I’m modifying U-Boot to implement some custom boot logic for Rock Pi 4b. What I would like to do is to use (customized) U-Boot in eMMC to boot into Android image installed on NVMe drive. I would like to know which configuration was used to build uboot-trust-spi.img in this link.
I saw this comment that says rk3399-pie-gms-express-baseline branch from radxa/u-boot repository was used to build the image, but it doesn’t specify the commit ID and the exact configuration. I tried rock-pi-4b-rk3399_defconfig, but U-Boot built from that configuration was not able to boot Android from NVMe. Can I get the information on how to build that uboot-trust-spi.img myself?
Maybe you can advise on this problem?
I have Android 9 on emmc but try to boot Manjaro Linux from a micro-sd card.
It doesn’t boot, it uses u-boot 2020.04 and kernel 5.7
Only after I erase the whole emmc and then insert the micro-sd card, does Manjaro Linux boot correctly from a micro-sd card.
Is it a problem with the u-boot on emmc or SPI u-boot?
Any way to fix it so it can boot from micro-sd card correctly and if removed, Android on emmc can also still boot?
I would also want to add USB boot for Linux first in u-boot so it boots USB - Micro-sd - emmc in this order if it finds any Linux OS on there.
I heard Android can’t boot from USB, but is there a way to do it with a newer u-boot perhaps in future?
