When I follow the instructions to check the wifi I am unable to see any networks available after a scan. I see the hardware is enabled but then after a scan nothing happens.
I have a small antenna attached 2.4 and 5.0 ghz capable.
Also I had issues with the ssh early on and was unable to ssh over uart 2 and found uart 0 to be capable instead. However while trying uart 2 I tried different usb to ttl cables and of course tried a 5V without looking. So I’m not sure how to see if I damaged the wifi module by attempting to transmit a 5V signal over uart 2 receive pin.
Is anyone else having issues with wifi/ble and are there any troubleshooting tips for wifi/ble? I am on the V1.1 hardware using the debian image provided by radxa.
Are you using rockpis-debian-190806 image?If you using this image it’s debug uart is uart2 on default.
You can use sudo ifconfig to see is it have wlan0 device,PiS has some bug about WiFi now, sometimes you need to reboot it to use WiFi properly,we will fix it as soon as possible.
Uart0 debug console were used by old image,in new image we change it to uart2.
You can reference Rock Pi S Serial Console to configuring on your PC,the cable connect like this:
Oh I see I thought I was on hardware version v11 not v10. Thank you I am still unable to get wifi at the moment but will try to reflash the sd again. Thank you again for the help
Ok I am still not seeing wifi. Wlan0 does not show in ifconfig only eth0 and lo. I am on hardware v11 using latest image 20200315. I am getting the following output for launching the wifi driver on boot,
[ 5.106631] =======================================================
[ 5.106641] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 5.106649] =======================================================
[ 5.106659] Realtek 8723DS SDIO WiFi driver (Powered by Rockchip,Ver v5.6.5_31752.20181221_COEX20181130-2e2e) init.
[ 5.106670] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 5.106680] [WLAN_RFKILL]: wifi turn on power. -1
[ 5.106690] mmc2:mmc host rescan start!
[ OK ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
Starting Update UTMP about System Boot/Shutdown…
Starting Network Time Synchronization…
[ OK ] Reached target Sound Card.
Starting Load/Save RF Kill Switch Status…
[ 5.217902] [BT_RFKILL]: rfkill_rk_set_power: set bt wake_host pin output high!
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ 5.289405] [BT_RFKILL]: rfkill_rk_set_power: set bt wake_host pin input!
[ 5.289466] [BT_RFKILL]: ENABLE UART_RTS
[ 5.393360] [BT_RFKILL]: DISABLE UART_RTS
[ 5.393529] [BT_RFKILL]: bt turn on power
[ OK ] Started Load/Save RF Kill Switch Status.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Initialization.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting Bluetooth service…
Starting Install HCI UART Module…
[ OK ] Started D-Bus System Message Bus.
Starting WPA supplicant…
Starting Login Service…
Starting Network Manager…
[ OK ] Reached target System Time Synchronized.
[ OK ] Started Daily apt download activities.
[ OK ] Started Daily apt upgrade and clean activities.
[ OK ] Reached target Timers.
[ 5.651986] Bluetooth: HCI UART driver ver 2.2.d448471.20190215-141136
[ 5.652088] Bluetooth: HCI H4 protocol initialized
[ 5.652291] Bluetooth: HCI Realtek H5 protocol initialized
[ 5.652502] rtk_btcoex: rtk_btcoex_init: version: 1.2
[ 5.652711] rtk_btcoex: create workqueue
[ 5.652923] rtk_btcoex: Coex over UDP
[ 5.653655] rtk_btcoex: alloc buffers 1792, 2432 for ev and l2
[ 6.105321] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 6.143378] ====>_BlockWrite 105 i:0
[ 6.143419] ====>_WriteFW 233
[ 6.143590] ====>_BlockWrite 105 i:0
[ 6.143606] ====>_WriteFW 233
[ 6.145643] systemd-journald[205]: Failed to read journal file /var/log/journal/2ecd64108b2f4a3d97ac9d8af3f306bd/user-1000.journal for rotation, trying to move it out of the way: Device or resource busy
[ OK ] Started Login Service.
[ OK ] Started Install HCI UART Module.
[ OK ] Started Bluetooth service.
[ OK ] Started WPA supplicant.
Starting Load RTL8723DS Bluetooth firmware…
[ 6.361022] [BT_RFKILL]: rfkill_rk_set_power: set bt wake_host pin output high!
Starting Hostname Service…
[ 6.437285] [BT_RFKILL]: rfkill_rk_set_power: set bt wake_host pin input!
[ 6.437347] [BT_RFKILL]: ENABLE UART_RTS
[ 6.541249] [BT_RFKILL]: DISABLE UART_RTS
[ 6.541360] [BT_RFKILL]: bt turn on power
[ OK ] Started Load RTL8723DS Bluetooth firmware.
[ OK ] Started Hostname Service.
[ OK ] Started Network Manager.
[ OK ] Reached target Network.
Starting OpenBSD Secure Shell server…
Starting Rockchip adb…
Starting Permit User Sessions…
Starting /etc/rc.local Compatibility…
[ OK ] Started /etc/rc.local Compatibility.
[ OK ] Started Permit User Sessions.
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyFIQ0.
[ OK ] Reached target Login Prompts.
Starting Network Manager Script Dispatcher Service…
[ 6.993095] file system registered
[ OK ] Started Network Manager Script Dispatcher Service.
[ 7.119163] read descriptors
[ 7.119224] read strings
[ OK ] Started OpenBSD Secure Shell server.
[ 7.275473] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.283538] Bluetooth: h5_open
[ 7.283578] Bluetooth: hci_uart_register_dev
[ 7.286839] rtk_btcoex: Open BTCOEX
[ 7.286885] rtk_btcoex: create_udpsocket: connect_port: 30001
[ 7.286939] rtk_btcoex: send msg INVITE_REQ with len:11
Starting Authorization Manager…
[ OK ] Reached target Bluetooth.
[ 7.409324] Bluetooth: Out-of-order packet arrived, got 7 expected 0
[ OK ] Started Authorization Manager.
[ 7.533294] Bluetooth: hu ffffffc01902f700 retransmitting 1 pkts
[ 7.535541] rtk_btcoex: BTCOEX hci_rev 0xaa7b
[ 7.535595] rtk_btcoex: BTCOEX lmp_subver 0x5645
[ 8.113289] dwc2 ff400000.usb: bound driver configfs-gadget
[ OK ] Started Rockchip adb.
[ OK ] Reached target Multi-User System.
[ OK ] Reached target Graphical Interface.
Starting Update UTMP about System Runlevel Changes…
[ OK ] Started Update UTMP about System Runlevel Changes.
[ 8.207161] tty_port_close_start: tty->count = 1 port count = 2.
is there any plans to support later kernels like 5.8 or higher. These newer realtek parts are much better supported in newer kernels. Right now wifi and bt are useless on Rockpi s.
