USB SATA device disconnect randomly
Hi!
My HDDs randomly disconnect. Sometimes after a day, sometimes after a few hours, sometimes in heavy usage and sometimes in idle state.
I am trying to solve this problem since January, but with no luck.
I read many forums, and they talked about kernel update, disable UAS, bad RPI 4 USB 3.0 ports, change the HDD with other one, power issues, but I tried out everything.
Two thing which I didn’t try:
  1. The only thing which I didn’t try is the power supply replacement.
    I have the this one: https://shop.allnetchina.cn/collections/sata-hat/products/dc12v-5a-60w-wall-plug-power-supply
  2. Replace with another RPI 4, because I only have one, but the ports seems to okay.
I post my dmesg in commect because of the character limit.
Thanks for help or any advice!
My dmesg when the UAS is enabled:
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.10.17-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1403 SMP Mon Feb 22 11:33:35 GMT 2021
[    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
[    0.000000]   Normal   empty
[    0.000000]   HighMem  [mem 0x0000000030000000-0x00000000fbffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x000000002fffffff]
[    0.000000]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
[    0.000000] On node 0 totalpages: 966656
[    0.000000]   DMA zone: 2304 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 196608 pages, LIFO batch:63
[    0.000000]   HighMem zone: 770048 pages, LIFO batch:63
[    0.000000] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
[    0.000000] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 964352
[    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=DC:A6:32:76:2E:65 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p7 rootfstype=ext4 fsck.repair=yes rootwait usbhid.mousepoll=0
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x0000000017cc0000-0x000000001bcc0000] (64MB)
[    0.000000] Memory: 3472776K/3866624K available (10240K kernel code, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 131704K reserved, 262144K cma-reserved, 3080192K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 33942 entries in 67 pages
[    0.000000] ftrace: allocated 67 pages with 3 groups
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
[    0.000008] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[    0.000035] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[    0.000105] bcm2835: system timer (irq = 25)
[    0.000770] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[    0.000791] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[    0.000813] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[    0.000832] Switching to timer-based delay loop, resolution 18ns
[    0.001100] Console: colour dummy device 80x30
[    0.001820] printk: console [tty1] enabled
[    0.001890] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[    0.001945] pid_max: default: 32768 minimum: 301
[    0.002132] LSM: Security Framework initializing
[    0.002338] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.002383] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.004035] Disabling memory control group subsystem
[    0.004176] CPU: Testing write buffer coherency: ok
[    0.004678] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.005930] Setting up static identity map for 0x200000 - 0x20003c
[    0.006149] rcu: Hierarchical SRCU implementation.
[    0.007111] smp: Bringing up secondary CPUs ...
[    0.008400] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.009828] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.011298] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.011458] smp: Brought up 1 node, 4 CPUs
[    0.011506] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[    0.011537] CPU: All CPU(s) started in HYP mode.
[    0.011564] CPU: Virtualization extensions available.
[    0.012425] devtmpfs: initialized
[    0.026678] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[    0.026960] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.027017] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.034414] pinctrl core: initialized pinctrl subsystem
[    0.035564] NET: Registered protocol family 16
[    0.039745] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.040565] audit: initializing netlink subsys (disabled)
[    0.040905] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
[    0.041487] thermal_sys: Registered thermal governor 'step_wise'
[    0.042226] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.042280] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.042714] Serial: AMBA PL011 UART driver
[    0.078369] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[    0.090925] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-02-25T12:10:40, variant start
[    0.100938] raspberrypi-firmware soc:firmware: Firmware hash is 564e5f9b852b23a330b1764bcf0b2d022a20afd0
[    0.146055] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[    0.150345] vgaarb: loaded
[    0.150828] SCSI subsystem initialized
[    0.151419] usbcore: registered new interface driver usbfs
[    0.151495] usbcore: registered new interface driver hub
[    0.151600] usbcore: registered new device driver usb
[    0.151984] usb_phy_generic phy: supply vcc not found, using dummy regulator
[    0.153970] clocksource: Switched to clocksource arch_sys_counter
[    1.155539] VFS: Disk quotas dquot_6.6.0
[    1.155680] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.155889] FS-Cache: Loaded
[    1.156096] CacheFiles: Loaded
[    1.157230] simple-framebuffer 3e3cf000.framebuffer: framebuffer at 0x3e3cf000, 0x7f8000 bytes, mapped to 0x(ptrval)
[    1.157276] simple-framebuffer 3e3cf000.framebuffer: format=a8r8g8b8, mode=1920x1080x32, linelength=7680
[    1.168398] Console: switching to colour frame buffer device 240x67
[    1.178590] simple-framebuffer 3e3cf000.framebuffer: fb0: simplefb registered!
[    1.187459] NET: Registered protocol family 2
[    1.188447] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    1.188682] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    1.188836] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    1.188982] TCP: Hash tables configured (established 8192 bind 8192)
[    1.189217] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.189325] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.189661] NET: Registered protocol family 1
[    1.190479] RPC: Registered named UNIX socket transport module.
[    1.190559] RPC: Registered udp transport module.
[    1.190624] RPC: Registered tcp transport module.
[    1.190690] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.190778] PCI: CLS 0 bytes, default 64
[    1.193895] Initialise system trusted keyrings
[    1.194280] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[    1.202969] zbud: loaded
[    1.205082] FS-Cache: Netfs 'nfs' registered for caching
[    1.205939] NFS: Registering the id_resolver key type
[    1.206049] Key type id_resolver registered
[    1.206113] Key type id_legacy registered
[    1.206301] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.207437] Key type asymmetric registered
[    1.207503] Asymmetric key parser 'x509' registered
[    1.207748] bounce: pool size: 64 pages
[    1.207848] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    1.208143] io scheduler mq-deadline registered
[    1.208209] io scheduler kyber registered
[    1.212947] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[    1.213058] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[    1.213227] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
[    1.213414] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
[    1.276072] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[    1.279357] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[    1.282227] pci_bus 0000:00: root bus resource [bus 00-ff]
[    1.285204] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[    1.288208] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[    1.291359] pci 0000:00:00.0: PME# supported from D0 D3hot
[    1.297856] PCI: bus0: Fast back to back transfers disabled
[    1.301090] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[    1.304133] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    1.307493] pci 0000:01:00.0: PME# supported from D0 D3cold
[    1.313860] PCI: bus1: Fast back to back transfers disabled
[    1.316736] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[    1.319580] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[    1.322456] pci 0000:00:00.0: PCI bridge to [bus 01]
[    1.325278] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
[    1.328512] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[    1.331529] pcieport 0000:00:00.0: PME: Signaling with IRQ 64
[    1.343443] iproc-rng200 fe104000.rng: hwrng registered
[    1.346718] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[    1.350433] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[    1.365808] brd: module loaded
[    1.381185] loop: module loaded
[    1.385900] Loading iSCSI transport class v2.0-870.
[    1.391274] libphy: Fixed MDIO Bus: probed
[    1.395999] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[    1.414007] libphy: bcmgenet MII bus: probed
[    1.504149] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[    1.508200] usbcore: registered new interface driver r8152
[    1.511065] usbcore: registered new interface driver lan78xx
[    1.513872] usbcore: registered new interface driver smsc95xx
[    1.518247] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
[    1.521102] xhci_hcd 0000:01:00.0: xHCI Host Controller
[    1.523801] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[    1.529913] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
[    1.533890] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    1.536627] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.539309] usb usb1: Product: xHCI Host Controller
[    1.541972] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
[    1.544652] usb usb1: SerialNumber: 0000:01:00.0
[    1.547984] hub 1-0:1.0: USB hub found
[    1.550707] hub 1-0:1.0: 1 port detected
[    1.554070] xhci_hcd 0000:01:00.0: xHCI Host Controller
[    1.556740] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[    1.559427] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[    1.562571] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    1.565260] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.567935] usb usb2: Product: xHCI Host Controller
[    1.570617] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
[    1.573298] usb usb2: SerialNumber: 0000:01:00.0
[    1.576741] hub 2-0:1.0: USB hub found
[    1.579494] hub 2-0:1.0: 4 ports detected
[    1.583922] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.586948] dwc_otg: FIQ enabled
[    1.586963] dwc_otg: NAK holdoff enabled
[    1.586978] dwc_otg: FIQ split-transaction FSM enabled
[    1.586996] Module dwc_common_port init
[    1.587466] usbcore: registered new interface driver uas
[    1.590233] usbcore: registered new interface driver usb-storage
[    1.593073] mousedev: PS/2 mouse device common for all mice
[    1.597493] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    1.603736] sdhci: Secure Digital Host Controller Interface driver
[    1.606460] sdhci: Copyright(c) Pierre Ossman
[    1.609837] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[    1.613124] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.618938] ledtrig-cpu: registered to indicate activity on CPUs
[    1.621986] hid: raw HID events driver (C) Jiri Kosina
[    1.624874] usbcore: registered new interface driver usbhid
[    1.627558] usbhid: USB HID core driver
[    1.636286] Initializing XFRM netlink socket
[    1.639054] NET: Registered protocol family 17
[    1.641861] Key type dns_resolver registered
[    1.644947] Registering SWP/SWPB emulation handler
[    1.647685] registered taskstats version 1
[    1.650272] Loading compiled-in X.509 certificates
[    1.653713] Key type ._fscrypt registered
[    1.656599] Key type .fscrypt registered
[    1.659157] Key type fscrypt-provisioning registered
[    1.673403] uart-pl011 fe201000.serial: there is not valid maps for state default
[    1.676426] uart-pl011 fe201000.serial: cts_event_workaround enabled
[    1.679078] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
[    1.689312] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[    1.693041] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[    1.695772] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[    1.727528] of_cfs_init
[    1.730469] of_cfs_init: OK
[    1.746569] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    1.750804] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.755055] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.760613] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    1.765241] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.768801] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[    1.772492] Waiting for root device /dev/mmcblk0p7...
