5x2 Pin Diagram?
Setting up a NAS with a RP5 and the Penta Sata Hat. I want to connect a 2 wire fan to the 5x2 header. I have the pin configuration listed here: https://wiki.radxa.com/Dual_Quad_SATA_HAT
But I don’t understand the orientation of the connector – and if it’s labeled, I can’t read it :slight_smile:
Are pins 1 and 2 at the edge of the board as I’ve guessed in this picture, or do I have it reversed?
If I have it right, I’m going to connect the red wire to pin 4 (5v) and the black to 9 (GND). Hopefully that’s the correct procedure. Thank you!
I have the same plan to connect extra fan to this board. But I thin on the board you have correct pinout printed.
pin
Thank you for verifying this! Fan is working great on mine!
I can confirm this! Piotr_L’s post confirms the correct orientation; I also used it to pass through for I2C control for a separate screen and it worked great!
I am trying to connect my 3 wires fan , 3 rd wire to control speed.
1- I have found the below PIN diagram for PI 4 SATA HAT , is it the same PIN output for PI 5 SATA HAT ?
2- I would need to buy a 2x5 female connector to connect my fan, what would the this connector specification ?
3 - Should I use PIN 8 PWM_33 for the 3rd wire to control the fan speed ?
Thank you.
I found out that in my Penta Hat board, the pin 8 that connects to PWM_33 is missing the 0 ohm resistor on the back.
Make sure that your board is connected. I spent a few hours trying to enable the fan PWM and nothing worked. I had to plug in an oscilloscope and a multitester to find out about that missing jumper.
