Yes, I have put the hwdec=rkmpp etc. flags to mpv.conf. The decoding just fails if trying to play youtube videos. And when using ffmpeg-mpp I have actually deprioritized the hardware codecs from ffmpeg-mpp source because they were giving problems with firefox, and using vd=h264_rkmpp_decoder… parameter to force their use with mpv, as for some reason using hwdec=rkmpp then with ffmpeg-mpp causes mpv to freeze at the end of the video, requiring killing it.
Lines from verbose log that seem to have some relevance to the issue:
[vd] Container reported FPS: 30.000000
[vd] Codec list:
[vd] h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
[vd] h264_v4l2m2m (h264) - V4L2 mem2mem H.264 decoder wrapper
[vd] h264_qsv (h264) - H264 video (Intel Quick Sync Video acceleration)
[vd] h264_rkmpp (h264) - Rockchip MPP (Media Process Platform) H264 decoder
[vd] Opening decoder h264
[vd] Looking at hwdec h264_rkmpp-rkmpp…
[vo/gpu] Loading hwdec drivers for format: ‘drm_prime’
[vo/gpu] Loading hwdec driver ‘drmprime’
[vo/gpu/drmprime] using EGL dmabuf interop
[vo/gpu/drmprime] Using DRM device: /dev/dri/renderD128
[ffmpeg] AVHWDeviceContext: Opened DRM device /dev/dri/renderD128: driver rockchip version 3.0.0.
[vo/gpu] Loading hwdec driver ‘drmprime-overlay’
[vo/gpu/drmprime-overlay] Failed to retrieve DRM fd from native display.
[vo/gpu] Loading failed.
[vd] Trying hardware decoding via h264_rkmpp-rkmpp.
[vd] Using underlying hw-decoder ‘h264_rkmpp’
[ffmpeg] h264_mp4toannexb: The input looks like it is Annex B already
[vd] Pixel formats supported by decoder: drm_prime nv12
[vd] Codec profile: Main (0x4d)
[vd] Hardware decoding of this stream is unsupported?
[vd] Requesting pixfmt ‘nv12’ from decoder.
[ffmpeg/video] h264_rkmpp: Format nv12 chosen by get_format().
[ffmpeg/video] h264_rkmpp: Created a RKMPP hardware device
[vd] Selected codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
[ffmpeg] detected 8 logical cores
[vf] User filter list:
[vf] scale_rkrga (scale_rkrga.00)
[cplayer] Starting playback…
[ffmpeg/video] h264_rkmpp: Decoder could not get packet, retrying
[ffmpeg/video] h264_rkmpp: Decoder flushing
[vd] Attempting next decoding method after failure of h264_rkmpp-rkmpp.
[vd] Skipping previously attempted hwdec: h264_rkmpp-rkmpp
[vd] Using software decoding.
Feb 12 20:14:25 alarm rtkit-daemon[782]: Supervising 0 threads of 0 processes of 0 users.
Feb 12 20:14:25 alarm rtkit-daemon[782]: Failed to look up client: No such file or directory
Feb 12 20:14:28 alarm kernel: mpp_rkvdec2 fdc48100.rkvdec-core: resetting...
Feb 12 20:14:28 alarm kernel: mpp_rkvdec2 fdc48100.rkvdec-core: reset done
Feb 12 20:14:28 alarm kernel: mpp_rkvdec2 fdc38100.rkvdec-core: resetting...
Feb 12 20:14:28 alarm kernel: mpp_rkvdec2 fdc38100.rkvdec-core: reset done
ffmpeg
[ffmpeg/video] vp9_rkmpp: Received a 'errinfo' frame
[ffmpeg/video] vp9_rkmpp: Decoder could not get packet, retrying
[ffmpeg/video] vp9_rkmpp: Wrote 2576 bytes to decoder
[ffmpeg/video] vp9_rkmpp: Wrote 2089 bytes to decoder
[ffmpeg/video] vp9_rkmpp: Wrote 2569 bytes to decoder
[ffmpeg/video] vp9_rkmpp: Decoder failed to get frame: -542398533
for the mpp issue i have downgraded the repos.
for the youtube case of mpv, it really looks like an mpv issue, however i think it would be beneficial to have such a workaround in PR@nyanmisaka
Chromium-mpp can be installled from binary repo, there is no need to install it from agr, it takes so much time to compole it, and there is no specific improvement in agr
It freezes to me on Ubuntu all the time too. Because it has been happening so often, I set up the keyboard shortcut to restart the plasmashell. I read somewhere that freezing plasmashell is quite common for years already.
I would like to know if there is any solution for this too.
