same error with taglib or different?
New error logKodi-compile-1.zip (29.1 KB)
ah thats because java version is too new, let me find a way to automatically handle this on package, if not you might need to manually intervene and install an old version of java runtime environment
what is the output of archlinux-java status ?
Available Java environments:
java-10-openjdk
java-17-openjdk
java-21-openjdk (default)
sudo archlinux-java set java-10-openjdk
should work, then install again, it will continue from where it failed
Compiletime about three hours
works fine !
option -noconfirm stopps removal of kodi-matrix-mpp-git
Thanks for your help
Uli
yeah it take some time because it build every binary addon,
but the next update will be 15mins max. only the first build takes time.
by the way, i found some bugs in agr tool. so you need to update the tool with
python -m pip install https://github.com/hbiyik/agr/archive/master.zip --break-system-packages --force-reinstall
when updated, the tool can self update itself with below command, so you dont need to issue above command anymore once updated.
agr update --agr
Just a question,
will there an update for a newer version of repo 7ji
chromium-mpp-git be.
Regards
Uli
we are discussing here:
both him and myself are a little bit tired by maintaining those, from my pov, maintaining the binary distribution is also another pain, but we will see.
UPDATE:
kodi-nexus-mpp-gitand andkodi-binary-addons-gitpackages are now completely separated.
Now first time building of kodi takes 45mins, update build takes about 5 minutes
first time building of kodi-binary-addons-git takes 2.5 hours, update build takes around 10 mins.
@Uli_Beling i think you are the only one, if you have previous built kodi, you need uninstall pacman -R kodi-nexus-mpp-git and reinstall with kodi-nexus-mpp-git to get updates, because the package names are changed a bit.
- removed
moonlight-qt-gitpackage since the fix forffmpeg-rockchipis merged to upstream moonlight. You can use AUR to installmoonlight-qt-gitpackage instead ofagr
to update agr:
agr update --agr
to update the system
agr update
It also won’t let me build kodi from AGR even after clearing all my previous builds. I will try the Java fix you mentioned earlier.
::Java fix worked and kodi installed successfully
good, i am working on an update to agr which will provide at least 5x speed improvement. currently it is meant to just work, now i need to make it faster
Does anyone of you guys know a working image with kernel 6.x and hdmi output ?
Radxa , Armbian , Bredos , ARCH ?
regards
Uli
Is there a fix for Firefox? Its the only browser I noticed that freezes/crashes. Librewolf is the alternative I use for now
With the new ffmpeg-rockchip support for firefox is dropped.
Also firefox is getting really slow lately so i kinda lost my appetite to make it work.
But
There is below hack i managed to work out only for h264, but this is ugly and not covering all formats, and ff is slow.
I might work on it i also have some other ideas but, currently you can just use chromium-mpp
There seems to be some issue with hardware decoding not working with ffmpeg-rockchip when playing videos from youtube using mpv+yt-dlp. Local files do work and mpv+yt-dlp hardware decoding works with ffmpeg-mpp.
Did you check the wiki? You need to do flag mpv to use rkmpp qith new ffmpeg-rockchip. It should be few posts above.
Maybe consider adding a section on how to modify mpv.conf. Many users have become accustomed to the fact that rkmpp has higher priority than software decoder, but they don’t know that this is actually a hack.
i was just expecting someone from the community to come up with mpv.conf
