Build 33 installed on NVMe not working
Enter the system normally when you turn it on for the first time.
But after restarting, I can’t enter the system anymore.
Environment:
rock-5b-spi-image-g3caf61a44c2-debug.img
rock-5b_debian_bullseye_kde_b33.img.xz
NVMe:
Transcend TS256GMTE110S 256.0 GB
and
Kingston A2000 NVMe SSD 500G
PS:
Using rock-5b-debian-bullseye-xfce4-arm64-20221031-1558-gpt.img.xz is no problem.
See the console log as follows:
DDR Version V1.08 20220617
LPDDR4X, 2112MHz
channel[0] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB
channel[1] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB
channel[2] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB
channel[3] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB
Manufacturer ID:0xff
CH0 RX Vref:28.7%, TX Vref:21.8%,21.8%
CH1 RX Vref:29.7%, TX Vref:22.8%,21.8%
CH2 RX Vref:30.7%, TX Vref:21.8%,20.8%
CH3 RX Vref:27.7%, TX Vref:22.8%,22.8%
change to F1: 528MHz
change to F2: 1068MHz
change to F3: 1560MHz
change to F0: 2112MHz
out
U-Boot SPL board init
U-Boot SPL 2017.09-g3caf61a44c2-220414 #stephen (Sep 29 2022 - 18:14:19)
Trying to boot from MMC2
MMC: no card present
mmc_init: -123, time 0
spl: mmc init failed with error: -123
Trying to boot from MMC1
mmc_init: -95, time 14
spl: mmc init failed with error: -95
Trying to boot from MTD2
Trying fit image at 0x4000 sector
Verified-boot: 0
Checking atf-1 0x00040000 … sha256(806278dba1…) + OK
Checking uboot 0x00200000 … sha256(6a08776395…) + OK
Checking fdt 0x0030a010 … sha256(d32827d3ac…) + OK
Checking atf-2 0x000f0000 … sha256(c00c7fd75b…) + OK
Checking atf-3 0xff100000 … sha256(71c3a5841b…) + OK
Checking atf-4 0xff001000 … sha256(2301cf73be…) + OK
Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000)
Total: 498.301 ms
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-405-gb52c2eadd:derrick.huang
NOTICE: BL31: Built : 11:23:47, Aug 15 2022
INFO: spec: 0x1
INFO: ext 32k is not valid
INFO: system boots from cpu-hwid-0
INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001
INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz
INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz
INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz
INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz
INFO: BL31: Initialising Exception Handling Framework
INFO: Entry point address = 0x200000
INFO: SPSR = 0x3c9
U-Boot 2017.09-g3caf61a44c2-220414 #stephen (Sep 29 2022 - 18:14:19 +0800)
Model: Radxa ROCK 5B
PreSerial: 2, raw, 0xfeb50000
DRAM: 15.7 GiB
Sysmem: init
Relocation Offset: edb6d000
Relocation fdt: eb9f9cd8 - eb9fecc8
CR: M/C/I
Using default environment
SF: Detected sfc_nor with page size 256 Bytes, erase size 4 KiB, total 16 MiB
Bootdev(atags): mtd 2
PartType: EFI
DM: v2
No misc partition
boot mode: None
FIT: No boot partition
No resource partition
Failed to load DTB, ret=-19
No find valid DTB, ret=-22
Failed to get kernel dtb, ret=-22
CLK: (sync kernel. arm: enter 1008000 KHz, init 1008000 KHz, kernel 0N/A)
b0pll 24000 KHz
b1pll 24000 KHz
lpll 24000 KHz
v0pll 24000 KHz
aupll 24000 KHz
cpll 1500000 KHz
gpll 1188000 KHz
npll 24000 KHz
ppll 1100000 KHz
aclk_center_root 702000 KHz
pclk_center_root 100000 KHz
hclk_center_root 396000 KHz
aclk_center_low_root 500000 KHz
aclk_top_root 750000 KHz
pclk_top_root 100000 KHz
aclk_low_top_root 396000 KHz
No misc partition
Net: No ethernet found.
