Hi all I recently got the radxa 8 inch display with 5a board, firstly be carefull when you are connecting the connector, nubert from allnetchina was detrimental for helping me, not burn the connector, for anyone trying to connect, please follow this guide from here
once the connections are established,
on the official version of radxas os, i had to use ```
rsetup
and enable ```Enable Radxa Display 8HD``` then the display started working,
this is how i connected, touch is also working on the official rom,
but then i am facing this issue, where in i have enabled the overlays for the display in `ubuntuEnv.txt` file: Usually in the `/boot/firmware/`
and enabled ```
overlays=rock-5b-radxa-display-8hd rock-5a-radxa-camera-4k
this started the display to work, but touch doesnt work whatsoever.
anyone figured out how to make the touch work in other osses?
tried ubuntu and armbian, but the problem is still the same, anyone made the touch work?
thanks