[    1.811409] random: fast init done
[    1.840390] mmc1: new high speed SDIO card at address 0001
[    1.875721] mmc0: new ultra high speed DDR50 SDXC card at address aaaa
[    1.879257] mmcblk0: mmc0:aaaa SN64G 59.5 GiB
[    1.886132]  mmcblk0: p1 p2 < p5 p6 p7 >
[    1.903623] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[    1.906358] VFS: Mounted root (ext4 filesystem) readonly on device 179:7.
[    1.914024] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[    1.916636] devtmpfs: mounted
[    1.928299] Freeing unused kernel memory: 2048K
[    2.014308] Run /sbin/init as init process
[    2.016826]   with arguments:
[    2.016841]     /sbin/init
[    2.016855]   with environment:
[    2.016870]     HOME=/
[    2.016884]     TERM=linux
[    2.096681] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[    2.099274] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    2.101857] usb 1-1: Product: USB2.0 Hub
[    2.106556] hub 1-1:1.0: USB hub found
[    2.109525] hub 1-1:1.0: 4 ports detected
[    2.479271] systemd[1]: System time before build time, advancing clock.
[    2.595362] NET: Registered protocol family 10
[    2.599388] Segment Routing with IPv6
[    2.671157] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    2.680269] systemd[1]: Detected architecture arm.
[    2.762790] systemd[1]: Set hostname to <raspberry-pi-4>.
[    3.406168] systemd[1]: /lib/systemd/system/winbind.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/winbindd.pid → /run/samba/winbindd.pid; please update the unit file accordingly.
[    3.603645] systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
[    3.667576] systemd[1]: /lib/systemd/system/fail2ban.service:12: PIDFile= references path below legacy directory /var/run/, updating /var/run/fail2ban/fail2ban.pid → /run/fail2ban/fail2ban.pid; please update the unit file accordingly.
[    3.766642] random: systemd: uninitialized urandom read (16 bytes read)
[    3.792326] random: systemd: uninitialized urandom read (16 bytes read)
[    3.796685] systemd[1]: Listening on fsck to fsckd communication Socket.
[    3.805006] random: systemd: uninitialized urandom read (16 bytes read)
[    3.808787] systemd[1]: Listening on udev Kernel Socket.
[    3.817256] systemd[1]: Listening on Journal Socket (/dev/log).
[    3.827634] systemd[1]: Created slice User and Session Slice.
[    4.035086] i2c /dev entries driver
[    4.628952] EXT4-fs (mmcblk0p7): re-mounted. Opts: (null)
[    4.768056] systemd-journald[127]: Received request to flush runtime journal from PID 1
[    5.063121] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    5.117795] fuse: init (API version 7.32)
[    5.614207] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[    5.617205] Driver for 1-wire Dallas network protocol.
[    5.621005] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[    5.621651] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[    5.622193] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[    5.643230] gpio-4 (onewire@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    5.652344] mc: Linux media interface: v0.10
[    5.655901] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[    5.658286] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[    5.658316] [vc_sm_connected_init]: start
[    5.677315] [vc_sm_connected_init]: installed successfully
[    5.682643] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[    5.699234] bcm2835_audio bcm2835_audio: card created with 4 channels
[    5.721901] bcm2835_audio bcm2835_audio: card created with 4 channels
[    5.761178] videodev: Linux video capture interface: v2.00
[    5.835576] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    5.835880] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    5.861811] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[    5.864988] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[    5.867294] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[    5.899124] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[    5.899176] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[    5.906155] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[    5.906212] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[    5.910092] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[    5.911928] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[    5.923459] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[    5.928063] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[    5.928149] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[    5.928223] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[    5.928308] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[    5.928374] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[    5.930396] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[    5.994473] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[    5.994524] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[    6.032343] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    6.035410] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[    6.179394] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    6.280809] brcmfmac: F1 signature read @0x18000000=0x15264345
[    6.298099] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    6.298662] usbcore: registered new interface driver brcmfmac
[    6.338283] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[    6.338360] checking generic (3e3cf000 7f8000) vs hw (0 ffffffffffffffff)
[    6.338425] fb0: switching to vc4drmfb from simple
[    6.342687] Console: switching to colour dummy device 80x30
[    6.353538] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[    6.355439] vc4-drm gpu: [drm] HDMI-A-1: EDID is invalid:
[    6.355464]  [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.355480]  [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.355495]  [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.355510]  [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.355525]  [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.355540]  [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.355555]  [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.355570]  [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.491234] Console: switching to colour frame buffer device 240x67
[    6.515989] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
[    6.578400] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    6.591911] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
[    7.071806] rtc-pcf8563 1-0051: registered as rtc0
[    9.772788] uart-pl011 fe201000.serial: no DMA platform data
[    9.789566] 8021q: 802.1Q VLAN Support v1.8
[   10.096376] random: crng init done
[   10.096394] random: 7 urandom warning(s) missed due to ratelimiting
[   10.434059] Adding 2097148k swap on /var/swap.  Priority:-2 extents:5 across:3309564k SSFS
[   10.923605] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[   10.924681] bcmgenet fd580000.ethernet eth0: Link is Down
[   15.114157] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   15.114192] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   16.694531] Bluetooth: Core ver 2.22
[   16.694598] NET: Registered protocol family 31
[   16.694607] Bluetooth: HCI device and connection manager initialized
[   16.695059] Bluetooth: HCI socket layer initialized
[   16.695074] Bluetooth: L2CAP socket layer initialized
[   16.695097] Bluetooth: SCO socket layer initialized
[   16.703839] Bluetooth: HCI UART driver ver 2.3
[   16.703852] Bluetooth: HCI UART protocol H4 registered
[   16.703920] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   16.704681] Bluetooth: HCI UART protocol Broadcom registered
[   16.964766] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   16.964779] Bluetooth: BNEP filters: protocol multicast
[   16.964795] Bluetooth: BNEP socket layer initialized
[   17.044248] Bluetooth: RFCOMM TTY layer initialized
[   17.044272] Bluetooth: RFCOMM socket layer initialized
[   17.044300] Bluetooth: RFCOMM ver 1.11
[   21.134318] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[   21.165550] usb 2-2: New USB device found, idVendor=152d, idProduct=0561, bcdDevice=81.36
[   21.165563] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[   21.165571] usb 2-2: Product: JMS56x Series
[   21.165578] usb 2-2: Manufacturer: JMicron
[   21.165585] usb 2-2: SerialNumber: DD564198838B4
[   21.196297] scsi host0: uas
[   21.198737] scsi 0:0:0:0: Direct-Access     ST1000LM 049-2GH172       8136 PQ: 0 ANSI: 6
[   21.201086] scsi 0:0:0:1: Direct-Access     ST1000LM 049-2GH172       8136 PQ: 0 ANSI: 6
[   21.201461] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[   21.201738] sd 0:0:0:0: [sda] Write Protect is off
[   21.201747] sd 0:0:0:0: [sda] Mode Sense: 67 00 10 08
[   21.202284] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, supports DPO and FUA
[   21.203060] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
