windows环境下烧写安卓系统到SD卡缺少指导
根据5b的安装页面信息第三步将U-Boot烧写进SD卡,此步骤目前只有mac和linux环境的方法,并无windows环境下的。
我尝试只将安卓镜像烧写进microSD卡,并放入5B,开机会一直卡在安卓的logo界面。
当我使用eMMC烧写时则可以顺利进入安卓。
sorry that i cant reply in chineese but i think i have a solution:
if the sd card and your emmc has the same size then just copy the emmc to the sd with balena etcher
but if the sd is larger than the emmc copy it and then enlarge it with the windows drive management utility
if the sd is smaller than the emmc then i have no solution
chineese throug google translate:
对不起,我不能用中文回复,但我想我有一个解决方案:
如果 sd 卡和您的 emmc 大小相同,则只需使用 balena 蚀刻机将 emmc 复制到 sd
但如果 sd 大于 emmc 则复制它,然后使用 windows 驱动器管理实用程序将其放大
如果 sd 小于 emmc 那么我没有解决方案
i hope it isnt too bad the google translator chineese
:smile:
Thanks for your reply, but at the moment this solution is not for me because I don’t have an eMMC2usb card reader. So I still hope that the official personnel can update the doc under the Windows system, because I found that not only me, many people have encountered the problem that android cannot enter the system after burning the SD card.
ok i thougt you have an emmc2usb / emmc2sd
but i hope someone could help
RKTools,好像可以直接写镜像到emmc上面,可以尝试以下
我把系统通过rktools写入到eMMC了,也成功进入安卓了。只是看到这个sd卡没windows的方法所以写个帖子
还有一种方式,rock运行linux系统,然后通过dd命令,我通过这个方式将linux和android系统烧录到内存卡种的
rufus可以直接写入,之前的版本写入直接能用
