So, I was flashing the 13GB large TwisterOS.Armbian.Focal.Radxa-Zero.Beta4.img when it failed in the middle of flashing using Etcher.
Now, when load “rz-udisk-loader.bin” I get the attached failure. I can’t seem to recover from this, erasing the eMMC again has no effect.
I guess my Radxa Zero is bricked?
1D init succeed
DATA transfer complete...
Check phy result
INFO : End of initialization
channel==0
RxClkDly_Margin_A0==236 ps 12
TxDqDly_Margin_A0==236 ps 12
RxClkDly_Margin_A1==236 ps 12
TxDqDly_Margin_A1==216 ps 11
TrainedVREFDQ_A0==74
TrainedVREFDQ_A1==74
VrefDac_Margin_A0==24
DeviceVref_Margin_A0==40
VrefDac_Margin_A1==23
DeviceVref_Margin_A1==40
channel==1
RxClkDly_Margin_A0==216 ps 11
TxDqDly_Margin_A1==236 ps 12
VrefDac_Margin_A0==25
VrefDac_Margin_A1==24
soc_vref_reg_value 0x 00000013 00000016 00000012 00000014 00000015 00000013 00000014 00000014 00000013 00000014 00000014 00000016 00000015 0
2D init succeed
ddr init done, boot next stage
result report
auto size-- 65535DDR cs0 size: 2048MB
DDR cs1 size: 2048MB
DMC_DDR_CTRL: 00e00024DDR size: 3928MB
cs0 DataBus test pass
cs1 DataBus test pass
cs0 AddrBus test pass
cs1 AddrBus test pass
Data req end
RUN bl2 usb boot
0.0;M3 CHK:0;cm4_sp_mode 0
MVN_1=0x00000000
MVN_2=0x00000000
OPS=0x30
ring efuse init
28 0b 30 00 01 16 26 00 00 14 35 39 53 42 56 50
[0.017149 Inits done]
secure task start!
high task start!
low task start!
run into bl31
NOTICE: BL31: v1.3(release):4fc40b1
NOTICE: BL31: Built : 15:57:33, May 22 2019
NOTICE: BL31: G12A normal boot!
U-Boot 2021.01-00042-g1e3a71b1dd (Sep 09 2021 - 20:42:32 +0800) radxazero
Model: Radxa Zero
SoC: Amlogic Meson G12A (Unknown) Revision 28:b (30:2)
DRAM: 3.8 GiB
MMC: sd@ffe03000: 0, sd@ffe05000: 1, mmc@ffe07000: 2
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In: serial@3000
Out: serial@3000
Err: serial@3000
Net: Net Initialization Skipped
No ethernet found.
** Invalid partition 1 **
You didn’t need to extract the 3.2GB img.xz TwisterOS Beta4 image, that’s only necessary when you transfer or manually copy extracted 13GB TwisterOS Beta4 image to uSD(MicroSD) or eMMC using ddcommands. When using Etcher you use 3.2Gb downloaded TwisterOS Beta4 image for Zero.
How were you exactly flashing a extracted 13GB TwisterOS image to eMMC using Etcher, was it to eMMC right? Can you still boot from uSD(microSD) with a TwisterOS image? What’s the eMMC size?
If you still can boot from uSD, then go into CLI(Command Line) and delete eMMC contents/partition:
I had the same problem. You have to use the linux fastboot commands to erase the emmc completely. With the windows tool, it looks like erasing is not working correctly (there is no error)
That bash script above is somewhat broken on some distros and will not correctly add ~/.nexustools to PATH. You might have to do this by hand or use ~/.nexustools/fastboot directly.
Replug the Zero with the USB button pressed. After that we can go into usb-disk mode to use Etcher:
sudo boot-g12.py rz-udisk-loader.bin
Of note: It’s really useful to use the UART port for debugging. I don’t see how I would have ever figured it out otherwise. Not very user friendly for sure. But that leads me to a much bigger concern: UART1 is not user accessible anymore. My plan was to investigate if the Radxa Zero could be used as a drop in replacement for a Raspberry Zero for use in a Prusa 3D printer. In the way the UART1 port is used right now that will not work since the Einsy RAMBo expects UART1 to be a normal serial device :-(((
Successfully installed the Debian image using the steps explained by @tinic with the following changes:
sudo fastboot erase 1 command failed
also ran sudo fastboot erase bootenv after sudo fastboot erase boot loader
Finally, after using Etcher to write the Debian image I ran the following to write the bootloader to eMMC: sudo dd if=u-boot.bin of=/dev/sdx bs=512 seek=1
Also, this was powered via laptop port and when I plugged in HDMI the light did not turn on / black screen. Changed to use a USB port from the monitor and was able to boot successfully.
Once started I followed the instructions to connect WIFI and was able to login via SSH from laptop.
I followed different way, I faced with same situation while flashing Manjaro image via Etcher. I am windows 10 user.
1-I prepared ubuntu server uSD card and booted.
2-connected via ADB and activated WIFI connection.
3-Shifted form adb shell to ssh
4-updated repo and libraries on ubuntu server.
5-“sudo fdisk -l” listed disks and determined eMMC device
6-“sudo fdisk /dev/mmcblk0” after this command, created new partition by following help.
7-“sudo mkfs.ext4 /dev/mmcblk0” (
8-“systemctl poweroff”
With this aproach I do not need to change my computer OS.