[   21.204589] sd 0:0:0:1: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[   21.204859] sd 0:0:0:1: [sdb] Write Protect is off
[   21.204868] sd 0:0:0:1: [sdb] Mode Sense: 67 00 10 08
[   21.205349] sd 0:0:0:1: [sdb] Write cache: enabled, read cache: enabled, supports DPO and FUA
[   21.206090] sd 0:0:0:1: [sdb] Optimal transfer size 33553920 bytes
[   21.289102]  sdb: sdb1
[   21.304593] sd 0:0:0:0: Attached scsi generic sg0 type 0
[   21.305784] sd 0:0:0:1: Attached scsi generic sg1 type 0
[   21.319146]  sda: sda1
[   21.322298] sd 0:0:0:1: [sdb] Attached SCSI disk
[   21.322688] sd 0:0:0:0: [sda] Attached SCSI disk
[   21.862016] md/raid1:md0: active with 2 out of 2 mirrors
[   21.867053] md0: detected capacity change from 0 to 1000068546560
[   23.361137] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
[   46.274408] usb 2-1: new SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[   46.305737] usb 2-1: New USB device found, idVendor=152d, idProduct=0561, bcdDevice=81.36
[   46.305757] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[   46.305773] usb 2-1: Product: JMS56x Series
[   46.305788] usb 2-1: Manufacturer: JMicron
[   46.305803] usb 2-1: SerialNumber: DD564198838B3
[   46.337738] scsi host1: uas
[   46.339263] scsi 1:0:0:0: Direct-Access     HGST HTS 721010A9E630     8136 PQ: 0 ANSI: 6
[   46.341082] sd 1:0:0:0: Attached scsi generic sg2 type 0
[   46.342328] sd 1:0:0:0: [sdc] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[   46.342610] sd 1:0:0:0: [sdc] Write Protect is off
[   46.342628] sd 1:0:0:0: [sdc] Mode Sense: 67 00 10 08
[   46.342799] scsi 1:0:0:1: Direct-Access     HGST HTS 721010A9E630     8136 PQ: 0 ANSI: 6
[   46.343198] sd 1:0:0:0: [sdc] Write cache: enabled, read cache: enabled, supports DPO and FUA
[   46.344147] sd 1:0:0:0: [sdc] Optimal transfer size 33553920 bytes
[   46.351157] sd 1:0:0:1: Attached scsi generic sg3 type 0
[   46.355475] sd 1:0:0:1: [sdd] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[   46.355812] sd 1:0:0:1: [sdd] Write Protect is off
[   46.355831] sd 1:0:0:1: [sdd] Mode Sense: 67 00 10 08
[   46.356463] sd 1:0:0:1: [sdd] Write cache: enabled, read cache: enabled, supports DPO and FUA
[   46.357391] sd 1:0:0:1: [sdd] Optimal transfer size 33553920 bytes
[   46.451219]  sdd: sdd1
[   46.492640]  sdc: sdc1
[   46.496765] sd 1:0:0:1: [sdd] Attached SCSI disk
[   46.497393] sd 1:0:0:0: [sdc] Attached SCSI disk
[   54.097824] EXT4-fs (sdd1): mounted filesystem with ordered data mode. Opts: (null)
[   54.212766] EXT4-fs (sdc1): mounted filesystem with ordered data mode. Opts: (null)
[ 4080.060049] xhci_hcd 0000:01:00.0: WARN Successful completion on short TX
[ 4080.433892] xhci_hcd 0000:01:00.0: ERROR Transfer event TRB DMA ptr not part of current TD ep_index 6 comp_code 1
[ 4080.433902] xhci_hcd 0000:01:00.0: Looking for event-dma 000000041eea6470 trb-start 000000041eea6480 trb-end 000000041eea6490 seg-start 000000041eea6000 seg-end 000000041eea6ff0
[ 4087.085290] sd 0:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: IN
[ 4087.085301] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0xa1 a1 08 0e d1 01 01 4f c2 a0 b0 00 00
[ 4087.135310] scsi host0: uas_eh_device_reset_handler start
[ 4087.286102] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 4087.319614] scsi host0: uas_eh_device_reset_handler success
[12480.313561] xhci_hcd 0000:01:00.0: WARN Successful completion on short TX
[12480.668836] xhci_hcd 0000:01:00.0: ERROR Transfer event TRB DMA ptr not part of current TD ep_index 6 comp_code 1
[12480.668846] xhci_hcd 0000:01:00.0: Looking for event-dma 000000041eebc600 trb-start 000000041eebc610 trb-end 000000041eebc610 seg-start 000000041eebc000 seg-end 000000041eebcff0
[12487.342853] sd 0:0:0:0: [sda] tag#4 uas_eh_abort_handler 0 uas-tag 1 inflight: IN
[12487.342863] sd 0:0:0:0: [sda] tag#4 CDB: opcode=0xa1 a1 08 0e d1 01 01 4f c2 a0 b0 00 00
[12487.412872] scsi host0: uas_eh_device_reset_handler start
[12487.563639] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[12487.606649] scsi host0: uas_eh_device_reset_handler success
[32882.454722] xhci_hcd 0000:01:00.0: WARN Successful completion on short TX
[32882.720837] xhci_hcd 0000:01:00.0: ERROR Transfer event TRB DMA ptr not part of current TD ep_index 6 comp_code 3
[32882.720847] xhci_hcd 0000:01:00.0: Looking for event-dma 000000041f718a50 trb-start 000000041f718a60 trb-end 0000000000000000 seg-start 000000041f718000 seg-end 000000041f718ff0
[32882.720853] xhci_hcd 0000:01:00.0: Looking for event-dma 000000041f718a50 trb-start 000000041f717000 trb-end 000000041f717260 seg-start 000000041f717000 seg-end 000000041f717ff0
[32889.814749] sd 1:0:0:0: [sdc] tag#10 uas_eh_abort_handler 0 uas-tag 2 inflight: CMD
[32889.814759] sd 1:0:0:0: [sdc] tag#10 CDB: opcode=0xa1 a1 06 0c d8 00 00 4f c2 a0 b0 00 00
[32889.814772] sd 1:0:0:0: [sdc] tag#4 uas_eh_abort_handler 0 uas-tag 9 inflight: CMD
[32889.814779] sd 1:0:0:0: [sdc] tag#4 CDB: opcode=0xa1 a1 06 0c d8 00 00 4f c2 a0 b0 00 00
[32912.855031] sd 1:0:0:1: [sdd] tag#13 uas_eh_abort_handler 0 uas-tag 4 inflight: CMD IN
[32912.855040] sd 1:0:0:1: [sdd] tag#13 CDB: opcode=0x28 28 00 3f da ed 08 00 04 00 00
[32912.855255] xhci_hcd 0000:01:00.0: WARN Set TR Deq Ptr cmd failed due to incorrect slot or ep state.
[32912.855745] sd 1:0:0:0: [sdc] tag#1 uas_eh_abort_handler 0 uas-tag 10 inflight: CMD IN
[32912.855753] sd 1:0:0:0: [sdc] tag#1 CDB: opcode=0x28 28 00 42 20 d0 b0 00 04 00 00
[32912.855926] xhci_hcd 0000:01:00.0: WARN Set TR Deq Ptr cmd failed due to incorrect slot or ep state.
[32912.856008] sd 1:0:0:1: [sdd] tag#12 uas_eh_abort_handler 0 uas-tag 5 inflight: CMD IN
[32912.856015] sd 1:0:0:1: [sdd] tag#12 CDB: opcode=0x28 28 00 3f da f1 08 00 02 f0 00
[32912.856161] xhci_hcd 0000:01:00.0: WARN Set TR Deq Ptr cmd failed due to incorrect slot or ep state.
[32912.856220] sd 1:0:0:1: [sdd] tag#11 uas_eh_abort_handler 0 uas-tag 6 inflight: CMD IN
[32912.856226] sd 1:0:0:1: [sdd] tag#11 CDB: opcode=0x28 28 00 3f da f3 f8 00 04 00 00
[32912.856334] xhci_hcd 0000:01:00.0: WARN Set TR Deq Ptr cmd failed due to incorrect slot or ep state.
[32912.856409] sd 1:0:0:1: [sdd] tag#9 uas_eh_abort_handler 0 uas-tag 3 inflight: CMD IN
[32912.856415] sd 1:0:0:1: [sdd] tag#9 CDB: opcode=0x28 28 00 3f da f7 f8 00 04 00 00
[32912.856554] xhci_hcd 0000:01:00.0: WARN Set TR Deq Ptr cmd failed due to incorrect slot or ep state.
[32912.856627] sd 1:0:0:1: [sdd] tag#8 uas_eh_abort_handler 0 uas-tag 7 inflight: CMD IN
[32912.856633] sd 1:0:0:1: [sdd] tag#8 CDB: opcode=0x28 28 00 3f da e2 28 00 04 00 00
[32912.856797] xhci_hcd 0000:01:00.0: WARN Set TR Deq Ptr cmd failed due to incorrect slot or ep state.
[32912.856872] sd 1:0:0:1: [sdd] tag#3 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD IN
[32912.856878] sd 1:0:0:1: [sdd] tag#3 CDB: opcode=0x28 28 00 3f da e6 28 00 02 e0 00
[32912.857028] xhci_hcd 0000:01:00.0: WARN Set TR Deq Ptr cmd failed due to incorrect slot or ep state.
[32912.857084] sd 1:0:0:1: [sdd] tag#0 uas_eh_abort_handler 0 uas-tag 8 inflight: CMD IN
[32912.857091] sd 1:0:0:1: [sdd] tag#0 CDB: opcode=0x28 28 00 3f da dd e0 00 04 00 00
[32912.895058] scsi host1: uas_eh_device_reset_handler start
[32913.055987] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[32913.089910] scsi host1: uas_eh_device_reset_handler success
[32913.472616] scsi host1: uas_eh_device_reset_handler start
[32913.616382] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[32913.649911] scsi host1: uas_eh_device_reset_handler success
[32913.650234] sd 1:0:0:0: [sdc] tag#10 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x06 cmd_age=31s
[32913.650256] sd 1:0:0:0: [sdc] tag#10 CDB: opcode=0xa1 a1 06 0c d8 00 00 4f c2 a0 b0 00 00
[32913.650299] sd 1:0:0:0: [sdc] tag#4 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x06 cmd_age=31s
[32913.650317] sd 1:0:0:0: [sdc] tag#4 CDB: opcode=0xa1 a1 06 0c d8 00 00 4f c2 a0 b0 00 00
[33480.280927] xhci_hcd 0000:01:00.0: WARN Successful completion on short TX
[33480.282631] xhci_hcd 0000:01:00.0: ERROR Transfer event TRB DMA ptr not part of current TD ep_index 6 comp_code 1
[33480.282643] xhci_hcd 0000:01:00.0: Looking for event-dma 000000041eebc700 trb-start 000000041eebc710 trb-end 000000041eebc710 seg-start 000000041eebc000 seg-end 000000041eebcff0
[33487.311712] sd 0:0:0:0: [sda] tag#10 uas_eh_abort_handler 0 uas-tag 1 inflight: IN
[33487.311723] sd 0:0:0:0: [sda] tag#10 CDB: opcode=0xa1 a1 08 0e 00 01 00 00 00 a0 ec 00 00
[33487.351719] scsi host0: uas_eh_device_reset_handler start
[33487.512507] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[33487.545597] scsi host0: uas_eh_device_reset_handler success
[33487.632971] xhci_hcd 0000:01:00.0: WARNING: Host System Error
[33487.814049] sd 1:0:0:1: [sdd] tag#1 sense submit err -22 uas-tag 5 inflight: s-st a-in s-in a-cmd s-cmd
[33487.814061] sd 1:0:0:1: [sdd] tag#1 CDB: opcode=0x28 28 00 4e 47 be e0 00 04 00 00
[33492.682359] xhci_hcd 0000:01:00.0: xHCI host not responding to stop endpoint command.
