Armbian - the best ARM framework 🐧
image Armbian setup some features and more! :penguin:
image Go to the Armbian Supported Boards page for Radxa
Download the latest version of @igorp operative system > Flash it into your Storage, boot your board with it and then… look here for some options if you feel the need off course.
In hope this helps everyone like it does to me so here goes some tips.
A bit in respect of Armbian 💸
The controversial phenomenon.
The controversy around Armbian is nothing but the open-source financial cliché that most developers face in order to pursue bigger goals in achieving the happiness of others. You will often see requests for donations and developers’ grey hairs in their attempts to make us understand that the reward per demand is sometimes neither fair nor feasible.
🔌Things to consider
Sometimes reboot will not work and if in due update it will brick… I suggest that you opt by doing shutdown and then start the system again for safety.
  • RK3588 Type C DP requires hot-unplug/hot-plug.
  • Armbian do set the system to automatic login.
  • The system runs better on Wayland.
  • Cloud Gaming is amazing on these boards.
  • Steam with the @Ptitseb master box64/box86 works.
  • Talented Armbian users keep supporting:
    – Kernel updates / GPU and HW Acceleration / Chromium Browser integrations at bay.
  • The Armbian framework is by far the most atractive for many developers to learn and support their projects on ARM.
🪁 Fan options
:point_right: Armbian already has this shorted ages ago but I will leave it here for further notice.
For the fan heatsink to work: (Armbian)
git clone https://github.com/lukaszsobala/fan-control-rock5b
cd fan-control-rock5b
make package
sudo dpkg -i fan-control*.deb
sudo systemctl enable fan-control
systemctl start fan-control
Or Non-GPIO 4012 Fan Fix (Archlinux) (not for armbian).
git clone https://github.com/XZhouQD/Rock5B_Naive_Pwm_Fan
cd Rock5B_Naive_Pwm_Fan/
cp fan_pwm /usr/local/bin/.
chmod +x /usr/local/bin/fan_pwm
cp fan_pwm.service /etc/systemd/system/.
systemctl daemon-reload
systemctl start fan_pwm
systemctl enable fan_pwm
Manage the fan manually :wind_face:
Prevent the system to take over fan control - Automatically.
sudo apt install i2c-tools -y
echo user_space | sudo tee /sys/class/thermal/thermal_zone0/policy
sudo i2cset -y -f 2 0x18 0x8A 0x20
(Fan speed 0x41 = 50%, 0x64 = 100%)
📱Bluetooth options
:point_right:t3: Some Wifi BT modules require an blacklist in order to work so here is the basics.
A8 Module Bluetooth:
sudo nano /etc/modprobe.d/blacklist.conf
then add these lines somewhere (at the bottom of the file is fine):
blacklist pgdrv
blacklist btusb
blacklist btrtl
blacklist btbcm
#blacklist btintel
Then press Ctrl+X, then Y.
sudo apt install bluez -y or bluetooth – not needed to install since latest armbian version
systemctl status bluetooth CTRL+ C
systemctl start bluetooth
Then reboot .
🌐 Wifi options
For AX210 Wifi and BT to Work - Not sure if we can activate this without internet at all.
#wifi
sudo wget -P /lib/firmware https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/plain/iwlwifi-ty-a0-gf-a0-59.ucode
sudo mv /lib/firmware/iwlwifi-ty-a0-gf-a0.pnvm /lib/firmware/iwlwifi-ty-a0-gf-a0.pnvm.bak
#bt
sudo wget -P /lib/firmware/intel https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/plain/intel/ibt-0041-0041.sfi
sudo wget -P /lib/firmware/intel https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/plain/intel/ibt-0041-0041.ddc
📢 Audio options
Audio Tutorial for Bluetooth devices: – (not required since armbian latest versions)
:point_right: Some valid information on how to fix issues with audio be free to explore.
