I am doing a series of benchmarks with the same set of 4x 120gb Integral P series 5
https://integralmemory.com/product/p-series-5-performance-sata-iii-2.5-inch-solid-state-drive-ssd
I have also 4x Jmicron 578 usb adapters the powered 12v ones that can also run 3.5" disk.
Image used is the standard Debian https://dl.radxa.com/rockpi/images/debian/rockpi4_debian_stretch_lxde_armhf_20181105_2120-gpt.img.gz
Linux linaro-alip 4.4.154
So with 2 identical ssd in USB3.0-0 & USB3.0-1 we will check single disk speed.
/dev/sda
Command line used: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2
Output is in kBytes/sec
random random bkwd record stride
kB reclen write rewrite read reread read write read rewrite read fwrite frewrite fread freread
102400 4 18252 27259 31814 32002 20574 26928
102400 16 60376 87245 97004 98580 64215 88406
102400 512 261755 232193 242331 252794 211577 279430
102400 1024 304668 311887 289360 296418 250199 273380
102400 16384 390597 393552 346084 354387 345981 393214
/dev/sdb
102400 4 18323 26205 30070 30425 18320 26103
102400 16 57640 79354 94251 92999 60041 85012
102400 512 262524 269200 246613 254026 209976 241371
102400 1024 299684 313775 300159 309836 254030 285209
102400 16384 390050 396653 343984 355940 348794 394684
Slight difference but prob if test was run multiple times the average would be close enough not to matter and above doesn’t really.
Now start with raid
sudo mdadm --create --verbose /dev/md0 --level=0 --raid-devices=2 /dev/sda /dev/sdb
/dev/md0
102400 4 22511 27894 32447 31611 20538 27974
102400 16 67143 82704 90162 102588 64829 80332
102400 512 273903 286319 267301 269415 222084 298235
102400 1024 484016 498544 452781 464062 381425 418365
102400 16384 757070 533962 659360 690695 621724 773455
sudo mdadm --create --verbose /dev/md0 --level=1 --raid-devices=2 /dev/sda /dev/sdb
102400 4 8999 10704 19223 16672 9380 10044
102400 16 35224 33219 26717 93407 32162 38301
102400 512 236433 149504 261918 206158 143571 224128
102400 1024 187899 248715 178599 187869 159296 263155
102400 16384 296295 267946 131671 333164 329056 290577
This time on a 4 port USB3.0 hub using the top USB3.0 port
102400 4 13234 15227 18615 18588 13082 15241
102400 16 31071 34921 38321 38415 31401 35065
102400 512 58148 57295 56534 56256 55781 58886
102400 1024 64100 64696 63539 63775 64067 62311
102400 16384 68061 68293 66934 66678 66957 68150
102400 4 8900 9830 31376 31014 17521 9536
102400 16 18217 19297 94578 86954 61725 19474
102400 512 32041 32341 248433 250812 199070 30996
102400 1024 31819 32555 271239 271200 237609 32522
102400 16384 33706 33294 327036 336360 329408 33838
I added this on the end because at times either via hub or 2 ports occasionally you get a stutter like a disk has gone on holiday.