[33492.682373] xhci_hcd 0000:01:00.0: USBSTS: HSE EINT
[33492.698391] xhci_hcd 0000:01:00.0: Host halt failed, -110
[33492.698402] xhci_hcd 0000:01:00.0: xHCI host controller not responding, assume dead
[33492.698459] xhci_hcd 0000:01:00.0: HC died; cleaning up
[33492.698601] usb 1-1: USB disconnect, device number 2
[33492.702193] usb 2-1: USB disconnect, device number 3
[33492.702717] sd 1:0:0:1: [sdd] tag#12 uas_zap_pending 0 uas-tag 1 inflight: CMD
[33492.702735] sd 1:0:0:1: [sdd] tag#12 CDB: opcode=0x28 28 00 24 c8 5b d0 00 04 00 00
[33492.702753] sd 1:0:0:1: [sdd] tag#11 uas_zap_pending 0 uas-tag 2 inflight: CMD
[33492.702767] sd 1:0:0:1: [sdd] tag#11 CDB: opcode=0x28 28 00 26 19 4a a8 00 04 00 00
[33492.702782] sd 1:0:0:1: [sdd] tag#10 uas_zap_pending 0 uas-tag 3 inflight: CMD
[33492.702795] sd 1:0:0:1: [sdd] tag#10 CDB: opcode=0x28 28 00 26 19 4e a8 00 00 08 00
[33492.702806] sd 1:0:0:1: [sdd] tag#12 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00 cmd_age=5s
[33492.702811] sd 1:0:0:1: [sdd] tag#13 uas_zap_pending 0 uas-tag 4 inflight: CMD
[33492.702819] sd 1:0:0:1: [sdd] tag#11 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00 cmd_age=5s
[33492.702823] sd 1:0:0:1: [sdd] tag#13 CDB: opcode=0x28 28 00 24 c8 5f d0 00 00 08 00
[33492.702841] sd 1:0:0:1: [sdd] tag#12 CDB: opcode=0x28 28 00 24 c8 5b d0 00 04 00 00
[33492.702844] sd 1:0:0:1: [sdd] tag#11 CDB: opcode=0x28 28 00 26 19 4a a8 00 04 00 00
[33492.702865] blk_update_request: I/O error, dev sdd, sector 639191720 op 0x0:(READ) flags 0x84700 phys_seg 128 prio class 0
[33492.702906] sd 1:0:0:1: [sdd] tag#10 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00 cmd_age=5s
[33492.702924] sd 1:0:0:1: [sdd] tag#10 CDB: opcode=0x28 28 00 26 19 4e a8 00 00 08 00
[33492.702944] blk_update_request: I/O error, dev sdd, sector 639192744 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[33492.703101] sd 1:0:0:1: [sdd] tag#13 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00 cmd_age=5s
[33492.703121] sd 1:0:0:1: [sdd] tag#13 CDB: opcode=0x28 28 00 24 c8 5f d0 00 00 08 00
[33492.703141] blk_update_request: I/O error, dev sdd, sector 617111504 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[33492.703241] sd 1:0:0:1: [sdd] tag#12 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00 cmd_age=4s
[33492.703260] sd 1:0:0:1: [sdd] tag#12 CDB: opcode=0x28 28 00 4e 47 be e0 00 04 00 00
[33492.703279] blk_update_request: I/O error, dev sdd, sector 1313324768 op 0x0:(READ) flags 0x80700 phys_seg 128 prio class 0
[33492.703363] sd 1:0:0:1: [sdd] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00 cmd_age=0s
[33492.703381] sd 1:0:0:1: [sdd] tag#0 CDB: opcode=0x28 28 00 01 d2 94 98 00 04 00 00
[33492.703400] blk_update_request: I/O error, dev sdd, sector 30577816 op 0x0:(READ) flags 0x84700 phys_seg 128 prio class 0
[33492.703433] sd 1:0:0:1: [sdd] tag#1 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00 cmd_age=0s
[33492.703452] sd 1:0:0:1: [sdd] tag#1 CDB: opcode=0x28 28 00 01 d2 98 98 00 00 08 00
[33492.703492] blk_update_request: I/O error, dev sdd, sector 30578840 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[33492.705801] blk_update_request: I/O error, dev sdc, sector 0 op 0x1:(WRITE) flags 0x800 phys_seg 0 prio class 0
[33492.751196] sd 1:0:0:0: [sdc] Synchronizing SCSI cache
[33492.871806] sd 1:0:0:1: [sdd] tag#7 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00 cmd_age=0s
[33492.871819] sd 1:0:0:1: [sdd] tag#7 CDB: opcode=0x28 28 00 26 19 4a a8 00 00 08 00
[33492.871830] blk_update_request: I/O error, dev sdd, sector 639191720 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[33492.891828] sd 1:0:0:1: [sdd] tag#6 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00 cmd_age=0s
[33492.891831] sd 1:0:0:1: [sdd] tag#8 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00 cmd_age=0s
[33492.891841] sd 1:0:0:1: [sdd] tag#8 CDB: opcode=0x28 28 00 24 c8 5b d0 00 00 08 00
[33492.891843] sd 1:0:0:1: [sdd] tag#6 CDB: opcode=0x28 28 00 4e 47 be e0 00 00 08 00
[33492.891851] blk_update_request: I/O error, dev sdd, sector 1313916992 op 0x0:(READ) flags 0x80700 phys_seg 128 prio class 0
[33492.891855] blk_update_request: I/O error, dev sdd, sector 1313324768 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[33493.342197] sd 1:0:0:0: [sdc] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=0x00
[33493.485262] sd 1:0:0:1: [sdd] Synchronizing SCSI cache
[33494.101810] sd 1:0:0:1: [sdd] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=0x00
[33494.142451] xhci_hcd 0000:01:00.0: WARN Can't disable streams for endpoint 0x82, streams are being disabled already
[33494.143770] usb 2-2: USB disconnect, device number 2
[33494.144041] sd 0:0:0:0: [sda] tag#6 uas_zap_pending 0 uas-tag 1 inflight: CMD
[33494.144049] sd 0:0:0:0: [sda] tag#6 CDB: opcode=0x2a 2a 08 00 00 08 08 00 00 01 00
[33494.144060] sd 0:0:0:1: [sdb] tag#7 uas_zap_pending 0 uas-tag 2 inflight: CMD
[33494.144066] sd 0:0:0:1: [sdb] tag#7 CDB: opcode=0x2a 2a 08 00 00 08 08 00 00 01 00
[33494.144079] md: super_written gets error=-5
[33494.144088] md/raid1:md0: Disk failure on sda1, disabling device.
               md/raid1:md0: Operation continuing on 1 devices.
[33494.152273] md: super_written gets error=-5
[33494.152343] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[33494.301920] md: super_written gets error=-5
[33494.321813] md: super_written gets error=-5
[33494.521854] md: super_written gets error=-5
[33494.721812] md: super_written gets error=-5
[33494.731839] sd 0:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=0x00
[33494.901813] md: super_written gets error=-5
[33494.902383] md: super_written gets error=-5
[33494.902787] md: super_written gets error=-5
[33494.902824] md: super_written gets error=-5
[33494.902859] md: super_written gets error=-5
[33494.903235] md: super_written gets error=-5
[33494.903270] md: super_written gets error=-5
[33494.903306] md: super_written gets error=-5
[33494.903925] md: super_written gets error=-5
[33494.903965] md: super_written gets error=-5
[33494.904001] md: super_written gets error=-5
[33494.904630] md: super_written gets error=-5
[33494.904646] md: super_written gets error=-5
[33494.904659] md: super_written gets error=-5
[33494.904754] md: super_written gets error=-5
[33494.904767] md: super_written gets error=-5
[33494.904781] md: super_written gets error=-5
[33494.904873] md: super_written gets error=-5
[33494.904887] md: super_written gets error=-5
[33494.904900] md: super_written gets error=-5
[33494.904993] md: super_written gets error=-5
[33494.905006] md: super_written gets error=-5
[33494.905020] md: super_written gets error=-5
[33494.906515] Aborting journal on device md0-8.
[33494.906773] md: super_written gets error=-5
[33494.906788] md: super_written gets error=-5
[33494.906802] md: super_written gets error=-5
[33494.906838] Buffer I/O error on dev md0, logical block 121667584, lost sync page write
[33494.906862] JBD2: Error -5 detected when updating journal superblock for md0-8.
[33494.908999] sd 0:0:0:1: [sdb] Synchronizing SCSI cache
[33494.949736] md: super_written gets error=-5
[33494.949840] md: super_written gets error=-5
[33494.949854] md: super_written gets error=-5
[33494.949868] md: super_written gets error=-5
[33494.949905] Buffer I/O error on dev md0, logical block 0, lost sync page write
[33494.949930] EXT4-fs (md0): I/O error while writing superblock
[33494.949939] EXT4-fs error (device md0): ext4_journal_check_start:83: Detected aborted journal
[33494.950987] EXT4-fs (md0): Remounting filesystem read-only
[33495.341814] md: super_written gets error=-5
[33495.341836] md: super_written gets error=-5
[33495.581876] sd 0:0:0:1: [sdb] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=0x00
[33495.652894] xhci_hcd 0000:01:00.0: WARN Can't disable streams for endpoint 0x82, streams are being disabled already
[33497.557409] Buffer I/O error on dev sdd1, logical block 121667584, lost sync page write
[33497.557421] JBD2: Error -5 detected when updating journal superblock for sdd1-8.
[33497.557427] Aborting journal on device sdd1-8.
[33497.557438] Buffer I/O error on dev sdd1, logical block 121667584, lost sync page write
[33497.557445] JBD2: Error -5 detected when updating journal superblock for sdd1-8.
[33497.559151] Buffer I/O error on dev sdc1, logical block 121667584, lost sync page write
[33497.559163] JBD2: Error -5 detected when updating journal superblock for sdc1-8.
[33497.559169] Aborting journal on device sdc1-8.
[33497.559179] Buffer I/O error on dev sdc1, logical block 121667584, lost sync page write
[33497.559186] JBD2: Error -5 detected when updating journal superblock for sdc1-8.