sudo add-apt-repository ppa:pipewire-debian/pipewire-upstream
sudo nala install pipewire pipewire-audio-client-libraries gstreamer1.0-pipewire libpipewire-0.3-{0,dev,modules} libspa-0.2-{bluetooth,dev,jack,modules} pipewire{,-{audio-client-libraries,pulse,media-session,bin,locales,tests}} -y
systemctl --user daemon-reload
systemctl --user --now disable pulseaudio.service pulseaudio.socket
systemctl --user --now enable pipewire pipewire-pulse
pactl info
reboot
💽 Flashing by Terminal
(Short guide) SPI flashing on the board itself would be:
wget https://dl.radxa.com/rock5/sw/images/others/zero.img.gz
gzip -d zero.img.gz
sudo dd if=zero.img of=/dev/mtdblock0
Wait ~5 minutes for the command to complete, check that sudo md5sum /dev/mtdblock0 returns 2c7ab85a893283e98c931e9511add182. Then:
wget https://dl.radxa.com/rock5/sw/images/loader/rock-5b/release/rock-5b-spi-image-g49da44e116d.img
sudo dd if=rock-5b-spi-image-g49da44e116d.img of=/dev/mtdblock0
Wait ~5 minutes for the command to complete, check that this time sudo md5sum /dev/mtdblock0 returns 46de85de37b8e670883e6f6a8bb95776. Then:
sync
reboot
For more info: https://wiki.radxa.com/Rock5/install/spi
More info (Spi to NVME boot from SD Card):
http://www.fieldday.io/armbian-rock5b/
🥛 App Manager Hubs
Raspberry Pi App Store for Open Source Projects.
wget -qO- https://raw.githubusercontent.com/Botspot/pi-apps/master/install | bash
FlatHub - Hundreds of apps and games for Linux.
sudo apt install flatpak -y ; sudo flatpak remote-add --if-not-exists flathub https://dl.flathub.org/repo/flathub.flatpakrepo ; sudo flatpak update -y
More flathub apps
Chromium Browser & Extension Manager
sudo flatpak install flathub org.chromium.Chromium -y
sudo flatpak install flathub com.mattjakeman.ExtensionManager -y
Some random apps
sudo flatpak install flathub org.gnome.Boxes -y
sudo apt install libvirt -y
sudo flatpak install flathub io.github.ungoogled_software.ungoogled_chromium -y
sudo flatpak install flathub io.github.realmazharhussain.GdmSettings -y
sudo flatpak install flathub tv.kodi.Kodi -y
sudo flatpak install flathub io.github.dosbox-staging -y
sudo flatpak install flathub com.dosbox_x.DOSBox-X -y
Emulation stuff for old school games
sudo flatpak install flathub org.ryujinx.Ryujinx -y
sudo flatpak install flathub org.libretro.RetroArch -y
sudo flatpak install flathub net.kuribo64.melonDS -y
sudo flatpak install flathub org.ppsspp.PPSSPP -y
sudo flatpak install flathub org.duckstation.DuckStation -y
sudo flatpak install flathub org.DolphinEmu.dolphin-emu -y
sudo flatpak install flathub com.github.Rosalie241.RMG -y
sudo flatpak install flathub io.mgba.mGBA -y
sudo flatpak install flathub io.github.simple64.simple64 -y
sudo flatpak install flathub com.vba_m.visualboyadvance-m -y
Bauh – a Manager for Your Multi-Package Needs
sudo apt install python3 python3-pip python3-yaml python3-dateutil python3-pyqt5 python3-packaging python3-requests -y ; sudo pip3 install bauh ; sudo pip3 install bauh --upgrade
💫 Graphics Acceleration / Performance
LiuJianFeng & PPA Graphics Panfrost/fork on Wayland
OpenCL runtime (libmali)
sudo add-apt-repository ppa:rockchip-linux/ppa
sudo add-apt-repository ppa:liujianfeng1994/rockchip-multimedia
sudo apt update ; sudo apt install mali-g610-firmware rockchip-multimedia-config glmark2 glmark2-es2 glmark2-es2-wayland mesa-utils malirun -y ; sudo apt upgrade -y
sudo add-apt-repository --remove ppa:liujianfeng1994/panfork-mesa
sudo add-apt-repository --remove ppa:liujianfeng1994/rockchip-multimedia
glxinfo|grep OpenGL -- check actual status of things
mkdir -p ~/tmp/libmali && cd ~/tmp/libmali
wget 'https://github.com/tsukumijima/libmali-rockchip/releases/download/v1.9-1-55611b0/libmali-valhall-g610-g13p0-gbm_1.9-1_arm64.deb'
sudo dpkg -i ./libmali-valhall-g610-g13p0-gbm_1.9-1_arm64.deb
Max out the SoC performance (Optional) - That’s if you want some real performance at the cost of being hot and power-hungry.
