Win 10, No audio devices found
I got my new X today! The 4GB/64GB version. I installed Win10 on it, and am currently showing that there’s no audio devices found.
When you tested it, what driver did it use?
Thanks!
Hi.
All should be found here. https://wiki.radxa.com/RockpiX/downloads
Otherwise these should work too. https://www.digital-loggers.com/downloads/api/AtomicPi_full_drivers_May_2019_Win10_x64.zip
Thanks for the links! I knew they were brought up in an earlier thread somewhere.
Btw, you will need also to reinstall one of the sound device (the one that not Intel) with driver from https://wiki.radxa.com/RockpiX/downloads to get 3.5 jack to work, because Windows install incorrect driver by default
The only driver that seems relevant says Intel SST Audio Device (WDM). Is that it, or if ‘the one not Intel’, which driver should I use?
check Nuvoton SST Nau88L24 Codec Device
