I think there is some miss match is the firmware provided while the chip on board.
Let me check
If this module is part of zero image.
Let me check
Thanks in advance, I’m quite qurious ! …
By thje way: brcmfmac43455 failed in dmesg message is also present on my current Armbian 24.2.1 Bookworm CLI setup on radxa and wifi is working here buttersmooth with no issues.
So the problem is somewhere else, but not in brcmfmac43455 …
I cannot even boot using this image.
Idk if my device have sdcard slot problem or something else.
Plus my sample unit is early prototype version with V1.51 printed.
Let me check with Radxa team.
Most of images I installed on built in eMMC drive
And yes - a lot of them refuse to start if I put them on SD card.
Just tested today again:
https://github.com/manjaro-arm/radxa-zero-images/releases/download/23.02/Manjaro-ARM-minimal-radxa-zero-23.02.img.xz
That failed to start from SD but was ok on eMMC
Wifi not working
https://github.com/manjaro-arm/radxa-zero-images/releases/download/23.02/Manjaro-ARM-gnome-radxa-zero-23.02.img.xz
OK on SD card
Wifi not working
https://github.com/manjaro-arm/radxa-zero-images/releases/download/23.02/Manjaro-ARM-xfce-radxa-zero-23.02.img.xz
That one I succeded to install on SD card and on emmc
Wifi not working:
nmcli dev
DEVICE TYPE STATE CONNECTION
lo loopback unmanaged –
nmcli radio
WIFI-HW WIFI WWAN-HW WWAN
missing enabled missing enabled
here in zip - output from inxi verbose and dmesg commands
4.zip (16.6 KB)
I also started thread on manjaro forum:
[ 8.966248] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.radxa,zero.bin failed with error -2
[ 8.966371] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.bin failed with error -2
[ 9.368259] Bluetooth: hci0: BCM: firmware Patch file not found, tried:
[ 9.369242] Bluetooth: hci0: BCM: 'brcm/BCM4345C0.radxa,zero.hcd'
[ 9.375546] Bluetooth: hci0: BCM: 'brcm/BCM4345C0.hcd'
Just download the missing “brcmfmac43455-sdio.bin” (and matching nvram .txt) and “BCM4345C0.hcd” files. You’ll find them all in here: https://github.com/LibreELEC/brcmfmac_sdio-firmware. Put them in /usr/lib/firmware/brcm/and reboot.
Working, Thanks !