[33498.892664] md: super_written gets error=-5
[33498.892716] md: super_written gets error=-5
[33504.601945] md: super_written gets error=-5
[33505.672799] EXT4-fs error (device md0): ext4_get_inode_loc:4462: inode #34652254: block 138415141: comm smbd: unable to read itable block
[33505.675024] md: super_written gets error=-5
[33505.675069] md: super_written gets error=-5
[33505.675143] Buffer I/O error on dev md0, logical block 0, lost sync page write
[33505.675170] EXT4-fs (md0): I/O error while writing superblock
[33505.676671] EXT4-fs error (device md0): ext4_get_inode_loc:4462: inode #34652254: block 138415141: comm smbd: unable to read itable block
[33505.679030] Buffer I/O error on dev md0, logical block 0, lost sync page write
[33505.679057] EXT4-fs (md0): I/O error while writing superblock
[33505.679312] EXT4-fs error (device md0): ext4_get_inode_loc:4462: inode #34652254: block 138415141: comm smbd: unable to read itable block
[33505.681559] Buffer I/O error on dev md0, logical block 0, lost sync page write
[33505.681582] EXT4-fs (md0): I/O error while writing superblock
[33505.683278] EXT4-fs error (device md0): ext4_get_inode_loc:4462: inode #34606796: block 138412300: comm smbd: unable to read itable block
[33505.685667] Buffer I/O error on dev md0, logical block 0, lost sync page write
[33505.685694] EXT4-fs (md0): I/O error while writing superblock
[33505.686534] EXT4-fs error (device md0): ext4_get_inode_loc:4462: inode #34606796: block 138412300: comm smbd: unable to read itable block
[33505.688880] Buffer I/O error on dev md0, logical block 0, lost sync page write
[33505.688907] EXT4-fs (md0): I/O error while writing superblock
[33505.689077] EXT4-fs warning (device md0): htree_dirblock_to_tree:1003: inode #34652254: lblock 0: comm smbd: error -5 reading directory block
[33505.691073] EXT4-fs error (device md0): ext4_get_inode_loc:4462: inode #34652254: block 138415141: comm smbd: unable to read itable block
[33505.693251] Buffer I/O error on dev md0, logical block 0, lost sync page write
[33505.693276] EXT4-fs (md0): I/O error while writing superblock
[33505.702661] EXT4-fs error (device md0): ext4_get_inode_loc:4462: inode #34652254: block 138415141: comm smbd: unable to read itable block
[33505.704736] Buffer I/O error on dev md0, logical block 0, lost sync page write
[33505.704761] EXT4-fs (md0): I/O error while writing superblock
[33505.709625] EXT4-fs error (device md0): ext4_get_inode_loc:4462: inode #34652254: block 138415141: comm smbd: unable to read itable block
[33505.711721] Buffer I/O error on dev md0, logical block 0, lost sync page write
[33505.711747] EXT4-fs (md0): I/O error while writing superblock
[33506.031980] md: super_written gets error=-5
[33506.032020] md: super_written gets error=-5
[33507.627889] EXT4-fs error (device md0): ext4_get_inode_loc:4462: inode #34606796: block 138412300: comm smbd: unable to read itable block
[33507.629949] md: super_written gets error=-5
[33507.629996] md: super_written gets error=-5
[33507.630067] Buffer I/O error on dev md0, logical block 0, lost sync page write
[33507.630095] EXT4-fs (md0): I/O error while writing superblock
[33507.632657] EXT4-fs error (device md0): ext4_get_inode_loc:4462: inode #34606796: block 138412300: comm smbd: unable to read itable block
[33507.634639] Buffer I/O error on dev md0, logical block 0, lost sync page write
[33507.634665] EXT4-fs (md0): I/O error while writing superblock
[33507.635738] EXT4-fs warning (device md0): htree_dirblock_to_tree:1003: inode #34606796: lblock 0: comm smbd: error -5 reading directory block
[33507.921992] md: super_written gets error=-5
[33507.922033] md: super_written gets error=-5
[33508.471859] EXT4-fs warning (device md0): htree_dirblock_to_tree:1003: inode #34603009: lblock 0: comm smbd: error -5 reading directory block
My dmesg when UAS disabled:
[    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=DC:A6:32:76:2E:65 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  usb-storage.quirks=152d:0561:u console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p7 rootfstype=ext4 fsck.repair=yes rootwait usbhid.mousepoll=0
[    0.000102] bcm2835: system timer (irq = 25)
[    0.000765] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[    0.000787] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[    0.000809] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[    0.000828] Switching to timer-based delay loop, resolution 18ns
[    0.001093] Console: colour dummy device 80x30
[    0.001817] printk: console [tty1] enabled
[    0.001886] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[    0.001941] pid_max: default: 32768 minimum: 301
[    0.002128] LSM: Security Framework initializing
[    0.002334] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.002380] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.004030] Disabling memory control group subsystem
[    0.004170] CPU: Testing write buffer coherency: ok
[    0.004673] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.005924] Setting up static identity map for 0x200000 - 0x20003c
[    0.006144] rcu: Hierarchical SRCU implementation.
[    0.007116] smp: Bringing up secondary CPUs ...
[    0.008405] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.009817] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.011282] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.011440] smp: Brought up 1 node, 4 CPUs
[    0.011487] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[    0.011518] CPU: All CPU(s) started in HYP mode.
[    0.011545] CPU: Virtualization extensions available.
[    0.012416] devtmpfs: initialized
[    0.026725] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[    0.027009] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.027064] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.034487] pinctrl core: initialized pinctrl subsystem
[    0.035642] NET: Registered protocol family 16
[    0.039889] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.040707] audit: initializing netlink subsys (disabled)
[    0.041019] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
[    0.041593] thermal_sys: Registered thermal governor 'step_wise'
[    0.042352] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.042406] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.042823] Serial: AMBA PL011 UART driver
[    0.078540] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[    0.090945] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-02-25T12:10:40, variant start
[    0.100956] raspberrypi-firmware soc:firmware: Firmware hash is 564e5f9b852b23a330b1764bcf0b2d022a20afd0
[    0.146128] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[    0.150429] vgaarb: loaded
[    0.150915] SCSI subsystem initialized
[    0.151510] usbcore: registered new interface driver usbfs
[    0.151588] usbcore: registered new interface driver hub
[    0.151693] usbcore: registered new device driver usb
[    0.152081] usb_phy_generic phy: supply vcc not found, using dummy regulator
[    0.154084] clocksource: Switched to clocksource arch_sys_counter
[    1.154498] VFS: Disk quotas dquot_6.6.0
[    1.154628] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.154815] FS-Cache: Loaded
[    1.155058] CacheFiles: Loaded
[    1.156169] simple-framebuffer 3e3cf000.framebuffer: framebuffer at 0x3e3cf000, 0x7f8000 bytes, mapped to 0x(ptrval)
[    1.156214] simple-framebuffer 3e3cf000.framebuffer: format=a8r8g8b8, mode=1920x1080x32, linelength=7680
[    1.167361] Console: switching to colour frame buffer device 240x67
[    1.177505] simple-framebuffer 3e3cf000.framebuffer: fb0: simplefb registered!
[    1.188162] NET: Registered protocol family 2
[    1.189093] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    1.189322] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    1.189462] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    1.189607] TCP: Hash tables configured (established 8192 bind 8192)
[    1.189840] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.189947] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.190295] NET: Registered protocol family 1
[    1.191088] RPC: Registered named UNIX socket transport module.
[    1.191169] RPC: Registered udp transport module.
[    1.191232] RPC: Registered tcp transport module.
[    1.191296] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.191384] PCI: CLS 0 bytes, default 64
[    1.194571] Initialise system trusted keyrings
[    1.194895] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[    1.203696] zbud: loaded
[    1.205789] FS-Cache: Netfs 'nfs' registered for caching
[    1.206643] NFS: Registering the id_resolver key type
[    1.206740] Key type id_resolver registered
[    1.206802] Key type id_legacy registered
[    1.206986] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.208122] Key type asymmetric registered
[    1.208189] Asymmetric key parser 'x509' registered
[    1.208435] bounce: pool size: 64 pages
[    1.208524] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    1.208809] io scheduler mq-deadline registered
[    1.208873] io scheduler kyber registered
[    1.213605] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[    1.213718] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[    1.213886] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
[    1.214054] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
[    1.276189] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[    1.279553] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[    1.282472] pci_bus 0000:00: root bus resource [bus 00-ff]
[    1.285427] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[    1.288415] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[    1.291556] pci 0000:00:00.0: PME# supported from D0 D3hot
[    1.298019] PCI: bus0: Fast back to back transfers disabled
[    1.301265] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[    1.304324] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    1.307736] pci 0000:01:00.0: PME# supported from D0 D3cold
[    1.314137] PCI: bus1: Fast back to back transfers disabled
[    1.317023] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[    1.319868] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[    1.322741] pci 0000:00:00.0: PCI bridge to [bus 01]
[    1.325540] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
[    1.328731] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[    1.331773] pcieport 0000:00:00.0: PME: Signaling with IRQ 64
[    1.344510] iproc-rng200 fe104000.rng: hwrng registered
[    1.347670] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[    1.351492] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[    1.366965] brd: module loaded
[    1.382487] loop: module loaded
[    1.387246] Loading iSCSI transport class v2.0-870.
[    1.392547] libphy: Fixed MDIO Bus: probed
[    1.397280] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[    1.414111] libphy: bcmgenet MII bus: probed
[    1.504234] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[    1.508251] usbcore: registered new interface driver r8152
[    1.511069] usbcore: registered new interface driver lan78xx
[    1.513864] usbcore: registered new interface driver smsc95xx
[    1.518248] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
[    1.521110] xhci_hcd 0000:01:00.0: xHCI Host Controller
[    1.523808] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[    1.529880] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
[    1.533922] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    1.536651] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.539334] usb usb1: Product: xHCI Host Controller
[    1.541993] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
[    1.544622] usb usb1: SerialNumber: 0000:01:00.0
[    1.548015] hub 1-0:1.0: USB hub found
[    1.550735] hub 1-0:1.0: 1 port detected
[    1.554125] xhci_hcd 0000:01:00.0: xHCI Host Controller
[    1.556794] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[    1.559435] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[    1.562608] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    1.565354] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.568045] usb usb2: Product: xHCI Host Controller
[    1.570709] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
[    1.573397] usb usb2: SerialNumber: 0000:01:00.0
[    1.576814] hub 2-0:1.0: USB hub found
[    1.579588] hub 2-0:1.0: 4 ports detected
[    1.583994] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.587049] dwc_otg: FIQ enabled
[    1.587064] dwc_otg: NAK holdoff enabled
[    1.587079] dwc_otg: FIQ split-transaction FSM enabled
[    1.587097] Module dwc_common_port init
[    1.587569] usbcore: registered new interface driver uas
[    1.590334] usbcore: registered new interface driver usb-storage
[    1.593138] mousedev: PS/2 mouse device common for all mice
[    1.597583] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    1.603940] sdhci: Secure Digital Host Controller Interface driver
[    1.606657] sdhci: Copyright(c) Pierre Ossman
[    1.609963] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[    1.613220] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.620151] ledtrig-cpu: registered to indicate activity on CPUs
[    1.623196] hid: raw HID events driver (C) Jiri Kosina
[    1.626054] usbcore: registered new interface driver usbhid
[    1.628763] usbhid: USB HID core driver
[    1.637557] Initializing XFRM netlink socket
[    1.640319] NET: Registered protocol family 17
[    1.643155] Key type dns_resolver registered
[    1.646231] Registering SWP/SWPB emulation handler
[    1.649038] registered taskstats version 1
[    1.651624] Loading compiled-in X.509 certificates
[    1.655338] Key type ._fscrypt registered
[    1.657936] Key type .fscrypt registered
[    1.660464] Key type fscrypt-provisioning registered
[    1.674719] uart-pl011 fe201000.serial: there is not valid maps for state default
[    1.677667] uart-pl011 fe201000.serial: cts_event_workaround enabled
[    1.680329] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
[    1.689809] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[    1.693535] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[    1.696279] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[    1.729276] of_cfs_init
[    1.732213] of_cfs_init: OK
[    1.750598] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    1.754938] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.759154] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.765135] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    1.767699] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[    1.771048] Waiting for root device /dev/mmcblk0p7...
