uname -a
and ls -la /usr/lib/firmware/brcm/ | grep radxa
I want to know which kernel is installed. The wifi firmware is already installed on the default image but from the screenshot it looks like it is failing to load or file not present.
Did you tried any other images? Maybe your board wifi module damaged? Because many people uses that image and there is not any other same problem. I use exactly same image on uSD without any problem.
I feel like this problem is not about Manjaro but its about zero.
I have 2 boards in total. My first zero works great and there is no problem with wifi or anything.
I have the latest release of manjaro installed.
i got the second board yesterday and im dealing with wifi problem. I came to conclusion that its not the problem with the OS but it is with the zero board.
what doesnt makes sense to me is;
1st board > 4GB 64GB eMMC
2nd board > 4GB 128GB eMMC
I’ve checked the hardware on wiki and both uses same module
I wonder if they changed any firmware or any other setting / setup on the board ? its very much frustrating to deal with these problems in OS environment while the problem might exist on hardware…