102400 4 13199 15578 800 18734 13116 15784
102400 16 31451 35213 38820 38832 31419 34123
102400 512 56975 56546 54976 55229 55360 57779
102400 1024 62347 62775 61629 62024 62171 62006
102400 16384 68176 68358 67332 66765 67234 68297
Really not sure what happened on that 4k read
journalctl
Jul 17 16:28:07 linaro-alip sudo[1202]: linaro : TTY=pts/0 ; PWD=/home/linaro/ssda ; USER=root ; COMMAND=/usr/bin/iozone -e -I -a -s 100M -r 4k -r 16k -r 512
Jul 17 16:28:07 linaro-alip sudo[1202]: pam_unix(sudo:session): session opened for user root by linaro(uid=0)
Jul 17 16:28:53 linaro-alip kernel: sd 0:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD
Jul 17 16:28:53 linaro-alip kernel: sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 00 04 3f 58 00 00 08 00
Jul 17 16:29:27 linaro-alip kernel: sd 0:0:0:0: [sda] tag#2 uas_eh_abort_handler 0 uas-tag 3 inflight: CMD
Jul 17 16:29:27 linaro-alip kernel: sd 0:0:0:0: [sda] tag#2 CDB: opcode=0x2a 2a 00 00 02 00 00 00 00 10 00
Jul 17 16:29:27 linaro-alip kernel: scsi host0: uas_eh_bus_reset_handler start
Jul 17 16:29:27 linaro-alip kernel: sd 0:0:0:0: [sda] tag#1 uas_zap_pending 0 uas-tag 2 inflight: CMD
Jul 17 16:29:27 linaro-alip kernel: sd 0:0:0:0: [sda] tag#1 CDB: opcode=0x35 35 00 00 00 00 00 00 00 00 00
Jul 17 16:29:27 linaro-alip kernel: sd 0:0:0:0: [sda] tag#3 uas_zap_pending 0 uas-tag 4 inflight: CMD
Jul 17 16:29:27 linaro-alip kernel: sd 0:0:0:0: [sda] tag#3 CDB: opcode=0x2a 2a 00 00 02 00 30 00 00 08 00
Jul 17 16:29:27 linaro-alip kernel: sd 0:0:0:0: [sda] tag#4 uas_zap_pending 0 uas-tag 5 inflight: CMD
Jul 17 16:29:27 linaro-alip kernel: sd 0:0:0:0: [sda] tag#4 CDB: opcode=0x2a 2a 00 00 02 10 f0 00 00 08 00
Jul 17 16:29:27 linaro-alip kernel: sd 0:0:0:0: [sda] tag#5 uas_zap_pending 0 uas-tag 6 inflight: CMD
Jul 17 16:29:27 linaro-alip kernel: sd 0:0:0:0: [sda] tag#5 CDB: opcode=0x2a 2a 00 00 02 11 68 00 00 08 00
Jul 17 16:29:27 linaro-alip kernel: sd 0:0:0:0: [sda] tag#6 uas_zap_pending 0 uas-tag 7 inflight: CMD
Jul 17 16:29:27 linaro-alip kernel: sd 0:0:0:0: [sda] tag#6 CDB: opcode=0x2a 2a 00 00 02 91 e8 00 00 08 00
Jul 17 16:29:27 linaro-alip kernel: usb 7-1.1: reset high-speed USB device number 3 using xhci-hcd
Jul 17 16:29:27 linaro-alip kernel: scsi host0: uas_eh_bus_reset_handler success
Jul 17 16:30:02 linaro-alip kernel: sd 0:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD
Jul 17 16:30:02 linaro-alip kernel: sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 00 05 71 08 00 00 08 00
Jul 17 16:30:28 linaro-alip kernel: sd 0:0:0:0: [sda] tag#1 uas_eh_abort_handler 0 uas-tag 2 inflight: CMD
Jul 17 16:30:28 linaro-alip kernel: sd 0:0:0:0: [sda] tag#1 CDB: opcode=0x2a 2a 00 06 e4 04 38 00 00 10 00
Jul 17 16:30:28 linaro-alip kernel: scsi host0: uas_eh_bus_reset_handler start
Jul 17 16:30:28 linaro-alip kernel: sd 0:0:0:0: [sda] tag#2 uas_zap_pending 0 uas-tag 3 inflight: CMD
Jul 17 16:30:28 linaro-alip kernel: sd 0:0:0:0: [sda] tag#2 CDB: opcode=0x2a 2a 00 00 02 00 38 00 00 18 00
Jul 17 16:30:28 linaro-alip kernel: sd 0:0:0:0: [sda] tag#3 uas_zap_pending 0 uas-tag 4 inflight: CMD
Jul 17 16:30:28 linaro-alip kernel: sd 0:0:0:0: [sda] tag#3 CDB: opcode=0x2a 2a 00 00 02 11 e8 00 00 08 00
Jul 17 16:30:28 linaro-alip kernel: usb 7-1.1: reset high-speed USB device number 3 using xhci-hcd
Jul 17 16:30:28 linaro-alip kernel: scsi host0: uas_eh_bus_reset_handler success
Jul 17 16:31:37 linaro-alip sudo[1202]: pam_unix(sudo:session): session closed for user root
