Zero Fails to boot up
My Zero 2GB would sometimes fails to boot up into kernel, but enters uboot.
Seems fails to find mmc partitions.
The failure rate is like 1/20times.
UART LOG attached here,
U-Boot 2021.07-24129-g105a2deb65 (Dec 14 2021 - 14:20:39 +0800) radxa-zero
Model: Radxa Zero
SoC: Amlogic Meson G12A (S905Y2) Revision 28:c (30:2)
DRAM: 2 GiB
MMC: sd@ffe03000: 0, sd@ffe05000: 1, mmc@ffe07000: 2
Loading Environment from nowhere… OK
In: serial
Out: serial
Err: serial
Net: Net Initialization Skipped
No ethernet found.
switch to partitions #0, OK
mmc2(part 0) is current device
Scanning mmc 2:1…
Found U-Boot script /boot.scr
** No partition table - mmc 2 **
Couldn’t find partition mmc 2:1
Can’t set block device
Executing script at 08000000
Wrong image format for “source” command
SCRIPT FAILED: continuing…
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
Scanning disk [email protected]
Disk [email protected] not ready
** fs_devread read error - block
Failed to mount ext2 filesystem…
** Unrecognized filesystem type **
Found 1 disks
No EFI system partition
BootOrder not defined
EFI boot manager: Cannot load any image
starting USB…
Starting the controller
USB XHCI 1.10
scanning bus usb@ff500000 for devices… 9 USB Device(s) found
scanning usb for storage devices… 0 Storage Device(s) found
Device 0: unknown device
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-meson-u200
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
No ethernet found.
This is a known issue that’s been fixed in the Radxa uboot fork. I’m not sure if which prebuilt images it’s made its way into at this point, but you can build it yourself with the instructions in the wiki: https://wiki.radxa.com/Zero/dev/u-boot
Note though that there is an error in step 3. The first command in step 3 should be:
export CROSS_COMPILE=/opt/gcc-arm-10.3-2021.07-x86_64-aarch64-none-elf/bin/aarch64-none-elf-
Yeah we fixed it in June. Download the latest image please.
