With support from radxa (received a sample board) I’ve started to add support for openwrt for the zero3e board
Test build https://oshi.at/tPRZ (90 days link)
Source code (dev tree) https://github.com/maurerr/openwrt/tree/radxa-zero3e
Any feedback is welcome
EDIT:
a “proper release” is on maurerr.github.io/radxa-zero3e with kernel modules and update to distfeeds.conf for those
for openwrt mainline we need u-boot support so I’ll request some help with that.
stay tuned
Hi @mariusd_ro , were you able to achieve your goal? Does WIFI AP work?
Thank you!
I only have zero3e and it doesn’t come with wifi
maybe @RadxaNaoki can help to answer about wifi AP
supporting wifi on 3W is planned but currently no ETA, sorry
(you may use USB wifi)
indy
February 4, 2025, 11:49am
6
so just gzip -dc radxa_zero-3e-ext4-sysupgrade.img.gz > /dev/mmcblk0?
indy
February 4, 2025, 3:53pm
7
cooool
root@OpenWrt:~# ethtool -T eth0
Time stamping parameters for eth0:
Capabilities:
hardware-transmit (SOF_TIMESTAMPING_TX_HARDWARE)
software-transmit (SOF_TIMESTAMPING_TX_SOFTWARE)
hardware-receive (SOF_TIMESTAMPING_RX_HARDWARE)
software-receive (SOF_TIMESTAMPING_RX_SOFTWARE)
software-system-clock (SOF_TIMESTAMPING_SOFTWARE)
hardware-raw-clock (SOF_TIMESTAMPING_RAW_HARDWARE)
PTP Hardware Clock: 0
Hardware Transmit Timestamp Modes:
off (HWTSTAMP_TX_OFF)
on (HWTSTAMP_TX_ON)
Hardware Receive Filter Modes:
none (HWTSTAMP_FILTER_NONE)
all (HWTSTAMP_FILTER_ALL)
ptpv1-l4-event (HWTSTAMP_FILTER_PTP_V1_L4_EVENT)
ptpv1-l4-sync (HWTSTAMP_FILTER_PTP_V1_L4_SYNC)
ptpv1-l4-delay-req (HWTSTAMP_FILTER_PTP_V1_L4_DELAY_REQ)
ptpv2-l4-event (HWTSTAMP_FILTER_PTP_V2_L4_EVENT)
ptpv2-l4-sync (HWTSTAMP_FILTER_PTP_V2_L4_SYNC)
ptpv2-l4-delay-req (HWTSTAMP_FILTER_PTP_V2_L4_DELAY_REQ)
ptpv2-event (HWTSTAMP_FILTER_PTP_V2_EVENT)
ptpv2-sync (HWTSTAMP_FILTER_PTP_V2_SYNC)
ptpv2-delay-req (HWTSTAMP_FILTER_PTP_V2_DELAY_REQ)
thanks
May I ask where did you run this command from? An external linux environment like Debian?
I keep having trouble flashing openwrt images to Zero 3E’s SD Card. I was using balenaEtcher at the beginning but the device won’t boot (solid green light; no ethernet connection seen from my router)
Somehow this does not work for me. I wonder what I have missed.
I have Debian running on my Zero 3E with SD Card 1 (mmcblk1)
radxa@radxa-zero3:~$ lsblk
mmcblk1 179:0 0 28.9G 0 disk
├─mmcblk1p1 179:1 0 16M 0 part /config
├─mmcblk1p2 179:2 0 300M 0 part /boot/efi
└─mmcblk1p3 179:3 0 28.5G 0 part /
zram0 254:0 0 489.6M 0 disk [SWAP]
openwrt-rockchip-armv8-radxa_zero-3e-ext4-sysupgrade.img.gz
Then I plug in SD Card 2 (sdb) using a card reader:
$ lsblk
sdb 8:16 1 59.5G 0 disk
├─sdb1 8:17 1 16M 0 part
├─sdb2 8:18 1 300M 0 part
└─sdb3 8:19 1 4.2G 0 part
And I used your command to flush the SD Card 2:
radxa@radxa-zero3:~$ sudo bash -c ‘gzip -dc openwrt-rockchip-armv8-radxa_zero-3e-ext4-sysupgrade.img.gz > /dev/sdb’
[sudo] password for radxa:
gzip: openwrt-rockchip-armv8-radxa_zero-3e-ext4-sysupgrade.img.gz: decompression OK, trailing garbage ignored
└─sdb2 8:18 1 104M 0 part
Finally I shutdown the device reboot from SD Card 2, but the device stuck on solid green light.
indy
April 25, 2025, 6:27am
12
i ignore diodes, i watch serial console