sudo echo performance | sudo tee /sys/devices/system/cpu/cpufreq/policy6/scaling_governor
sudo echo performance | sudo tee /sys/class/devfreq/fb000000.gpu/governor
sudo echo performance | sudo tee /sys/class/devfreq/dmc/governor
sudo echo performance | sudo tee /sys/class/devfreq/fdab0000.npu/governor
Once you’re done with your benchmarks, you may want to go back:
echo ondemand | sudo tee /sys/bus/cpu/devices/cpu[046]/cpufreq/scaling_governor
echo dmc_ondemand | sudo tee /sys/class/devfreq/dmc/governor
echo simple_ondemand | sudo tee /sys/class/devfreq/fb000000.gpu/governor
Or add to startup script /etc/rc.local
Or if you want a shortcut for performance / ondemand and powersave do nano .bash_aliases and add these instructions - save it Ctrl X, Yes, restart and after just type the governor you desire Terminal: performance to trigger it.
alias performance="echo performance | sudo tee /sys/bus/cpu/devices/cpu[046]/cpufreq/scaling_governor /sys/class/devfreq/dmc/governor /sys/class/devfreq/fb000000.gpu/governor"
alias ondemand="echo ondemand | sudo tee /sys/bus/cpu/devices/cpu[046]/cpufreq/scaling_governor && echo dmc_ondemand | sudo tee /sys/class/devfreq/dmc/governor && echo simple_ondemand | sudo tee /sys/class/devfreq/fb000000.gpu/governor"
alias powersave="echo powersave | sudo tee /sys/bus/cpu/devices/cpu[046]/cpufreq/scaling_governor /sys/class/devfreq/dmc/governor /sys/class/devfreq/fb000000.gpu/governor"
🧙🏼‍♂️ Mesa / Panthor & Panfork Benchmarks 🏄🏼‍♂️
Older values tested on Panfrost 🧗🏼‍♂️
PAN_MESA_DEBUG=gofaster glmark2
Expected results: 1st Line - 1669fps - Score: 1249fps - you are good.
PAN_MESA_DEBUG=gofaster glmark2-es2-wayland
Expected results: 1st Line - 3527fps - Score: 4067fps - you are sorted.
LD_LIBRARY_PATH=/usr/lib/aarch64-linux-gnu/mali glmark2-es2-wayland
Expected results: 1st Line - 4229fps - Score: 3933fps - what a legend.
Panthor 6.1-rkr3 (Mesa 24.1.4) - Score beats 3000 - Panthor is now faster than Panfrost.
Terrain - 110 & Refract - 273
Panfork on 6.1-rkr3 - Scored 2274
Terrain - 104 & Refract - 231
Panfork with gofaster on 6.1-rkr3 - Score 4324
Terrain - 157 & Refract - 329
Mali Blob G13P0 - Vendor Finest - Score 3866 :dizzy:
Terrain - 341 :ice_cube: & Refract - 583 :fire:
Tested with soc set to performance
sudo nano /sys/class/devfreq/dmc/governor
Not everyones values will be the same.
Cores should be @ the same values of frequency ~2256.00 MHz.
Rockchips RK3588/S.
🚧 OpenCL Libmali Malirun 'Hack'
OpenCL runtime (libmali) For Mali to Work on Armbian Panfrost
Do a performance boost on apps with malirun as trigger !
malirun chromium-browser #do this to other apps too
📄 External Guides
Switching Between Mali Blobs and Panfrost - for experts to run X11 like a Pro
Proxmox-Arm64
Setup Hardware Acceleration on RK3588
🕹️ NicoD gaming script
@nicod Has also a gaming script that works for all rockchip single boards:
git clone https://github.com/NicoD-SBC/armbian-gaming.git
cd armbian-gaming
bash ./armbian-gaming.sh
🤖 Redroid for Rockchip ARM64
Only works on Panfrost kernel 5.10
Android Emulator to your ARM system (ReDroid with Scrcpy and Docker):
sudo apt install docker.io scrcpy android-tools-adb -y
sudo docker run -d -p 5555:5555 -v ~/redroid-data:/data --restart unless-stopped --name redroid --privileged cnflysky/redroid-rk3588:13.0.0-latest androidboot.redroid_height=1920 androidboot.redroid_width=1080
Currently only working on Panfrost.
