AX210NGW WiFi 6E Card M.2 5400Mbps Tri-Band Wireless Module for laptop,11AX WiFi Adapter with Bluetooth 5.3,MU-MIMO, Ultra-Low Latency, NGFF, Supports Windows 11/10 (64bit)
WiFi should works out of the box in Armbian 23.8 and newer versions. Firmware changes (remove pnvm bin) are not required any more. BT requires installing the armbian-firmware-full package manually.
radxa@rock-5a:~$ inxi -M -N -E
Machine:
Type: ARM System: Radxa ROCK 5A details: N/A
Network:
Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi
Device-2: rk3588-gmac driver: rk_gmac_dwmac
Bluetooth:
Device-1: Intel AX210 Bluetooth type: USB driver: btusb
Report: hciconfig ID: hci0 state: up
So I finally got the system up and running, got the armbian-firmware-full, opened the Bluetooth devices and set my bluetooth speaker to discover. Took a lot of tries, finally the speaker comes up and I try to connect and and tells me connection failed. What could be wrong?
