Zero 3E LAN Not Working
I have been using ubuntu armbian for my image to my radxa zero 3e and it’s been working very good until yesterday.
I think it happens after linux updates that when I restarted the unit it then failed to boot. The device only turns on green LED without blinking.
After much troubleshooting I came to conclusion that it cannot boot because of the ubuntu system on the sd card is faulty.
I then flashed a new image which was armbian server debian edition and can boot back the system.
But now I have problem with my LAN. There’s no ethernet interface when I use command “ip a”.
I thought it’s a debian problem so I flashed it again with armbian ubuntu.
Sadly the problem persists.
When I clicked on the wired LAN switch on the quick access at the top right of ubuntu gnome, an error comes out saying there’s a problem.
So does my ethernet port on my radxa zero 3e dead already?