Hit key to stop autoboot(‘CTRL+C’): 0
invalid flags type!
Device 0: Repair the backup gpt table OK!
Vendor: 0x1d79 Rev: U1006A3 Prod: H455073714
Type: Hard Disk
Capacity: 244198.3 MB = 238.4 GB (500118192 x 512)
… is now current device
Scanning nvme 0:2…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
1411 bytes read in 2 ms (688.5 KiB/s)
U-Boot menu
1: Debian GNU/Linux 11 (bullseye) 5.10.110-8-rockchip
2: Debian GNU/Linux 11 (bullseye) 5.10.110-8-rockchip (rescue target)
Enter choice: 1: Debian GNU/Linux 11 (bullseye) 5.10.110-8-rockchip
Retrieving file: /boot/initrd.img-5.10.110-8-rockchip
** File not found /boot/initrd.img-5.10.110-8-rockchip **
Skipping l0 for failure retrieving initrd
8212018 bytes read in 13 ms (602.4 MiB/s)
Retrieving file: /boot/vmlinuz-5.10.110-8-rockchip
28170752 bytes read in 36 ms (746.3 MiB/s)
append: root=UUID=79cfa060-ad46-4e28-b208-ad722575e31b quiet splash loglevel=4 rw earlycon consoleblank=0 console=tty0 console=ttyFIQ0,1500000n8 console=ttyAML0,115200n8 console=ttyS2,1500000n8 console=ttyS0,1500000n8 coherent_pool=2M irqchip.gicv3_pseudo_nmi=0 plymouth.ignore-serial-consoles cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 single
Retrieving file: /usr/lib/linux-image-5.10.110-8-rockchip/rockchip/rk3588-rock-5b.dtb
250190 bytes read in 19 ms (12.6 MiB/s)
Fdt Ramdisk skip relocation
No misc partition
Flattened Device Tree blob at 0x0a100000
Booting using the fdt blob at 0x0a100000
‘reserved-memory’ cma: addr=10000000 size=10000000
‘reserved-memory’ ramoops@110000: addr=110000 size=f0000
Using Device Tree in place at 000000000a100000, end 000000000a14014d
Adding bank: 0x00200000 - 0xf0000000 (size: 0xefe00000)
Adding bank: 0x100000000 - 0x3fc000000 (size: 0x2fc000000)
Adding bank: 0x3fc500000 - 0x3fff00000 (size: 0x03a00000)
Total: 2541.466 ms
Starting kernel …
[ 3.380950] fiq_debugger fiq_debugger.0: IRQ fiq not found
[ 3.380964] fiq_debugger fiq_debugger.0: IRQ wakeup not found
[ 3.380971] fiq_debugger_probe: could not install nmi irq handler
[ 4.030205] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
[ 4.030841] rk-pcie fe170000.pcie: IRQ msi not found
[ 4.030865] rk-pcie fe170000.pcie: Missing config reg space
[ 4.030996] rk-pcie fe170000.pcie: Missing config reg space
[ 4.031037] rk-pcie fe170000.pcie: invalid resource
[ 4.031235] rk-pcie fe150000.pcie: IRQ msi not found
[ 4.031260] rk-pcie fe150000.pcie: Missing config reg space
[ 4.031388] rk-pcie fe150000.pcie: Missing config reg space
[ 4.031427] rk-pcie fe150000.pcie: invalid resource
[ 4.031854] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
[ 4.031862] rkvdec2_init:1008: No niu aclk reset resource define
[ 4.031869] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
[ 4.031874] rkvdec2_init:1011: No niu hclk reset resource define
[ 4.032514] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found!
[ 4.032521] rkvdec2_init:1008: No niu aclk reset resource define
[ 4.032527] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
[ 4.032533] rkvdec2_init:1011: No niu hclk reset resource define
[ 4.297459] rockchip-hdptx-phy-hdmi fed70000.hdmiphy: hdptx phy pll locked!
