Windows on ARM Hyper V support
I want to install Hyper V in WOA, but it fails because it’s missing some support.
If I run systeminfo it shows this result:
Hyper-V Requirements: VM Monitor Mode Extensions: Yes
Virtualization Enabled In Firmware: No
Second Level Address Translation: No
Data Execution Prevention Available: Yes
When I search on SLAT for ARM I found this Wikipedia url:
“ARM’s virtualization extensions support SLAT, known as Stage-2 page-tables provided by a Stage-2 MMU. The guest uses the Stage-1 MMU. Support was added as optional in the ARMv7ve architecture and is also supported in the ARMv8 (32-bit and 64-bit) architectures.”
@RadxaYuntian Has CIX implemented this?
CIX is in contact with Microsoft regarding platform support. It should be something they are working on.