[    1.772465] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.822385] random: fast init done
[    1.866639] mmc1: new high speed SDIO card at address 0001
[    1.890972] mmc0: new ultra high speed DDR50 SDXC card at address aaaa
[    1.894516] mmcblk0: mmc0:aaaa SN64G 59.5 GiB
[    1.901069]  mmcblk0: p1 p2 < p5 p6 p7 >
[    1.914148] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[    1.933801] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[    1.936559] VFS: Mounted root (ext4 filesystem) readonly on device 179:7.
[    1.946654] devtmpfs: mounted
[    1.958338] Freeing unused kernel memory: 2048K
[    1.974412] Run /sbin/init as init process
[    1.976917]   with arguments:
[    1.976932]     /sbin/init
[    1.976945]   with environment:
[    1.976960]     HOME=/
[    1.976974]     TERM=linux
[    2.096765] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[    2.099475] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    2.102138] usb 1-1: Product: USB2.0 Hub
[    2.107300] hub 1-1:1.0: USB hub found
[    2.110173] hub 1-1:1.0: 4 ports detected
[    2.445373] systemd[1]: System time before build time, advancing clock.
[    2.560322] NET: Registered protocol family 10
[    2.564485] Segment Routing with IPv6
[    2.637460] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    2.644479] systemd[1]: Detected architecture arm.
[    2.739563] systemd[1]: Set hostname to <raspberry-pi-4>.
[    3.368085] systemd[1]: /lib/systemd/system/winbind.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/winbindd.pid → /run/samba/winbindd.pid; please update the unit file accordingly.
[    3.558638] systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
[    3.620576] systemd[1]: /lib/systemd/system/fail2ban.service:12: PIDFile= references path below legacy directory /var/run/, updating /var/run/fail2ban/fail2ban.pid → /run/fail2ban/fail2ban.pid; please update the unit file accordingly.
[    3.713790] random: systemd: uninitialized urandom read (16 bytes read)
[    3.739919] random: systemd: uninitialized urandom read (16 bytes read)
[    3.743866] systemd[1]: Listening on fsck to fsckd communication Socket.
[    3.752383] random: systemd: uninitialized urandom read (16 bytes read)
[    3.759064] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    3.768255] systemd[1]: Created slice system-getty.slice.
[    3.776504] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    3.935715] i2c /dev entries driver
[    4.581610] EXT4-fs (mmcblk0p7): re-mounted. Opts: (null)
[    4.740534] systemd-journald[128]: Received request to flush runtime journal from PID 1
[    5.028784] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    5.077937] fuse: init (API version 7.32)
[    5.512424] Driver for 1-wire Dallas network protocol.
[    5.516480] gpio-4 (onewire@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    5.529045] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[    5.529627] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[    5.530181] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[    5.530742] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[    5.617096] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[    5.619721] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[    5.619750] [vc_sm_connected_init]: start
[    5.627122] mc: Linux media interface: v0.10
[    5.635113] [vc_sm_connected_init]: installed successfully
[    5.666843] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[    5.675310] bcm2835_audio bcm2835_audio: card created with 4 channels
[    5.675349] videodev: Linux video capture interface: v2.00
[    5.678353] bcm2835_audio bcm2835_audio: card created with 4 channels
[    5.723260] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    5.723333] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    5.745609] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[    5.745710] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[    5.780810] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[    5.788016] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[    5.792734] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[    5.792802] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[    5.794767] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[    5.794907] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[    5.794933] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[    5.794956] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[    5.794994] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[    5.804332] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[    5.819719] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[    5.819805] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[    5.833391] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[    5.833442] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[    5.859763] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[    5.859812] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[    6.141432] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[    6.167054] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    6.178988] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[    6.179705] checking generic (3e3cf000 7f8000) vs hw (0 ffffffffffffffff)
[    6.179726] fb0: switching to vc4drmfb from simple
[    6.180825] Console: switching to colour dummy device 80x30
[    6.183044] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[    6.256939] vc4-drm gpu: [drm] HDMI-A-1: EDID is invalid:
[    6.256964]  [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.256981]  [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.256996]  [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.257012]  [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.257028]  [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.257043]  [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.257059]  [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.257074]  [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.291561] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    6.371327] brcmfmac: F1 signature read @0x18000000=0x15264345
[    6.394790] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    6.395603] usbcore: registered new interface driver brcmfmac
[    6.419015] Console: switching to colour frame buffer device 240x67
[    6.444268] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
[    6.689899] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    6.700585] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
[    7.030741] rtc-pcf8563 1-0051: registered as rtc0
[    9.226610] random: crng init done
[    9.226628] random: 7 urandom warning(s) missed due to ratelimiting
[    9.456571] 8021q: 802.1Q VLAN Support v1.8
[    9.485107] uart-pl011 fe201000.serial: no DMA platform data
[    9.994177] Adding 2097148k swap on /var/swap.  Priority:-2 extents:5 across:3309564k SSFS
[   10.352429] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[   10.353701] bcmgenet fd580000.ethernet eth0: Link is Down
[   14.474457] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   14.474504] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   16.490763] Bluetooth: Core ver 2.22
[   16.490833] NET: Registered protocol family 31
[   16.490840] Bluetooth: HCI device and connection manager initialized
[   16.492497] Bluetooth: HCI socket layer initialized
[   16.492512] Bluetooth: L2CAP socket layer initialized
[   16.492538] Bluetooth: SCO socket layer initialized
[   16.518600] Bluetooth: HCI UART driver ver 2.3
[   16.518612] Bluetooth: HCI UART protocol H4 registered
[   16.518698] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   16.523185] Bluetooth: HCI UART protocol Broadcom registered
[   16.784543] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   16.784553] Bluetooth: BNEP filters: protocol multicast
[   16.784571] Bluetooth: BNEP socket layer initialized
[   16.854216] Bluetooth: RFCOMM TTY layer initialized
[   16.854234] Bluetooth: RFCOMM socket layer initialized
[   16.854257] Bluetooth: RFCOMM ver 1.11
[   18.944403] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[   18.975596] usb 2-2: New USB device found, idVendor=152d, idProduct=0561, bcdDevice=81.36
[   18.975620] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[   18.975630] usb 2-2: Product: JMS56x Series
[   18.975637] usb 2-2: Manufacturer: JMicron
[   18.975644] usb 2-2: SerialNumber: DD564198838B4
[   18.981115] usb 2-2: UAS is ignored for this device, using usb-storage instead
[   18.981172] usb 2-2: UAS is ignored for this device, using usb-storage instead
[   18.981181] usb-storage 2-2:1.0: USB Mass Storage device detected
[   18.981496] usb-storage 2-2:1.0: Quirks match for vid 152d pid 0561: 800000
[   18.981584] scsi host0: usb-storage 2-2:1.0
[   19.994768] scsi 0:0:0:0: Direct-Access     ST1000LM 049-2GH172       8136 PQ: 0 ANSI: 6
[   19.995432] scsi 0:0:0:1: Direct-Access     ST1000LM 049-2GH172       8136 PQ: 0 ANSI: 6
[   19.999825] sd 0:0:0:1: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[   20.000465] sd 0:0:0:1: [sdb] Write Protect is off
[   20.000475] sd 0:0:0:1: [sdb] Mode Sense: 47 00 10 08
[   20.001131] sd 0:0:0:1: [sdb] No Caching mode page found
[   20.001142] sd 0:0:0:1: [sdb] Assuming drive cache: write through
[   20.001487] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[   20.002104] sd 0:0:0:0: [sda] Write Protect is off
[   20.002115] sd 0:0:0:0: [sda] Mode Sense: 47 00 10 08
[   20.002751] sd 0:0:0:0: [sda] No Caching mode page found
[   20.002761] sd 0:0:0:0: [sda] Assuming drive cache: write through
[   20.011583] sd 0:0:0:0: Attached scsi generic sg0 type 0
[   20.012287] sd 0:0:0:1: Attached scsi generic sg1 type 0
[   20.126294]  sdb: sdb1
[   20.220639]  sda: sda1
[   20.225769] sd 0:0:0:1: [sdb] Attached SCSI disk
[   20.231481] sd 0:0:0:0: [sda] Attached SCSI disk
[   20.754952] md/raid1:md0: not clean -- starting background reconstruction
[   20.754962] md/raid1:md0: active with 2 out of 2 mirrors
[   20.783179] md0: detected capacity change from 0 to 1000068546560
[   22.057064] md: resync of RAID array md0
[   22.238477] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
[   45.184542] usb 2-1: new SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[   45.216366] usb 2-1: New USB device found, idVendor=152d, idProduct=0561, bcdDevice=81.36
[   45.216384] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[   45.216398] usb 2-1: Product: JMS56x Series
[   45.216411] usb 2-1: Manufacturer: JMicron
[   45.216424] usb 2-1: SerialNumber: DD564198838B3
[   45.235247] usb 2-1: UAS is ignored for this device, using usb-storage instead
[   45.235352] usb 2-1: UAS is ignored for this device, using usb-storage instead
[   45.235368] usb-storage 2-1:1.0: USB Mass Storage device detected
[   45.236370] usb-storage 2-1:1.0: Quirks match for vid 152d pid 0561: 800000
[   45.237142] scsi host1: usb-storage 2-1:1.0
[   46.314647] scsi 1:0:0:0: Direct-Access     HGST HTS 721010A9E630     8136 PQ: 0 ANSI: 6
[   46.315404] sd 1:0:0:0: [sdc] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[   46.316404] sd 1:0:0:0: [sdc] Write Protect is off
[   46.316413] sd 1:0:0:0: [sdc] Mode Sense: 47 00 10 08
[   46.317375] sd 1:0:0:0: [sdc] No Caching mode page found
[   46.317384] sd 1:0:0:0: [sdc] Assuming drive cache: write through
[   46.318838] sd 1:0:0:0: Attached scsi generic sg2 type 0
[   46.319401] scsi 1:0:0:1: Direct-Access     HGST HTS 721010A9E630     8136 PQ: 0 ANSI: 6
[   46.319958] sd 1:0:0:1: Attached scsi generic sg3 type 0
[   46.323666] sd 1:0:0:1: [sdd] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[   46.324662] sd 1:0:0:1: [sdd] Write Protect is off
[   46.324672] sd 1:0:0:1: [sdd] Mode Sense: 47 00 10 08
[   46.325335] sd 1:0:0:1: [sdd] No Caching mode page found
[   46.325344] sd 1:0:0:1: [sdd] Assuming drive cache: write through
[   46.640339]  sdc: sdc1
[   46.654594]  sdd: sdd1
[   46.661519] sd 1:0:0:0: [sdc] Attached SCSI disk
[   46.662911] sd 1:0:0:1: [sdd] Attached SCSI disk
[   49.180410] EXT4-fs (sdc1): mounted filesystem with ordered data mode. Opts: (null)
[   50.550590] EXT4-fs (sdd1): mounted filesystem with ordered data mode. Opts: (null)
[   51.234866] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[   51.454867] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[   52.334763] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[   52.515190] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[   53.974850] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[   58.234809] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[   58.664800] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[   58.855286] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[ 1859.821148] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 1864.221317] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 1864.611424] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[ 1864.791302] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[ 3659.799250] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 3660.029284] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 3660.389625] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[ 3660.629537] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[ 5460.769583] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 5460.979594] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 5461.340076] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[ 5461.539615] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[ 7260.808980] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 7260.999162] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 7261.349404] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[ 7261.529417] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[ 9060.767490] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 9060.977328] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 9061.337756] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[ 9061.517778] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[ 9193.058651] md: md0: resync done.
