Where to find the prorietary/binary Vulkan MALI drivers for G62 (rk3566)?
I want to use the Vulkan API on the Zero 3W. I tested the Android image (with proprieraty drivers) and it kida worked, I think it had Vulkan 1.1 support… But I would rather use a linux based system. I tested several images. On some of them I did manage to get the open source panfrost driver working… but it has only Vulkan 1.0 support… and I had some other issues when I tried to use it. So I wanted to test the proprietary drivers (e.g. I tried following the steps in: Switch GPU driver | Radxa Docs), but the issue is: the libmali-bifrost-g52-g13p0-x11-wayland-gbm.so file (or any other variants I found in different repos), does not actually contain the Vulkan API.
Does anybody knows where I could get the vulkan drivers (libMaliOpenCL.so.1) for this board?
