Hello Experts, I am having an issue with my Rardxa Zero 2 16GM EMMC. If I install CoreElec 20.2 linux to the internal storage, and boot to it, I cannot access any SD Card in the SD slot. It does not show them as a source. I do not have this issue with my Radxa Zero original 16GB. Core Elec shows the SD card contents right away. It shows up as a source and I can play movie files from the SD card without any other steps. Alternatively, if I try to install Core Elec 20.2 to an SD card, and boot to that, it fails on startup with the error code below and does not make it through the first bootup.
Starting debugging shell for boot step: mount_flash… type exit to quit
Error in mount_flash: mount_common: Could not mount UUID=3006-1615
Is it possible to get CoreElec to recognize the SD card storage? So I can use both the EMMC and sd card slot? Maybe if I moun the sd card via command line which I am not sure how to do? If I SSH to the Radxa Zero 2, and type the ‘mount’ command, it does not list the SD card storage. If I SSH to the Radxa Zero Original 16GB with CoreElec 20.2 installed on the EMMC, I can see SD Card storage listed in the mount command which shows: /dev/mmcblk1p1 on /var/media/power1tb type fuseblk (bunch of options here)
