I’m currently testing a Radxa Zero 3W and comparing its Wi-Fi performance to a Raspberry Pi Zero 2W (which supports only 2.4GHz). I’ve run multiple tests comparing signal strength using Network Manager while ensuring the most similar testing environments by reducing variables. I’ve tried the two scenarios:
Both devices were tested using the same 2.4GHz network.
Radxa on 5GHz with Pi on 2.4GHz.
In both scenarios, the Radxa consistently performs slightly worse or sometimes significantly worse than the Pi in terms of Wi-Fi signal strength.
I tested both the Debian B6 CLI (minimal) and Debian B6 XFCE (desktop) images from your official releases.
I would expect the Radxa to outperform the Pi in these scenarios. Are there known Wi-Fi performance issues or tuning recommendations for the Zero 3W? Could this be a firmware or driver issue?
