I recently got a radxa Zero 1GB and installed the latest image: “radxa-zero-debian-buster-xfce4-arm64-20211121-0245-mbr.img”. Wifi lasts for a few hours and then breaks.
I’ve also tried the following with no luck:
rmmod brcmfmac
modprobe brcmfmac
Here is the log:
dmesg | grep brcmfmac
[ 8.246593] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[ 8.248750] brcmfmac: brcmf_of_probe: interrupt could not be mapped
[ 8.249712] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 8.259486] usbcore: registered new interface driver brcmfmac
[ 8.328938] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac43430-sdio.radxa,zero.txt failed with error -2
[ 8.590371] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 8.593628] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
[ 8.614313] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Mar 30 2016 11:30:56 version 7.45.77.h8.4 FWID 01-ee8a6268
Updated to: radxa-zero-debian-buster-xfce4-arm64-20220602-0403-mbr
Same issue.
[ 8.175325] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[ 8.210681] brcmfmac: brcmf_of_probe: interrupt could not be mapped
[ 8.214937] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 8.224191] usbcore: registered new interface driver brcmfmac
[ 8.309763] brcmfmac mmc0:0001:1: Direct firmware load for brcm/brcmfmac43430-sdio.radxa,zero.txt failed with error -2
[ 8.598930] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 8.602211] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
[ 8.623013] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Mar 30 2016 11:30:56 version 7.45.77.h8.4 FWID 01-ee8a6268
I don’t have the 1GB model, nor do I have that specific year firmware 2016, but I do have what I believe should work on my github. You are more than welcome to test it: git clone -b radxa https://github.com/pyavitz/firmware.git
Make sure to backup the current firmware you have in place before over writing it. sudo cp -r /lib/firmware/brcm /lib/firmware/brcm.orig
So interestingly enough, turning off wifi powersave seems to have solved the issue. The error is still there, but slightly different after adding the file it was looking for.
[ 8.390839] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[ 8.397722] brcmfmac: brcmf_of_probe: interrupt could not be mapped
[ 8.408380] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 8.423731] usbcore: registered new interface driver brcmfmac
[ 8.779502] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 8.790885] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
[ 8.817190] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Mar 30 2016 11:30:56 version 7.45.77.h8.4 FWID 01-ee8a6268
From what I recall the clm_blob is supposed to be inside the bin file, so that it strange.