adb disconnect localhost:5555 ; adb connect localhost:5555 ; scrcpy -s localhost:5555
Just add this alias in nano .bash_aliases and run it as malior each time:
alias malior="malior-droid stop ; adb disconnect localhost:5555 ; malior-droid start ; adb connect localhost:5555 ; scrcpy -s localhost:5555 ; malior-droid resize 720x1280"
Change it to english this way. Just drag and drop your .apk file into the android window it will auto install it .
🧑🏻‍🔧 Fix the google play store by doing this
To become certified with access to the play store you have to:
1 - Install a device ID apk to get this Device ID and register it on your google account.
2 - Register it here: https://www.google.com/android/uncertified/
3 - Restart Malior-Droid again and add your google account manually on settings.
4 - Send apkpure the emulator window and start installing apps like a boss !
🧑🏻‍🔬 Kernel modules required ``` CONFIG_STAGING=y CONFIG_ASHMEM=y CONFIG_ANDROID_BINDER_IPC=y # CONFIG_ANDROID_BINDERFS is not set CONFIG_ANDROID_BINDER_DEVICES="binder,hwbinder,vndbinder" # CONFIG_ANDROID_BINDER_IPC_SELFTEST is not set CONFIG_ESD_FS=y ```
🪀 Waydroid for Panthor
Credits to @Willzen - The Armbian vendor kernel version now includes Panthor, and will soon be able to run it as well.
Works with the current Panthor Install it!
sudo apt install curl ca-certificates -y
curl https://repo.waydro.id | sudo bash
sudo apt install waydroid -y
sudo wget -P https://github.com/WillzenZou/armbian_fork_build/releases/download/willzen-armbian-24.5.0/2.waydroid-panthorv10-240416-v1.img.tar.gz
cd /usr/share ; sudo mkdir waydroid-extra ; cd waydroid-extra ; sudo mkdir images ; cd
sudo tar -xf 2.waydroid-panthorv10-240416-v1.img.tar.gz -C /usr/share/waydroid-extra/images
sudo waydroid init -f -i /usr/share/waydroid-extra/images
Apps will be re-sizable but never the show-full-gui
sudo waydroid container stop ; waydroid session stop ; sudo waydroid prop set persist.waydroid.multi_windows true ; sudo waydroid session start ; waydroid show-full-ui
Supposedly resizes the full-gui
sudo waydroid container stop ; waydroid session stop ; sudo waydroid prop set persist.waydroid.multi_windows true ; sudo waydroid prop set persist.waydroid.width 720 ; sudo waydroid prop set persist.waydroid.height 1280 ; systemctl restart waydroid-container ;  waydroid session start
Install Google Store
Select gapps and microG from Android 13 off the Script - For your Waydroid Android 11
sudo apt install lzip -y
git clone https://github.com/casualsnek/waydroid_script
cd waydroid_script
python3 -m venv venv
venv/bin/pip install -r requirements.txt
sudo venv/bin/python3 main.py
Other commands
waydroid app install com.app.apk
waydroid app launch com.app
waydroid app list
🎮 Steam Installation Tutorial
sudo dpkg --add-architecture armhf && sudo apt update && sudo apt install aptitude -y
sudo apt install gcc-arm-linux-gnueabihf libc6 binfmt-support cmake nano lsof gedit git cabextract neofetch -y && neofetch
#sudo aptitude install -y zenity build-essential git cmake cabextract gcc-arm-linux-gnueabihf libgdm1:armhf libudev1:armhf libgl1-mesa-dri:armhf libglapi-mesa:armhf libglu1-mesa:armhf libglx-mesa0:armhf mesa-va-drivers:armhf mesa-vdpau-drivers:armhf mesa-vulkan-drivers:armhf libsdl1.2debian:armhf libegl-mesa0:armhf
git clone --depth 1 https://github.com/ptitSeb/box64
git clone --depth 1 https://github.com/ptitSeb/box86
cd ~/box64; mkdir build; cd build; cmake ../ -DRK3588=1; make -j$(nproc); sudo make install
cd ~/box86; mkdir build; cd build; cmake ../ -DRK3588=1; make -j$(nproc); sudo make install; cd
#cd /usr/lib/arm-linux-gnueabihf/ && sudo ln -sfv libpng16.so.16 libpng12.so.0 && cd
#Hold a beer it will take a while.
