X-Server does not start
I’ve just testet Armbian_23.02.0-trunk_Rock-5b_jammy_legacy_5.10.110_kde-plasma_desktop.img.xz
from https://github.com/Headcrabed/armbian-rock5b-images/releases/tag/20230102-0848.
System boots up, but no X-server is starting.
root@rock-5b:~# cat /var/log/Xorg.0.log
[ 8.693] (–) Log file renamed from “/var/log/Xorg.pid-1245.log” to “/var/log/Xorg.0.log”
[ 8.694]
X.Org X Server 1.21.1.3
X Protocol Version 11, Revision 0
[ 8.694] Current Operating System: Linux rock-5b 5.10.110-rockchip-rk3588 #trunk SMP Mon Jan 2 10:10:28 UTC 2023 aarch64
[ 8.694] Kernel command line: root=UUID=690124a5-36f0-4f37-b780-5500a355332d rootwait rootfstype=ext4 splash plymouth.ignore-serial-consoles console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart= usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
[ 8.695] xorg-server 2:21.1.3-2ubuntu2.5 (For technical support please see http://www.ubuntu.com/support)
[ 8.695] Current version of pixman: 0.40.0
[ 8.695] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 8.695] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 8.695] (==) Log file: “/var/log/Xorg.0.log”, Time: Thu Jan 19 18:59:17 2023
[ 8.696] (==) Using config directory: “/etc/X11/xorg.conf.d”
[ 8.696] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 8.696] (==) No Layout section. Using the first Screen section.
[ 8.697] (==) No screen section available. Using defaults.
[ 8.697] (
) |–>Screen “Default Screen Section” (0)
[ 8.697] (**) | |–>Monitor “”
[ 8.697] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[ 8.697] (==) Automatically adding devices
[ 8.697] (==) Automatically enabling devices
[ 8.697] (==) Automatically adding GPU devices
[ 8.697] (==) Automatically binding GPU devices
[ 8.697] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 8.699] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 8.699] Entry deleted from font path.
[ 8.701] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/100dpi/:unscaled,
/usr/share/fonts/X11/75dpi/:unscaled,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 8.701] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 8.701] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 8.701] (II) Loader magic: 0x55782ad010
[ 8.701] (II) Module ABI versions:
[ 8.701] X.Org ANSI C Emulation: 0.4
[ 8.701] X.Org Video Driver: 25.2
[ 8.701] X.Org XInput driver : 24.4
[ 8.701] X.Org Server Extension : 10.0
[ 8.702] (++) using VT number 1
[ 8.702] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 8.705] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 8.705] (II) Platform probe for /sys/devices/platform/display-subsystem/drm/card0
[ 8.719] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 8.719] (II) Platform probe for /sys/devices/platform/fdab0000.npu/drm/card1
[ 8.722] (II) no primary bus or device found
[ 8.722] falling back to /sys/devices/platform/display-subsystem/drm/card0
[ 8.722] (II) LoadModule: “glx”
[ 8.723] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 8.730] (II) Module glx: vendor=“X.Org Foundation”
[ 8.730] compiled for 1.21.1.3, module version = 1.0.0
[ 8.730] ABI class: X.Org Server Extension, version 10.0
[ 8.730] (==) Matched modesetting as autoconfigured driver 0
[ 8.730] (==) Matched fbdev as autoconfigured driver 1
[ 8.730] (==) Assigned the driver to the xf86ConfigLayout
[ 8.731] (II) LoadModule: “modesetting”
[ 8.731] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 8.732] (II) Module modesetting: vendor=“X.Org Foundation”
[ 8.732] compiled for 1.21.1.3, module version = 1.21.1
[ 8.732] Module class: X.Org Video Driver
[ 8.732] ABI class: X.Org Video Driver, version 25.2
[ 8.732] (II) LoadModule: “fbdev”
[ 8.733] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 8.733] (II) Module fbdev: vendor=“X.Org Foundation”
[ 8.733] compiled for 1.21.1.3, module version = 0.5.0
[ 8.733] Module class: X.Org Video Driver
[ 8.733] ABI class: X.Org Video Driver, version 25.2
[ 8.733] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 8.733] (II) FBDEV: driver for framebuffer: fbdev
[ 8.735] (II) modeset(0): using drv /dev/dri/card0
[ 8.735] (WW) Falling back to old probe method for fbdev
[ 8.735] (II) Loading sub module “fbdevhw”
[ 8.735] (II) LoadModule: “fbdevhw”
[ 8.735] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 8.735] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 8.735] compiled for 1.21.1.3, module version = 0.0.2
[ 8.736] ABI class: X.Org Video Driver, version 25.2
[ 8.736] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 8.736] (II) modeset(0): Creating default Display subsection in Screen section
“Default Screen Section” for depth/fbbpp 24/32
[ 8.736] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 8.736] (==) modeset(0): RGB weight 888
[ 8.736] (==) modeset(0): Default visual is TrueColor
[ 8.736] (II) Loading sub module “glamoregl”
[ 8.736] (II) LoadModule: “glamoregl”
[ 8.736] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 8.750] (II) Module glamoregl: vendor=“X.Org Foundation”
[ 8.750] compiled for 1.21.1.3, module version = 1.0.1
[ 8.750] ABI class: X.Org ANSI C Emulation, version 0.4
[ 10.005] (EE)
[ 10.005] (EE) Backtrace:
[ 10.009] (EE) 0: /usr/lib/xorg/Xorg (OsLookupColor+0x188) [0x557820c928]
[ 10.010] (EE) unw_get_proc_info failed: no unwind info found [-10]
[ 10.010] (EE)
[ 10.010] (EE)
Fatal server error:
[ 10.010] (EE) Caught signal 6 (Aborted). Server aborting
[ 10.010] (EE)
[ 10.010] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 10.010] (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
[ 10.010] (EE)
[ 10.035] (EE) Server terminated with error (1). Closing log file.
root@rock-5b:~#
Any tips to resolve this ?
Greetings
Andreas
Official Armbian releases are available here, and nightly test images of Armbian can be downloaded here.
The one you’ve downloaded is some custom-made stuff, please ask the person who made it.
Exactly - Armbian is free to use, get build or build yourself, but they won’t waste their time for custom build with some changes that can introduce any bugs. @linuxfriend - if your out of official release channel then you are on your own, maybe person who compiled that build may support You.
