ZERO 3W suddenly stopped booting – solid green LED, no MASKROM detected
My Radxa ZERO 3W suddenly stopped booting and I’m unable to enter MASKROM mode.
The board was working normally before this happened and was running Android from the onboard eMMC. The microSD card was not being used.
After the failure:
  • Solid green LED when powered on
  • Android from eMMC no longer boots
  • A microSD card that was known to be working before the failure also no longer boots
  • Board powers on when connected through the USB-C OTG/data port
  • Windows makes the USB connect sound and Device Manager refreshes when I connect it
  • However, RKDevTool does not detect the board
  • rkdeveloptool on Linux also does not detect anything
  • I also tried macOS Rockchip tools with no device detected
  • Tried the onboard MASKROM button
  • Tried manually grounding the MASKROM contacts
  • Neither method makes the board appear as a MASKROM device
The important point is that the SD card was working previously, and it was not involved in the original failure. The board was booting Android from eMMC when it suddenly stopped.
So currently the board is essentially:
Power on → solid green LED → no boot from eMMC → no boot from previously working SD card → no MASKROM enumeration
Since Windows does react to the USB connection, I’m wondering whether the RK3566 is partially responding but failing to enumerate as MASKROM, or whether this could be a hardware/power/eMMC issue.
Could someone from Radxa please advise:
  1. What does a solid green LED indicate on ZERO 3W in this situation?
  2. Should the RK3566 BootROM always enumerate as MASKROM even if the eMMC is corrupted?
  3. Is there another way to force/check MASKROM mode besides the button/contact?
  4. Are there any test points or voltage rails I should measure to determine whether the RK3566 is actually starting?
  5. Could a failed eMMC prevent MASKROM and also explain why the SD card suddenly stopped booting?
  6. Is there any recovery method if USB MASKROM is not enumerating?
Any guidance on determining whether this is a bootloader/eMMC problem or an actual hardware failure would be greatly appreciated.