sudo nano /usr/share/binfmts/box86.conf
package box86
interpreter /usr/local/bin/box86
magic \x7fELF\x01\x01\x01\x00\x00\x00\x00\x00\x00\x00\x00\x00\x02\x00\x03\x00
mask \xff\xff\xff\xff\xff\xff\xff\x00\xff\xff\xff\xff\xff\xff\xff\xff\xfe\xff\xff\xff
sudo nano /usr/share/binfmts/box64.conf
package box64
interpreter /usr/local/bin/box64
magic \x7fELF\x02\x01\x01\x00\x00\x00\x00\x00\x00\x00\x00\x00\x02\x00\x3e\x00
sudo update-binfmts --import box86.conf
sudo update-binfmts --import box64.conf
sudo update-binfmts --enable
sudo update-binfmts --display
sudo systemctl restart systemd-binfmt
cd ~/box86
./install_steam.sh
Installation is now finished EnJoy!
Easier method: Just install steam via Pi-Apps
wget -qO- https://raw.githubusercontent.com/Botspot/pi-apps/master/install | bash ; pi-apps
FEX-EMU or NicoD Armbian-Gaming Script
:desktop_computer: Desktop Ricing #Unixporn
🎛️ Tweaks and Shell Extensions🎚️
Getting the Gnome Shell Extensions
sudo apt install gnome-tweaks gnome-shell-extension-manager chrome-gnome-shell -y
Open Tweaks and enable the dam Titlebar buttons (Why is this even disabled -.-’ )
You can now install ‘el’ gnome extensions:
Enable User Themes / Dash to Panel or Dash to Dock and Freon or Vitals and Screenshot Tool and Compiz for an wobble effect and Burn my Windows to keep your system lit :fire:
Rice your Desktop
Themes / Icons - Shell - The Rice
Download this .themes
Download these .icons
Download this Wallpaper
sudo tar -xf Cold-Metal-No-Logo-GTK.tar.xz -C /usr/share/themes
sudo tar -xf Zafiro-Nord-Black.tar.xz -C /usr/share/icons
/home/$USER/.themes & /home/$USER/.icons (if they dont exist just mkdir them).
Giving /home/.themes & .icons writting permissions can work.
You can also use /usr/share/themes by sudo tar -xf Cold-Metal-No-Logo-GTK.tar.xz -C /usr/share/themes
Then user themes extension from gnome shell extensions has to be enabled by sudo apt install chrome-gnome-shell -y and when user themes is enabled we can then apply shell themes on Tweaks.
Open Tweaks application and select these themes.
