966] scsi 2:0:0:0: Attached scsi generic sg4 type 0
[ 150.119741] scsi 2:0:0:1: Direct-Access JMicron Tech 8136 PQ: 0 ANSI: 6
[ 150.123165] sd 2:0:0:1: Attached scsi generic sg5 type 0
[ 150.123574] sd 2:0:0:0: [sdd] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 150.124290] sd 2:0:0:0: [sdd] Write Protect is off
[ 150.124311] sd 2:0:0:0: [sdd] Mode Sense: 67 00 10 08
[ 150.125836] sd 2:0:0:0: [sdd] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 150.126753] sd 2:0:0:1: [sde] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 150.127065] sd 2:0:0:0: [sdd] Optimal transfer size 33553920 bytes
[ 150.127428] sd 2:0:0:1: [sde] Write Protect is off
[ 150.127449] sd 2:0:0:1: [sde] Mode Sense: 67 00 10 08
[ 150.128446] sd 2:0:0:1: [sde] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 150.129306] sd 2:0:0:1: [sde] Optimal transfer size 33553920 bytes
[ 150.141600] sdd: sdd1
[ 150.148360] sde: sde1
[ 150.153301] sd 2:0:0:0: [sdd] Attached SCSI disk
[ 150.155041] sd 2:0:0:1: [sde] Attached SCSI disk
Is the board defect?
