Hey there,
since days Im trying to get wifi & BT to work.
First I tried some official images Armbian_22.11.1_Rockpi-4cplus_jammy_current_5.15.80_xfce_desktop.img & with all of them I got a Blackscreen after the Logo. (all settings were made)
Then I a tried a pre-release so I could finally get into armbian.
Wifi :
I couldn’t connect via. wifi, “wifi network could not be found”
But it was listed with a good signal strength.
BT:
no adapter was found. ( I used armconfig to enable BT)
USB:
just 3 of 4 usb ports were working. ( I guess it was 1x usb 3.0 & 2x usb 2.0)
The Rock Pi ist connected via usbc and I tried different Power sources, Monitor (supercharging enabled), PC & and a seperate power supply with 3,5 A.
Then I tried librelec,(LibreELEC-RK3399.arm-10.0.4-rock-pi-4) there wasnt even a Wifi or a BT adapter listed.
And only 1 usb port were working.
And then I tried Debian and I finally got all USB ports working.
Also my BT adapter showed up the first time.
But I still wasnt able to connect to my wifi network, my network was listed but I got again: “wifi network could not be found”
With BT was nearly the same…, it listed my BT device but it couldn’t connect.
Dietpi… also nearly the same just one usb 3.0 was working.
Any tips how to solve this ?
Or could it be an hardware failure ?
