Just received my Zero 3W w. 4GB RAM and 32GB eMMC.
On my Windows machine:
Installed the drivers
Installed RKDevTool
Held the maskrom button while inserting my USB-C to USB-A into my computer
Light on Zero3 W is solid green
Device is found in RKDevTool
Specified:
rk356x_spl_loader_ddr1056_v1.12.109_no_check_todly.binrk356x_spl_loader_ddr1056_v1.12.109_no_check_todly.bin for “Loader”
and
radxa-zero3_debian_bullseye_xfce_b6.img for “Image”
Changed the “Storage” for “Image” to “eMMC”
Note that this screenshot is taken AFTER I’ve removed my Zero 3W, that is why it says "No Devices Found".
Tried three USB-A (2* USB 3.X and 1* USB 2.0) ports and one USB-C port (using a USB-C to USB-C cable) and receive the same error when trying to upload the OS.
On my Mac machine:
Compiled rkdeveloptool as per instructions
sudo rkdeveloptool db <path-to-spl_loader> returns:
Downloading bootloader succeded.
Yes I followed the instructions .
I did all the steps I outlined in my previous post, if I missed / misunderstood something then please point it out because I don’t believe I did.
I’m using a 5V/3A PSU and have connected the USB-C to USB-C cable to the USB 2.0 OTG-port.
I used the radxa-zero3_debian_bullseye_xfce_b6.img and Etcher to burn it to a good quality (SanDisk Ultra mSDHC 32GB) SD-card.
I can confirm InfiniteBSOD sution is the correct one.
I tried v2.96, and it doesn’t seem to work.
I imagine it has to do with the “storage” column. I set it to emmc, but it doesn’t work
