Zero no longer boots eMMC / SD Card
Hi I have a couple of zeros with eMMC, and using, but one of them suddenly no longer boots.
The MASKROM mode seems working as I could use the RZ_USB_Boot_Helper_V1.0.0 tool to flash the *.bin file into it. However, either the erase bin or the udisk bin won’t work. Won’t work in the sense that no USB storage device is discovered after the flash.
To verify further, I flashed a SD card ubunter server image to plug in. It doesn’t boot as well. The green LED is on.
What could be the possible cause here? In the meanwhile, I am trying to attached a serial and put my output here.
Here is the serial output once pluged-in, with SD card mounted.
G12A:BL:0253b8:61aa2d;FEAT:E0F83180:2000;POC:F;RCY:0;EMMC:0;READ:0;0.0
        bl2_stage_init 0x01
bl2_stage_init 0x81
hw id: 0x0001 - pwm id 0x00
bl2_stage_init 0xc0
bl2_stage_init 0x02
L0:00000000
L1:00000703
L2:00008067
L3:04000000
S1:00000000
B2:00002000
B1:e0f83180
TE: 136776
Board ID = 2
Set cpu clk to 24M
Set clk81 to 24M
CPU clk: 1200 MHz
Set clk81 to 166.6M
eMMC boot @ 0
sw8 s
board id: 2
Load FIP HDR from eMMC, src: 0x00010200, des: 0xfffd0000, size: 0x00004000, part: 0
fw parse done
Load ddrfw from eMMC, src: 0x00060200, des: 0xfffd0000, size: 0x0000c000, part: 0
Load ddrfw from eMMC, src: 0x00038200, des: 0xfffd0000, size: 0x00004000, part: 0
PIEI prepare done
fastboot data load
00000000
emmc switch 1 ok
00000000
emmc switch 2 ok
fastboot data verify
verify result: 265
LPDDR4 probe
ddr clk to 792MHz
Load ddrfw from eMMC, src: 0x0003c200, des: 0xfffd0000, size: 0x0000c000, part: 0
00000000
emmc switch 0 ok
dmc_version 0000
Check phy result
INFO : End of CA training
INFO : End of initialization
Check phy result
1D training failed
LPDDR4 probe
ddr clk to 792MHz
dmc_version 0000
Check phy result
Check phy result
1D training failed
All ddr config failed...
Reset...
boot times 0G12A:BL:0253b8:61aa2d;FEAT:E0F83180:2000;POC:F;RCY:0;EMMC:0;READ:0;0.0
        l2_stage_init 0x01
bl2_stage_init 0x81
bl2_stage_init 0xc0
bl2_stage_init 0x02
L0:00000000
L1:00000703
L2:00008067
L3:04000000
S1:00000000
B2:00002000
B1:e0f83180
TE: 134817
Board ID = 2
Set cpu clk to 24M
Set clk81 to 24M
CPU clk: 1200 MHz
Set clk81 to 166.6M
eMMC boot @ 0
sw8 s
board id: 2
fw parse done
PIEI prepare done
fastboot data load
00000000
emmc switch 1 ok
00000000
emmc switch 2 ok
verify result: 265
LPDDR4 probe
ddr clk to 792MHz
00000000
emmc switch 0 ok
dmc_version 0000
Check phy result
Check phy result
1D training failed
LPDDR4 probe
ddr clk to 792MHz
dmc_version 0000
Check phy result
Check phy result
1D training failed
Reset...
        l2_stage_init 0x01
bl2_stage_init 0x81
bl2_stage_init 0xc0
bl2_stage_init 0x02
L0:00000000
L1:00000703
L2:00008067
L3:04000000
S1:00000000
B2:00002000
B1:e0f83180
TE: 134834
Board ID = 2
Set cpu clk to 24M
Set clk81 to 24M
CPU clk: 1200 MHz
Set clk81 to 166.6M
eMMC boot @ 0
sw8 s
board id: 2
fw parse done
PIEI prepare done
fastboot data load
00000000
emmc switch 1 ok
00000000
emmc switch 2 ok
verify result: 265
LPDDR4 probe
ddr clk to 792MHz
00000000
emmc switch 0 ok
dmc_version 0000
Check phy result
Check phy result
1D training failed
LPDDR4 probe
ddr clk to 792MHz
dmc_version 0000
Check phy result
Check phy result
1D training failed
Reset...
boot times 0
Your board might have some hardware problem. Can you take pictures on both side of your board so we can have some visual examination?
OK I didn’t see any major part missing, which could happen to the naked board. Can you try loading Android bootloader and send the serial log? This one has a different memory training profile, and will show up as a fastboot device if the bootloader can load successfully.
Got the two units back and checked,
NO. 04: CPU is burnt, replaced a S905Y2, the board is fully functional now.