☄️ Rice your Login Manager 🌍 ▼
Not all SDDM themes found on github works on non archlinux systems. If you find a way let me know
Install these requirements
sudo apt install -y sddm qtdeclarative5-dev qml-module-qtgraphicaleffects qml-module-qtquick-controls qml-module-qtquick-controls2 libqt5svg5 qt6-wayland qt6-5compat-dev qtcreator ; QT_QPA_PLATFORM=xcb
#systemctl disable gdm
#systemctl disable lightdm
#systemctl enable sddm
For theme setting:
sudo nano /etc/sddm.conf.d/theme.conf.user
or
Theme folders for installing and ls:
cd /usr/share/sddm/themes/
Test your themes before applying:
sddm-greeter --test-mode --theme /usr/share/sddm/themes/maya
sddm-greeter-qt6 --test-mode --theme /usr/share/sddm/themes/sddm-astronaut-theme
sudo git clone https://github.com/Keyitdev/sddm-astronaut-theme.git /usr/share/sddm/themes/sddm-astronaut-theme
sudo cp /usr/share/sddm/themes/sddm-astronaut-theme/Fonts/* /usr/share/fonts/
echo "[Theme]
Current=sddm-astronaut-theme" | sudo tee /etc/sddm.conf
sudo git clone https://github.com/JaKooLit/simple-sddm-2.git /usr/share/sddm/themes/simple-sddm-2
echo "[Theme]
Current=simple-sddm-2" | sudo tee /etc/sddm.conf
sddm-greeter --test-mode --theme /usr/share/sddm/themes/simple-sddm-2
sudo git clone https://github.com/RadRussianRus/sddm-slice.git /usr/share/sddm/themes/sddm-slice
echo "[Theme]
Current=sddm-slice" | sudo tee /etc/sddm.conf
sddm-greeter --test-mode --theme /usr/share/sddm/themes/sddm-slice
SteamOS Theme
sudo git clone https://github.com/JiayuanWen/sddm-sugar-steamOS.git /usr/share/sddm/themes/sddm-sugar-steamOS
echo "[Theme]
Current=sddm-sugar-steamOS" | sudo tee /etc/sddm.conf
sddm-greeter --test-mode --theme /usr/share/sddm/themes/sddm-sugar-steamOS
sudo git clone https://github.com/Match-Yang/sddm-deepin.git
cd sddm-deepin
bash ./install.sh
sddm-greeter --test-mode --theme /usr/share/sddm/themes/deepin
sudo git clone https://github.com/Michal-Szczepaniak/sddm-theme-amadeus.git /usr/share/sddm/themes/sddm-theme-amadeus
echo "[Theme]
Current=sddm-theme-amadeus" | sudo tee /etc/sddm.conf
sddm-greeter --test-mode --theme /usr/share/sddm/themes/sddm-theme-amadeus
sudo git clone https://github.com/m-wynn/sddm_wynn-theme.git /usr/share/sddm/themes/sddm_wynn-theme
echo "[Theme]
Current=sddm_wynn-theme" | sudo tee /etc/sddm.conf
sddm-greeter --test-mode --theme /usr/share/sddm/themes/sddm_wynn-theme
sudo git clone https://github.com/3ximus/abstractdark-sddm-theme.git /usr/share/sddm/themes/abstractdark-sddm-theme
echo "[Theme]
Current=abstractdark-sddm-theme" | sudo tee /etc/sddm.conf
sddm-greeter --test-mode --theme /usr/share/sddm/themes/abstractdark-sddm-theme
sudo git clone https://github.com/AlfredoRamos/urbanlifestyle-sddm-theme.git /usr/share/sddm/themes/urbanlifestyle
echo "[Theme]
Current=urbanlifestyle" | sudo tee /etc/sddm.conf
sddm-greeter --test-mode --theme /usr/share/sddm/themes/urbanlifestyle
Source KDE themes
Source KDE themes
Github for SDDM themes
🏝️ Try Other Desktop Environments for ARM 🦅
UbuntuCraft
#ubuntucraft for arm isnt there yet..
#curl -LO https://github.com/archcraft-os/archcraft-arm/releases/download/1.0/archcraft-arm.tar.gz
tar -xzvf ubuntucraft.tar.gz
cd ubuntucraft
# nano customize.sh (optional)
# user/pass archcraft
sudo bash ./install.sh
#choose sddm not gdm3
Fix the top bar modules for each theme being on this example the “default” one:
1 - nano ~/.config/openbox/themes/default/polybar/config.ini
2 - Find the line modules-right =. This should be line 147.
3 - Remove the “battery” module, replacing it with “temperature”
Paste this instead:
modules-right = temperature dot volume dot network dot LD sysmenu RD
JaKooLit - Ubuntu-Hyprland
git clone --depth=1 -b Ubuntu-24.04-LTS https://github.com/JaKooLit/Debian-Hyprland.git ~/Ubuntu-Hyprland
cd ~/Ubuntu-Hyprland
chmod +x install.sh
./install.sh
SUPER Environments often needs changed from SUPER to FN+SUPER
# Look for $mainMod = SUPER
nano ~/.config/hypr/hyprland.conf
nano ~/.config/hypr/configs/Keybinds.conf
# Change it to $mainMod = FN+SUPER
:video_game: Try Cloud Gaming its perfect!:computer_mouse:
The credits are not mine this soup was given by the most talented members of this community so thanks to everyone that help me as I am new to all of this.
