Attention please: first,ensure your kernel has been compiled"
— There are no instructions for kernel compilation.
I tried to follow the readme.txt and it throws the following error for ‘make’
rock@linux:~/linux-rockchip$ sudo make
[sudo] password for rock:
CHK include/linux/version.h
CHK include/generated/utsrelease.h
make[1]: ‘include/generated/mach-types.h’ is up to date.
CC kernel/bounds.s
gcc: error: unrecognized argument in option ‘-mabi=apcs-gnu’
gcc: note: valid arguments to ‘-mabi=’ are: ilp32 lp64
gcc: error: unrecognized command line option ‘-mapcs’; did you mean ‘–specs’?
gcc: error: unrecognized command line option ‘-mno-sched-prolog’; did you mean ‘-Wno-sign-promo’?
gcc: error: unrecognized command line option ‘-msoft-float’
/home/rock/linux-rockchip/./Kbuild:35: recipe for target ‘kernel/bounds.s’ failed
make[1]: *** [kernel/bounds.s] Error 1
Makefile:999: recipe for target ‘prepare0’ failed
make: *** [prepare0] Error 2
please help with kernel compilation or suggesting other methods.
P.S - I have Ubuntu bionic image
Thank you for providing the link. I am facing the following issues :
**rock@localhost:~$ sudo hostapd /etc/hostapd/hostapd.conf ** Configuration file: /etc/hostapd/hostapd.conf drv->ifindex=3 l2_sock_recv==l2_sock_xmit=0x0x55ab39f4d0 ioctl[RTL_IOCTL_HOSTAPD]: Operation not supported Could not connect to kernel driver. +rtl871x_sta_deauth_ops, ff:ff:ff:ff:ff:ff is deauth, reason=2 rtl871x_set_key_ops ioctl[RTL_IOCTL_HOSTAPD]: Operation not supported Failed to set encryption. rtl871x_set_key_ops ioctl[RTL_IOCTL_HOSTAPD]: Operation not supported Failed to set encryption. rtl871x_set_key_ops ioctl[RTL_IOCTL_HOSTAPD]: Operation not supported Failed to set encryption. rtl871x_set_key_ops ioctl[RTL_IOCTL_HOSTAPD]: Operation not supported Failed to set encryption. Using interface wlan0 with hwaddr 6c:21:a2:14:ce:9a and ssid 'ROCK4’ rtl871x_set_wps_assoc_resp_ie ioctl[RTL_IOCTL_HOSTAPD]: Operation not supported rtl871x_set_key_ops ioctl[RTL_IOCTL_HOSTAPD]: Operation not supported Failed to set encryption. rtl871x_set_beacon_ops ioctl[RTL_IOCTL_HOSTAPD]: Operation not supported rtl871x_set_hidden_ssid ignore_broadcast_ssid:0, ROCK4,5 ioctl[RTL_IOCTL_HOSTAPD]: Operation not supported rtl871x_set_acl Failed to set beacon head/tail or DTIM period ^X^Z [1]+ Stopped sudo hostapd /etc/hostapd/hostapd.conf
I followed the link for the .conf files
Note: rock@localhost:~$ uname -a
Linux linux 4.4.154-87-rockchip-00029-g8216f17#2 SMP Sat Jun 22 11:06:39 CST 2019 aarch64 aarch64 aarch64 GNU/Linux
Armbian is highly improved Ubuntu and Access Point feature was extra fine tuned and it works far better than on any Debian/Ubuntu based distribution out there. Most important features were brought from specialised distributions for routers like OpenWRT. Even you succeeds, your solution will still be below hardware capabilities.
Testing this will cost you 15 minutes, while fixing your “Ubuntu” perhaps 100x - 500x more? Then another bulk for getting high speed operations … If you want to learn by trying, I have no objections, but if you want a full blown tested solution with as low problems as possible …
I am learning by trying…I had Debian running initially and due to some issues with OpenCV installation I switched to Ubuntu …so I just want to try every possible way before switching to another Linux distribution … the config steps mentioned in the video can be done with /etc/hostapd/hostapd.conf. I don’t understand the (number of) probing channels …
Currently the hostapd.conf is
I tried changing the country code to DE…sometimes it works with CN but there are messages like IEEE 802.11 n - disassociated . AP enabled . AP disabled …etc
If I’m missing something very basic , sorry I’m a newbie
That’s why Armbian is always Debian or Ubuntu based with the exact same kernel. Yet another critical added value. To quickly solve the problem in case troubles are on the user land level, like you experienced. This is quite common.
Its the (only) way to deal also with drivers that were not done by the book. I have seen drivers saying “yes we support this channel/band” but it actually doesn’t work. This could surely be further optimised but its not critical if you have to wait a minute. You only do this once.
That’s why I propose you something (much) more suitable and reliable to not break your teeth upon. And to have a reference point (what hardware is capable) and where you will not be able to get the way you approached to the problem. Remember that when (if) you succeeds to come out with a working configuration, you still need to patch and recompile hostapd binary and pin it that its not overwritten with upstream …
Mine still does not work with this config. The files are way out of date, maybe that is why. Has anyone compiled hostapd and the realtek driver to work with a rock pi? I may just turn this into a movie player…
This does not work directly. It results in many hostapd and wlan0 errors complaining about the stock driver (nl80211) cannot be placed in ap mode or there is not enough entropy.
Yes, few years ago … Check video - zero compilation, zero scripting. On Rockpi it works exactly the same. With Armbian, tested with this mainline based image: https://dl.armbian.com/rockpi-4b/Buster_current but it should work the same with stock 4.4.y kernel.
I didn’t get AC speed - need to check why (almost 100% its only a config/firmware issue since AC works elsewhere), but 60Mbps UL/DL few meters away (phone as a client) is not that bad considering there is no external antenna.
The same setup/distance/client but with Realtek 8812AU dongle on USB, 180Mbps UL/DL
