Zero 3W not saw in Mask rom mode after first Flash
I flashed a file, I have no idea of knowing what I flashed now, but Since then the device when In for sure in maskrom mode, (hold the button and connect a cable that works with my other Radxa device zero 2 pro and that is seen as mask rom)
its not seen in Windows, with the correct drivers installed its seen as that GFX or whatever i is supposed to display as (the zero 2 pro shows up)
Initially I used mac os connand line to get the images flashed,
long story short it seems like its bricked.
I connected it to a usb lan connector that works for the zero 2 pro and its not saw by my router, sd card with the correct linux distro on it is not saw and the device (zero 2w) is not outputting an image.
how do I recover the functionality of the device back.
ive never has an issue lie this and it might be something common. tahnks yoooouuu
In windows procedure provided by radxa was unclear for me I fixed similar problem using linux procedure instead
summary:
./upgrade_tool ld
sudo ./upgrade_tool db
sudo ./upgrade_tool wl 0