[12660.792390] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[12660.972357] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[14460.262815] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[14460.452809] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[16260.702686] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[16260.922677] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[16260.954169] sd 1:0:0:1: [sdd] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00 cmd_age=0s
[16260.954182] sd 1:0:0:1: [sdd] tag#0 CDB: opcode=0x28 28 00 4d da dc 48 00 02 00 00
[16260.954193] blk_update_request: I/O error, dev sdd, sector 1306188872 op 0x0:(READ) flags 0x80700 phys_seg 5 prio class 0
[19860.430533] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[19860.610452] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[23460.162289] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[23460.352462] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[25260.562957] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[25260.742819] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[27060.572952] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[27060.752963] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[27061.253058] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[27061.432948] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[28860.583413] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[28860.763191] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[30660.983278] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[30661.163248] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[34260.342495] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[34260.522371] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[36060.352011] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[36060.531964] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[37861.231252] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[37861.411205] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[39660.660858] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[39660.840870] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[43260.989389] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[43261.179390] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[45061.008647] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[45061.188599] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[45061.688702] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[45061.868620] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[48660.838203] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[48661.028019] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[50460.207616] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[50460.397615] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[50460.887678] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[50461.157626] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[52261.347236] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[52261.527216] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[54060.727212] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[54060.927177] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[55860.906759] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[55861.086705] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[55861.696584] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[55861.886720] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[57660.945573] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[57661.125488] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[57662.225380] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[57665.535439] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[59460.913824] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[59465.313873] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[59465.703934] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[59465.893803] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[61260.842390] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[61261.022362] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[61261.892263] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[61262.082599] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[63060.971566] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[63061.151542] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[63061.521506] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[63061.701563] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[64860.630047] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[64860.810237] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[64861.200189] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[64861.380035] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[66660.389899] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[66660.579763] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[66661.140195] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[66661.329875] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[68460.450839] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[68464.440882] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[68464.830903] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[68465.011006] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[70261.011819] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[70265.701749] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[70269.822035] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[70270.011849] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[72061.200191] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[72061.379993] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[72062.100002] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[72062.280047] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[73860.464376] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[73860.644293] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[73861.404427] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[73861.604506] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[73861.635968] sd 1:0:0:0: [sdc] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00 cmd_age=0s
[73861.636002] sd 1:0:0:0: [sdc] tag#0 CDB: opcode=0x28 28 00 49 6a cb a0 00 02 00 00
[73861.636026] blk_update_request: I/O error, dev sdc, sector 1231735712 op 0x0:(READ) flags 0x84700 phys_seg 32 prio class 0
[75660.615354] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[75660.805308] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[75661.265398] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[75661.445377] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[77460.573063] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[77464.903076] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[77465.313049] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[77465.345252] sd 1:0:0:1: [sdd] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00 cmd_age=0s
[77465.345282] sd 1:0:0:1: [sdd] tag#0 CDB: opcode=0x28 28 00 6a 5d e8 40 00 02 00 00
[77465.345296] blk_update_request: I/O error, dev sdd, sector 1784539200 op 0x0:(READ) flags 0x80700 phys_seg 26 prio class 0
[77468.783289] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[79260.773511] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[79260.953520] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[81061.406146] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[81061.596160] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[82860.511546] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[82860.691539] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[82861.881784] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[82862.071615] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[84661.121766] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[84661.311991] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[84662.091808] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[84662.271824] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[86461.144110] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[86461.333711] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[90060.601969] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[90060.781868] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[90061.281875] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[90061.491761] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[90061.523262] sd 1:0:0:1: [sdd] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00 cmd_age=0s
[90061.523275] sd 1:0:0:1: [sdd] tag#0 CDB: opcode=0x28 28 00 4d a3 b0 a0 00 02 00 00
[90061.523286] blk_update_request: I/O error, dev sdd, sector 1302573216 op 0x0:(READ) flags 0x80700 phys_seg 64 prio class 0
[91861.931740] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[91862.111828] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[93660.991424] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[93661.171827] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[93661.661385] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[93661.841378] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[98635.656983] usb 2-2: USB disconnect, device number 2
[98640.532386] md/raid1:md0: Disk failure on sdb1, disabling device.
[98640.534395] md: super_written gets error=-5
[98640.534417] md: super_written gets error=-5
[98640.576865] md: super_written gets error=-5
[98640.576883] md: super_written gets error=-5
[98640.637225] md: super_written gets error=-5
[98640.637253] md: super_written gets error=-5
[98641.857112] usb 2-2: new SuperSpeed Gen 1 USB device number 4 using xhci_hcd
[98641.888345] usb 2-2: New USB device found, idVendor=152d, idProduct=0561, bcdDevice=81.36
[98641.888361] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[98641.888373] usb 2-2: Product: JMS56x Series
[98641.888385] usb 2-2: Manufacturer: JMicron
[98641.888397] usb 2-2: SerialNumber: DD564198838B4
[98641.891243] usb 2-2: UAS is ignored for this device, using usb-storage instead
[98641.891335] usb 2-2: UAS is ignored for this device, using usb-storage instead
[98641.891350] usb-storage 2-2:1.0: USB Mass Storage device detected
[98641.893107] usb-storage 2-2:1.0: Quirks match for vid 152d pid 0561: 800000
[98641.893227] scsi host2: usb-storage 2-2:1.0
[98642.897282] scsi 2:0:0:0: Direct-Access     ST1000LM 049-2GH172       8136 PQ: 0 ANSI: 6
[98642.897617] sd 2:0:0:0: Attached scsi generic sg0 type 0
[98642.897916] sd 2:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[98642.898147] scsi 2:0:0:1: Direct-Access     ST1000LM 049-2GH172       8136 PQ: 0 ANSI: 6
[98642.898443] scsi 2:0:0:1: Attached scsi generic sg1 type 0
[98642.898771] sd 2:0:0:0: [sdb] Write Protect is off
[98642.898780] sd 2:0:0:0: [sdb] Mode Sense: 47 00 10 08
[98642.899472] sd 2:0:0:0: [sdb] No Caching mode page found
[98642.899481] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[98642.902230] sd 2:0:0:1: [sde] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[98642.902867] sd 2:0:0:1: [sde] Write Protect is off
[98642.902875] sd 2:0:0:1: [sde] Mode Sense: 47 00 10 08
[98642.903524] sd 2:0:0:1: [sde] No Caching mode page found
[98642.903533] sd 2:0:0:1: [sde] Assuming drive cache: write through
[98643.028291]  sdb: sdb1
[98643.119615]  sde: sde1
[98643.121377] sd 2:0:0:0: [sdb] Attached SCSI disk
[98643.124943] sd 2:0:0:1: [sde] Attached SCSI disk
[98643.307459] usb 2-2: reset SuperSpeed Gen 1 USB device number 4 using xhci_hcd
[98643.338983] sd 2:0:0:0: [sdb] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00 cmd_age=0s
[98643.339009] sd 2:0:0:0: [sdb] tag#0 CDB: opcode=0x28 28 00 74 70 6d 00 00 00 08 00
[98643.339023] blk_update_request: I/O error, dev sdb, sector 1953524992 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[98644.047507] usb 2-2: reset SuperSpeed Gen 1 USB device number 4 using xhci_hcd
[98646.477502] usb 2-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[98654.887593] usb 2-2: reset SuperSpeed Gen 1 USB device number 4 using xhci_hcd
[98655.067649] usb 2-2: reset SuperSpeed Gen 1 USB device number 4 using xhci_hcd
[98708.318291] usb 2-2: reset SuperSpeed Gen 1 USB device number 4 using xhci_hcd
[99044.952718] md: super_written gets error=-5
[99044.952744] md: super_written gets error=-5
[99044.952787] md: super_written gets error=-5
[99044.954636] md: super_written gets error=-5
[99044.954653] md: super_written gets error=-5
[99044.954667] md: super_written gets error=-5
[99044.954708] EXT4-fs warning (device md0): ext4_end_bio:349: I/O error 10 writing to inode 17957439 starting block 244156704)
[99044.955116] Buffer I/O error on device md0, logical block 244156704
[99044.955132] Buffer I/O error on device md0, logical block 244156705
[99044.955143] Buffer I/O error on device md0, logical block 244156706
[99044.955153] Buffer I/O error on device md0, logical block 244156707
[99044.955162] Buffer I/O error on device md0, logical block 244156708
[99044.955172] Buffer I/O error on device md0, logical block 244156709
[99044.955182] Buffer I/O error on device md0, logical block 244156710
[99044.955191] Buffer I/O error on device md0, logical block 244156711
[99044.955201] Buffer I/O error on device md0, logical block 244156712
[99044.955211] Buffer I/O error on device md0, logical block 244156713
[99044.990645] md: super_written gets error=-5
[99044.990664] md: super_written gets error=-5
[99044.990678] md: super_written gets error=-5
[99044.990719] EXT4-fs warning (device md0): ext4_end_bio:349: I/O error 10 writing to inode 17957439 starting block 244156768)
[99045.431824] md: super_written gets error=-5
[99045.431845] md: super_written gets error=-5
[99050.502077] md: super_written gets error=-5
[99050.502101] md: super_written gets error=-5
[99050.502191] md: super_written gets error=-5
[99050.502314] md: super_written gets error=-5
[99050.502328] md: super_written gets error=-5
[99050.502341] md: super_written gets error=-5
[99050.502431] md: super_written gets error=-5
[99050.502445] md: super_written gets error=-5
[99050.502458] md: super_written gets error=-5
[99050.502547] md: super_written gets error=-5
[99050.502560] md: super_written gets error=-5
[99050.502574] md: super_written gets error=-5
[99050.502664] md: super_written gets error=-5
[99050.502678] md: super_written gets error=-5
[99050.502691] md: super_written gets error=-5
[99050.502781] md: super_written gets error=-5
[99050.502795] md: super_written gets error=-5
[99050.502808] md: super_written gets error=-5
[99050.502885] Aborting journal on device md0-8.