[ 4.301204] rockchip-hdptx-phy-hdmi fed70000.hdmiphy: hdptx phy lane locked!
[ 4.560509] rk806 spi2.0: no sleep-setting state
[ 4.560564] rk806 spi2.0: no reset-setting pinctrl state
[ 4.560602] rk806 spi2.0: no dvs-setting pinctrl state
[ 4.792266] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
[ 4.797031] rksfc_base v1.1 2016-01-08
[ 4.828950] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[ 4.829136] rockchip-dmc dmc: failed to get vop pn to msch rl
[ 4.830175] rockchip-dmc dmc: could not find power_model node
[ 4.835480] rk-pcie fe190000.pcie: IRQ msi not found
[ 4.835643] rk-pcie fe190000.pcie: Missing config reg space
[ 4.835969] rk-pcie fe190000.pcie: Missing config reg space
[ 4.836139] rk-pcie fe190000.pcie: invalid resource
[ 4.838600] RKNPU fdab0000.npu: can’t request region for resource [mem 0xfdab0000-0xfdabffff]
[ 4.838687] RKNPU fdab0000.npu: can’t request region for resource [mem 0xfdac0000-0xfdacffff]
[ 4.838751] RKNPU fdab0000.npu: can’t request region for resource [mem 0xfdad0000-0xfdadffff]
[ 4.843638] debugfs: Directory ‘fdab0000.npu-rknpu’ with parent ‘vdd_npu_s0’ already present!
[ 4.870107] RKNPU fdab0000.npu: failed to find power_model node
[ 4.870183] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
[ 4.870231] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
[ 6.784083] panfrost fb000000.gpu: opp_parse_supplies: Invalid number of elements in opp-microvolt property (6) with supplies (1)
[ 6.784406] panfrost fb000000.gpu: _of_add_opp_table_v2: Failed to add OPP, -22
[ 6.784981] panfrost fb000000.gpu: devfreq init failed -22
[ 6.785186] panfrost fb000000.gpu: Fatal error during GPU init
[ 6.878694] debugfs: File ‘Capture’ in directory ‘dapm’ already present!
[ 6.960265] rk-multicodecs es8316-sound: ASoC: Property ‘rockchip,audio-routing’ does not exist or its length is not even
Cannot open access to console, the root account is locked.
See sulogin(8) man page for more details.
Press Enter to continue.
[ 6.982089] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_cancel_cpu_limit_freq freq qos nod add
[ 6.986918] debugfs: Directory ‘fb000000.gpu-mali’ with parent ‘vdd_gpu_s0’ already present!
[ 7.093257] debugfs: File ‘Left Hp mixer’ in directory ‘dapm’ already present!
[ 7.093497] debugfs: File ‘Right Hp mixer’ in directory ‘dapm’ already present!
[ 7.093689] debugfs: File ‘HPCP L’ in directory ‘dapm’ already present!
[ 7.093850] debugfs: File ‘HPCP R’ in directory ‘dapm’ already present!
[ 7.094022] debugfs: File ‘HPVOL L’ in directory ‘dapm’ already present!
[ 7.094182] debugfs: File ‘HPVOL R’ in directory ‘dapm’ already present!
[ 7.104471] rtk_btusb: btusb_open hdev->promisc ==0
[ 7.118796] rtk_btusb: fw name is rtl8852bu_fw
[ 7.119408] rtk_btusb: This is not 8723a, use new patch style!
