Thanks for trying to help.
Ive just tried this, it builds the Uboot image ok but then but it fails when trying to build the kernel?
The error i get is
HOSTCC scripts/basic/fixdep
HOSTCC scripts/kconfig/conf.o
HOSTCC scripts/kconfig/confdata.o
HOSTCC scripts/kconfig/expr.o
LEX scripts/kconfig/lexer.lex.c
YACC scripts/kconfig/parser.tab.[ch]
HOSTCC scripts/kconfig/lexer.lex.o
HOSTCC scripts/kconfig/parser.tab.o
HOSTCC scripts/kconfig/preprocess.o
HOSTCC scripts/kconfig/symbol.o
HOSTCC scripts/kconfig/util.o
HOSTLD scripts/kconfig/conf
configuration written to .config
Using .config as base
Merging ./kernel/configs/android-11.config
Value of CONFIG_CIFS is redefined by fragment ./kernel/configs/android-11.config:
Previous value: CONFIG_CIFS=y
New value: # CONFIG_CIFS is not set
Value of CONFIG_CIFS_XATTR is redefined by fragment ./kernel/configs/android-11.config:
Previous value: CONFIG_CIFS_XATTR=y
New value: # CONFIG_CIFS_XATTR is not set
Value of CONFIG_CIFS_POSIX is redefined by fragment ./kernel/configs/android-11.config:
Previous value: CONFIG_CIFS_POSIX=y
New value: # CONFIG_CIFS_POSIX is not set
Value of CONFIG_CRYPTO_MD4 is redefined by fragment ./kernel/configs/android-11.config:
Previous value: CONFIG_CRYPTO_MD4=y
New value: # CONFIG_CRYPTO_MD4 is not set
Value of CONFIG_DEVMEM is redefined by fragment ./kernel/configs/android-11.config:
Previous value: CONFIG_DEVMEM=y
New value: # CONFIG_DEVMEM is not set
Value of CONFIG_IKHEADERS is redefined by fragment ./kernel/configs/android-11.config:
Previous value: CONFIG_IKHEADERS=m
New value: CONFIG_IKHEADERS=y
Value of CONFIG_GKI_HIDDEN_GPU_CONFIGS is redefined by fragment ./kernel/configs/android-11.config:
Previous value: # CONFIG_GKI_HIDDEN_GPU_CONFIGS is not set
New value: CONFIG_GKI_HIDDEN_GPU_CONFIGS=y
Value of CONFIG_UNICODE_NORMALIZATION_SELFTEST is redefined by fragment ./kernel/configs/android-11.config:
Previous value: # CONFIG_UNICODE_NORMALIZATION_SELFTEST is not set
New value: CONFIG_UNICODE_NORMALIZATION_SELFTEST=y
Value of CONFIG_KSM is redefined by fragment ./kernel/configs/android-11.config:
Previous value: # CONFIG_KSM is not set
New value: CONFIG_KSM=y
Value of CONFIG_ZRAM_WRITEBACK is redefined by fragment ./kernel/configs/android-11.config:
Previous value: # CONFIG_ZRAM_WRITEBACK is not set
New value: CONFIG_ZRAM_WRITEBACK=y
merged configuration written to .config (needs make)
scripts/kconfig/Makefile:93: *** No configuration exists for this target on this architecture. Stop.
Makefile:627: recipe for target ‘rock5b.config’ failed
make[1]: *** [rock5b.config] Error 2
Makefile:350: recipe for target ‘__build_one_by_one’ failed
make: *** [__build_one_by_one] Error 2
failed to build some targets (9 seconds)
I know that my build environment is set up as I can still successfully build the Radxa supplied version.
