Use hotspot (AP Mode) on CM3
May i know if currently CM3 OS supports hotspot mode? Is there an instruction on bringing it up?
I tried to follow some online tutorials here, but run into various technical issues.
I could sometimes see the hotspot showing up, but cannot connect. Sometime I manage to connect and authenticate, but drops immediately.
My CM3 is having the AzureWave AW-CM256SM chip. Thanks!
Interestingly, I have a better luck with nmcli command
I kind of combine the solution in the following two links, for both brining up of the Hotspot, and change the default 10.42.0.x IP assignment
This puzzles me. Seems the OS / driver seems all working. Just the software having some quirks? Whats the best practice here for CM3?