[ 7.173694] BUG: spinlock bad magic on CPU#5, systemd-udevd/397
[ 7.173776] lock: 0xffff800014bad080, .magic: 00000000, .owner: /-1, .owner_cpu: 0
[ 7.258673] of_dma_request_slave_channel: dma-names property of node ‘/serial@feb90000’ missing or empty
[ 9.521856] Bluetooth: hci1: command 0xfc18 tx timeout
[ 17.415446] Bluetooth: hci1: BCM: failed to write update baudrate (-110)
[ 17.415524] Bluetooth: hci1: Failed to set baudrate
[ 19.548631] Bluetooth: hci1: command 0x0c03 tx timeout
[ 27.442090] Bluetooth: hci1: BCM: Reset failed (-110)
[ 58.296864] udc fc000000.usb: failed to start radxa-otgutils: -19
Debian GNU/Linux 11 rock-5b ttyFIQ0
rock-5b login: rock
Password:
Linux rock-5b 5.10.110-8-rockchip #f9d1b1529 SMP Fri May 12 14:07:29 UTC 2023 aarch64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
rock@rock-5b:~$ [ 83.216551] dma-pl330 fea30000.dma-controller: fill_queue:2263 Bad Desc(2)
rock@rock-5b:~$ sudo[ 86.921685] rtk_btusb: btusb_open hdev->promisc ==0
[ 86.995914] debugfs: File ‘force_bredr_smp’ in directory ‘hci0’ already present!
reboot
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
#1) Respect the privacy of others.
#2) Think before you type.
#3) With great power comes great responsibility.
[sudo] password for rock:
[ 92.917738] dma-pl330 fea30000.dma-controller: fill_queue:2263 Bad Desc(3)
[ 95.338564] reboot: Restarting system
LPDDR4X, 2112MHz
CH0 RX Vref:28.7%, TX Vref:22.8%,21.8%
CH1 RX Vref:29.7%, TX Vref:23.8%,22.8%
CH2 RX Vref:30.7%, TX Vref:21.8%,21.8%
CH3 RX Vref:27.7%, TX Vref:21.8%,22.8%
out
Verified-boot: 0
Total: 497.858 ms
INFO: spec: 0x1
INFO: SPSR = 0x3c9
DRAM: 15.7 GiB
Sysmem: init
CR: M/C/I
PartType: EFI
DM: v2
No misc partition
boot mode: normal
b0pll 24000 KHz
b1pll 24000 KHz
lpll 24000 KHz
v0pll 24000 KHz
aupll 24000 KHz
cpll 1500000 KHz
gpll 1188000 KHz
npll 24000 KHz
ppll 1100000 KHz
No misc partition
invalid flags type!
Device 0: Vendor: 0x1d79 Rev: U1006A3 Prod: H455073714
Type: Hard Disk
fs_devread read outside partition 6827226137651840472
Failed to mount ext2 filesystem…
** Unrecognized filesystem type **
no mmc device at slot 1
no mmc device at slot 0
Device 2: Vendor: 0x2207 Rev: V1.00 Prod: sfc_nor
Type: Hard Disk
Capacity: 16.0 MB = 0.0 GB (32768 x 512)
Device 1:
Device 0: unknown device
starting USB…
No working controllers found
USB is stopped. Please issue ‘usb start’ first.
starting USB…
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-rockchip
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
starting USB…
No ethernet found.
Could not get mtd 0
Booting FIT Image FIT: No boot partition
FIT: No fit blob
FIT: No FIT image
Unknown command ‘bootrkp’ - try ‘help’
I can boot the ‘rock-5b_debian_bullseye_cli_b33.img.xz’ of Build 33 images when used bootloader for ‘armbian version’ instead of ‘release version’ or ‘debug version’ these referenced in Rock5/install/spi - Radxa Wiki.
Could you try to change the bootloader to the ‘armbian version’?
Other bootloaders may only support a GPT partition but Build 33 images are probably not GPT partition.
Thx, it’s worked.
I confirmed to boot of the ‘rock-5b_debian_bullseye_cli_b39.img.xz’ image that was installed to NVMe using the SPI boot loader flashed by the latest normal bootloader of ‘rock-5b-spi-image-gbf47e81-20230607.img’.
The normal bootloader of ‘rock-5b-spi-image-gbf47e81-20230607.img’ probably supports the non-GPT partition image.
