Amateurs are not willing to pay anything for software. Especially not for Linux. Its free. Why paying for?
Mainline is joint effort, a mixture of donations, sponsorship and various business interests. Its done when its done and it remains a big burden keeping it functional. Bill is extreme. Can’t go faster and can’t be paid by one vendor as all other vendor could be paying nothing, benefits the same and kill the one that pay for R&D … mainline is a complex and expensive question.
It is interesting to see how people are happy, unsatisfied and completely ignorant to software development … “I purchase a hardware and it has to work. I don’t care. I expect fully functionality. Fix it. No, I have no interest to pay your time fixing it. You just have to fix it.” and answer to this can not be nice as at least we didn’t sell you anything. Yet.
Same here, finally managed to boot directly from NVMe using my 65w Dell USB-C PD power supply …
It now boots reliably using it with both SD (slow ass one) and NVMe at least with armbian jammy image and its associated SPI image.
Is the magic done in the new SPI code ? Who knows …
I was using a 5v 6A dumb USB charger before which allowed me to write on the NVMe but booting from it systematically failed, voltage drop down issue under load using 5v ?
Looks like 20v was negociated
tcpm_source_psy_4_0022-i2c-4-22
Adapter: rk3x-i2c
in0: 20.00 V (min = +20.00 V, max = +20.00 V)
curr1: 3.25 A (max = +3.25 A)
I’m using a Samsung EVO 970 1TB which I had on hand, it works great with booting direct to nvme on debian, with updated SPI. I didn’t buy this specifically for the Rock5B, but performance is great.
Rockchip and ARM Mali could at least open up their standards for their RK3588 and G610 respectively. This isn’t costly to them and avoids costly reverse engineering. Hardware vendors can do a lot more to enable Mainline development, both Linux kernel and Mesa Panfrost (not Panfork). And yes I do believe Radxa, as board vendor, has some responsibility, and is overselling as they claim, I quote: “Open Source Hardware” (it isn’t) and “completely compatible with (…) Vulkan1.2” (Vulkan isn’t working).
Talking about vulkan, there is little Radxa can do here. arm mali G610 does support Vulkan 1.2 and it has a working driver for … Android. GNU Linux is always second-class citizen for these vendors due to small market size.
Thank you for the guide. Unfortunately it doesn’t work at all with my system. After copying the armbian image to the nvme drive and rebooting there is an error message “/dev/mmcblk0p1 does not exist”
Why is there no easy way to install the OS like there is for Raspberry Pis?
Why is there no possibility to select boot devices?
why do you need sd? are you sure it isn’t booting from SD instead as I believe it is default boot order in case there is both NVMe and SD. unless you put dummy SD with no OS installed
What I’m expecting from radxa is no flaws in hardware implementation, and that their board is able to exploit at least as much as performance as other board vendors (like khadas edge 2,..).
If this is the case then I don’t regret buying this device.
Regarding drivers support, I also consider it is more Rockchip’s (and Mali’s) responsability than Radxa. I agree they should just avoid advertising more than their board is capable of doing
I’ve used SD to bootstrap the board and then installed Armbian on NVMe with the builtin install script (armbian-install). I’m sure it boots from NVMe as it boots from it with the SD removed.
Also with the Armbian SPI image the boot order is always SD first then NVMe from what I can tell.
I just checked that on two new boards and this works only for jammy, but armbian with debian use some spi image which don’t support booting from nvme. I usually compile armbian myself but this time I downloaded official images and only updated all packages (which BTW changed login headline from community support to no end user support). Script was able to move system to nvme and update spi block, but image was not correct - it can’t detect nvme and boot from it. The one that worked was image from https://wiki.radxa.com/Rock5/install/spi (that one for armbian).
@bearpaw board is probably good, just several builds needs more tests, for now armbian-install don’t work for some variants.
We brought this up internally and it’s a bug, it should still say it is Community Supported. This will hopefully be addressed here sometime in the near future.
This detail makes just a bit of confusion, understandably anything can be broken on custom images, so I needed to pay extra attention for right image. The main issue now is that debian needs different spi to work for now and this variant of armbian-install is incomplete.
Other thoughts on this script:
@igorp said he just added linux formatted nvme and run script, I tried with brand new nvme drive, checked if it’s working, but did not created partitions yet, drive was not found in script, but it listed two eMMC drives (one to small and one that was source)
when I added partitions/fs to nvme it showed up, but then it warned me that dest will be formatted and asked for new fs
it estimated copy time to about 4 min, it took about 20s, AFAIR showing some progress
it asked for spi update, this time estimated for few minutes, that one took much more time than earlier and no progress (RKDevTool shows) was given.
