I used this instruction Camera | Radxa Docs
Got dark green picture with freezes (seems it has about 5-10 fps with resolution 1920 1080)
What i did wrong? And how i can make it work properly?
What camera are you using? Can you take a photo to see what camera you are using?
I use raspberry pi camera v2.1 with imx219 sensor
https://sl.aliexpress.ru/p?key=68pyOdx
Maybe i need another camera, that works fine by default with radxa zero 3w?
We have tested the IMX219 camera. Can you try previewing it with cheese?
cheese doesn’t work
gst-launch-1.0 v4l2src device=/dev/video0 io-mode=4 ! videoconvert ! video/x-raw,format=NV12,width=1920,height=1080 ! jpegenc ! multifilesink location=/home/radxa/test.jpg
these command works
Looks like the ISP is not working, you can run rkaiq_3A_server before run gst-launch.
Which image are you using?
Hello, have you solved this issue? I’m encountering the same problem
