I’ve created a new repo for building a minimal sdcard for this board.
I compiles well, however I need some help getting the bootload working on the sdcard.
uboot is now building and the kernel is booting, however the console looses kernel output - missing a parameter in the bootargs to route the kernel’s console to uart0. See here : Kernel bootargs
Just one (maybe stupid) question: would it be possible to build and run a 32bit version of this as well? I need to use some static libs that are only available for 32 bit arm.
yes it probably is possible. You would have to alter the build system. You would also have to check that the devicetree is there for 32 bit compilation. Some iuboot modifications may be necessary as well.
Hi! Can you share description on how to create buildroot on Radxa Zero eMMC?
Maybe this overlays can help: https://wiki.radxa.com/Device-tree-overlays
I would create a detail instruction for all if success. (Example)
Thanks
Hi im trying to build an image but i encountered this error:
Kconfig file or fragment '/home/buildroot.rk3308/board/RK3308/rk3308_linux_defconfig' for 'linux' does not exist
make: *** [linux/linux.mk:569: /home/buildroot.rk3308/board/RK3308/rk3308_linux_defconfig] Error 1
Not sure what you have to clean or if you need to make distclean first, but those extra packages will install openssh and the server/client for them.
Next, copy your public RSA id to the overlays folder as the authorized_keys like so (assumes you are using Linux with the regular RSA id locations) ;
mkdir -p buildroot.rockchip/overlays/root/.ssh
cp ~/.ssh/id_rsa.pub buildroot.rockchip/overlays/root/.ssh/authorized_keys
# fix directory and file permissions to make it secure
Now when you build and boot from the sdcard, your RSA id will be on the board. You can just do
OK regarding your qustion about rockchip-adbd, are you wanting to install ADBD ? I haven’t used that, however I found it in the standard buildroot packages.
make menuconfig
Then look in Target Packages-> System Tools -> android-tools. You can either select it manually or add the correct variables to the rockpis_defconfig file to make it always auto select adbd.
Dear flatmax, ive encountered an issue with the clock, it says the date is 1970
ive tried install ntpd but it fails to update the date
the hwclock give me this error: can't open '/dev/misc/rtc': No such file or directory
any idea what im missing?
Typically for network time protocol I add the following to the config file :
BR2_PACKAGE_NTP=y
BR2_PACKAGE_NTP_NTPDATE=y
Not sure about the rtc issue you are noticing. Perhaps if that device is missing, you should start a new thread on that issue - hoping for a response from the Radxa people.
Dear flatmax, have you had any success of writing a build to SD Nand?
when i try to use the radxa rkdeveloptool with the included bootloader it doesnt work.
Once the system is built, it outputs the command to write the image to sdcard to the console. Normally just cut and paste that to write to sdcard. Here it is in the code base :