@GinKage @incognito @rauxon @Googulator @amazingfate @student RadxaYuntian hipboi
Great review post. Thank you!
Great post, thanks. Appreciate the details and it being linked to the official page.
Had rock 5b brick also recently. Just wanted to confirm, it happens during reboot only? mine did after an update (and possibly a reboot).
yeah pretty much it… don’t do restarts… just shutdown and cut power and power on. That’s how I have been playing around.
Thanks for this post (and the afterburner image post). It really is the fastest way to get the rock5b up and running with acceptable performance and stability.
I have been running this setup now with nvme and the A8 for over a month as a daily work desktop and is very impressed by how capable it is even in this early stage of development.
The only problem I have encountered is some random dns/resolv problem which there migth be a fix for here:
Where to find more details about this please?
In the link you just quoted.
The link has no information about Windows 7. The link is to an (unofficial) ARM64 port of Proxmox VE, which, by itself, is a purpose built Linux distribution with web enabled access to LXC and KVM. LXC only supports Linux guests and KVM supports virtualization of underlying hardware, ARM64, in this case. Hence, in theory Windows 7, which has no ARM port, should not work as guest; at least not virtualized (QEMU emulated should work, albeit with poor performance)
Thats all the information I have. Sorry Dan I dont use Proxmox.
Edit: https://discord.com/channels/855634073376260096/921238019019796560/1077315533361385623
While from the screen grab the KVM tunable flag seems turned on, the flag is probably getting ignored. While KVM can filter some CPU features, architecture of host and guest must be the same for virtualization to work. This is (non-KVM) emulation, instead
Steam installation guide for Armbian step by step.
Props to @jtremblant !
Is it possible to flash direkt to NVMe. openFyde is booting correct after flashing zu NVMe via balenaEtcher. When flashing Armbian_23.8.1_Rock-5b_jammy_legacy_5.10.160.img the Rock 5b doesn’t boot.
It is but requires you to flash the spi first for that to work. So I best suggest u not to and to flash your emmc then yes move files to nvme.
I flashed the SPI with maskrom mode and an external computer already to boot fydeOS from it. But armbian doesn’t boot. Can you explain what you mean exactly?
edit: I missed that I need another SPI image (armbian version). Thanks for the advice @DarkevilPT
Likely its not bricked its the PD power loop and its never booting root, I have fallen foul of it so many times I don’t use PD and just have a 12v usb-c barrel connector.
Yeah no to cpu emulation also :slight_smile:
https://github.com/edk2-porting/edk2-rk3588 is coming along slowly but likely will never run windows so that is all I know.
Also to anyone as does anyone know what the time base is of /sys/class/pwm/pwmchip2/pwm0/period is?
I am presuming milisecs… just checking as usually fans are 20-25Khz just above hearing range
I did a bash script but been wondering what the time base really is for period?
Anyway much prefer the GPIO fans as you can PWM a brushless 2 pin fan but they are not really wired up that way.
20mm 3pin gpio fan https://www.raspberrypi.com/products/raspberry-pi-4-case-fan/
30mm 3pin gpio fan https://thepihut.com/products/software-controllable-5v-30mm-fan-for-raspberry-pi
40mm 3pin gpio fan https://www.aliexpress.us/item/1005002518918026.html
I am not that keen on armbian as its always seems to come preinstalled with user side scripts.
I prefer vanilla apart from tweaks needed under the hood so why I prefer.
As sticks to rk3588 for a large nunber of boards and also has mainline and are closer to the original distro of Ubuntu but no Debian.
zgrep -i panfrost /proc/config.gz
Hey Guys,
Do you have any idea how much work will be involved to add support for the 5B+. I just bought one and without Armbian and the hardware acceleration patches it’s basically unusable for me. I’m really hoping it will be possible to get it working the same for the 5B+ otherwise I’ll need to sell it and buy an older 5B…
Not that much, really. It’s basically just a matter of copying the device tree from Radxa’s repository, and adding a board config for the build. Hardly a couple hours’ worth of work, yet it’s unverifiable without having the hardware on hand, or a very impatient volunteer willing to help (wink-wink).
