Just got my RZ v1.51 yesterday and started messing around with it. here’s what I have done so far
- I got the lsusb drivers to install on windows, and got the RZ to start as USB boot mode
- successfully ran the USB Boot Helper in maskrom mode.
- Ran the radxa-zero-erase-emmc.bin file and the rz-udisk-loader.bin file to get the RZ to be recognized as a USB drive
- Flashed dietpi to the emmc
- Booted with no sdcard
- Got Nothing.
- Figured maybe the flash was bad, so repeated step (3).
- Here’s where things are weird, the emmc did not get wiped, when the RZ came back up as a USB drive, all the dietpi files were still there.
Is that normal? Any advice on how to actually clear the emmc?
After loading radxa-zero-erase-emmc.bin you do not need to load rz-udisk-loader.bin. radxa-zero-erase-emmc.bin will expose eMMC as a USB storage device by itself. It will take a while before the eMMC is wiped and recognized by the host computer, so if you interrupt that process and load rz-udisk-loader.bin, you will not erase your eMMC.
If you still have issues please send the serial log.
Thanks for the reply. I tried it again and gave it 4 hours for a 8GB emmc, and it still hasn’t re-connected as a USB storage device. How long does it take?
Well 10 seconds maximum… We were actually just wiping the partition table from eMMC so it was very quick. At this point I need the serial log before I can tell what was wrong and it is likely to be a hardware issue.
