Hello, I cannot load any of the two Armbian OS images (24.8 xfce, 25.2 minimum) into Radxa Zero 3W using RkDevelopTool and rk356x_spl_loader_ddr1056_v1.12.109_no_check_todly.bin bootloader.
The whole process runs until “Start to download C:\Users\Public\Downloads\radxa\images\Armbian_24.8.1_Radxa-zero3_bookworm_vendor_6.1.75_xfce_desktop.img” (or another image, included the bullseye Debian recommended by Radxa) and after some timeout it ends with “Download image failed”.
In the meantime I successfully loaded bullseye into another Radxa Zero 3W, but it needed 20+ attempts. The underlying operating system is Win 10 Pro 22H2.
Before my attempt to upload OS into eMMC neither of the two boards booted, they just blinked with the green LED and nothing happened, no output to HDMI display at all.
Hi Jindrich
Is it possible to boot from SD card properly?
You can try this version of RKDevTool:
https://dl.radxa.com/tools/windows/RKDevTool_Release_v2.86.zip
Note that you need to extract the image file to .img format when burning with RKDevTool.
It did not boot at all. Today, almost a year after, I was able to boot armbian from SD. Unfortunately there is another problem. When Armbian runs for the first time from SD, it ends asking “create password for root”. But at this moment keyboard does not work (driver not loaded?). After disconnecting power and reconnecting, armbian starts and asks for login. Now the keyboard works. But I was unable to set up root password, so I cannot login. Catch 22…
Is it possible to boot armbian so that root login happens automatically and fix that later?
v2.86 has different controls and does not work at all. I cannot find any guide how to flash the image with v2.86. No docs, no use…