[99050.502997] md: super_written gets error=-5
[99050.503012] md: super_written gets error=-5
[99050.503025] md: super_written gets error=-5
[99050.503057] Buffer I/O error on dev md0, logical block 121667584, lost sync page write
[99050.503085] JBD2: Error -5 detected when updating journal superblock for md0-8.
[99050.881892] md: super_written gets error=-5
[99050.881912] md: super_written gets error=-5
[99592.596267] EXT4-fs error (device md0): __ext4_get_inode_loc_noinmem:4446: inode #17956944: block 71827492: comm smbd: unable to read itable block
[99592.597309] md: super_written gets error=-5
[99592.597331] md: super_written gets error=-5
[99592.598029] md: super_written gets error=-5
[99592.598123] md: super_written gets error=-5
[99592.598137] md: super_written gets error=-5
[99592.598150] md: super_written gets error=-5
[99592.598186] Buffer I/O error on dev md0, logical block 0, lost sync page write
[99592.598907] EXT4-fs (md0): I/O error while writing superblock
[99592.601925] EXT4-fs error (device md0): __ext4_get_inode_loc_noinmem:4446: inode #17956944: block 71827492: comm smbd: unable to read itable block
[99592.602927] Buffer I/O error on dev md0, logical block 0, lost sync page write
[99592.602940] EXT4-fs (md0): I/O error while writing superblock
[99592.603433] EXT4-fs error (device md0): __ext4_get_inode_loc_noinmem:4446: inode #17956941: block 71827492: comm smbd: unable to read itable block
[99592.604389] Buffer I/O error on dev md0, logical block 0, lost sync page write
[99592.604400] EXT4-fs (md0): I/O error while writing superblock
[99592.604760] EXT4-fs error (device md0): __ext4_get_inode_loc_noinmem:4446: inode #17956941: block 71827492: comm smbd: unable to read itable block
[99592.605721] Buffer I/O error on dev md0, logical block 0, lost sync page write
[99592.605733] EXT4-fs (md0): I/O error while writing superblock
[99592.606137] EXT4-fs error (device md0): __ext4_get_inode_loc_noinmem:4446: inode #17956945: block 71827493: comm smbd: unable to read itable block
[99592.607175] Buffer I/O error on dev md0, logical block 0, lost sync page write
[99592.607189] EXT4-fs (md0): I/O error while writing superblock
[99592.607945] EXT4-fs error (device md0): __ext4_get_inode_loc_noinmem:4446: inode #17956945: block 71827493: comm smbd: unable to read itable block
[99592.609142] Buffer I/O error on dev md0, logical block 0, lost sync page write
[99592.609156] EXT4-fs (md0): I/O error while writing superblock
[99592.612571] EXT4-fs error (device md0): __ext4_get_inode_loc_noinmem:4446: inode #17956944: block 71827492: comm smbd: unable to read itable block
[99592.613545] Buffer I/O error on dev md0, logical block 0, lost sync page write
[99592.613558] EXT4-fs (md0): I/O error while writing superblock
[99592.613944] EXT4-fs error (device md0): __ext4_get_inode_loc_noinmem:4446: inode #17956944: block 71827492: comm smbd: unable to read itable block
[99592.614929] Buffer I/O error on dev md0, logical block 0, lost sync page write
[99592.614941] EXT4-fs (md0): I/O error while writing superblock
[99592.615530] EXT4-fs error (device md0): __ext4_get_inode_loc_noinmem:4446: inode #17956944: block 71827492: comm smbd: unable to read itable block
[99592.616449] Buffer I/O error on dev md0, logical block 0, lost sync page write
[99592.616460] EXT4-fs (md0): I/O error while writing superblock
[99592.616848] EXT4-fs error (device md0): __ext4_get_inode_loc_noinmem:4446: inode #17956944: block 71827492: comm smbd: unable to read itable block
[99592.617747] Buffer I/O error on dev md0, logical block 0, lost sync page write
[99592.617758] EXT4-fs (md0): I/O error while writing superblock
[99592.640961] EXT4-fs warning (device md0): htree_dirblock_to_tree:1003: inode #34737490: lblock 0: comm smbd: error -5 reading directory block
[99592.641004] EXT4-fs error (device md0): ext4_journal_check_start:83: Detected aborted journal
[99592.650483] EXT4-fs warning (device md0): htree_dirblock_to_tree:1003: inode #40378646: lblock 0: comm smbd: error -5 reading directory block
[99592.658626] EXT4-fs warning (device md0): htree_dirblock_to_tree:1003: inode #34736591: lblock 0: comm smbd: error -5 reading directory block
[99592.898331] md: super_written gets error=-5
[99592.898371] md: super_written gets error=-5
[99593.329442] md: super_written gets error=-5
[99593.329464] md: super_written gets error=-5
[99593.758622] md: super_written gets error=-5
[99593.758644] md: super_written gets error=-5
[99711.628608] EXT4-fs error: 15 callbacks suppressed
[99711.628615] EXT4-fs error (device md0): __ext4_get_inode_loc_noinmem:4446: inode #17956944: block 71827492: comm smbd: unable to read itable block
[99711.629639] md: super_written gets error=-5
[99711.629660] md: super_written gets error=-5
[99711.629703] buffer_io_error: 16 callbacks suppressed
[99711.629707] Buffer I/O error on dev md0, logical block 0, lost sync page write
[99711.629720] EXT4-fs: 17 callbacks suppressed
[99711.629724] EXT4-fs (md0): I/O error while writing superblock
[99711.632791] EXT4-fs error (device md0): __ext4_get_inode_loc_noinmem:4446: inode #17956944: block 71827492: comm smbd: unable to read itable block
[99711.633752] Buffer I/O error on dev md0, logical block 0, lost sync page write
[99711.633765] EXT4-fs (md0): I/O error while writing superblock
[99711.634261] EXT4-fs error (device md0): __ext4_get_inode_loc_noinmem:4446: inode #17956941: block 71827492: comm smbd: unable to read itable block
[99711.635176] Buffer I/O error on dev md0, logical block 0, lost sync page write
[99711.635187] EXT4-fs (md0): I/O error while writing superblock
[99711.635547] EXT4-fs error (device md0): __ext4_get_inode_loc_noinmem:4446: inode #17956941: block 71827492: comm smbd: unable to read itable block
[99711.636451] Buffer I/O error on dev md0, logical block 0, lost sync page write
[99711.636462] EXT4-fs (md0): I/O error while writing superblock
[99711.636823] EXT4-fs error (device md0): __ext4_get_inode_loc_noinmem:4446: inode #17956945: block 71827493: comm smbd: unable to read itable block
[99711.637712] Buffer I/O error on dev md0, logical block 0, lost sync page write
[99711.637723] EXT4-fs (md0): I/O error while writing superblock
[99711.638080] EXT4-fs error (device md0): __ext4_get_inode_loc_noinmem:4446: inode #17956945: block 71827493: comm smbd: unable to read itable block
[99711.638984] Buffer I/O error on dev md0, logical block 0, lost sync page write
[99711.638995] EXT4-fs (md0): I/O error while writing superblock
[99711.644487] EXT4-fs error (device md0): __ext4_get_inode_loc_noinmem:4446: inode #17956944: block 71827492: comm smbd: unable to read itable block
[99711.645405] Buffer I/O error on dev md0, logical block 0, lost sync page write
[99711.645418] EXT4-fs (md0): I/O error while writing superblock
[99711.645900] EXT4-fs error (device md0): __ext4_get_inode_loc_noinmem:4446: inode #17956944: block 71827492: comm smbd: unable to read itable block
[99711.646856] Buffer I/O error on dev md0, logical block 0, lost sync page write
[99711.646868] EXT4-fs (md0): I/O error while writing superblock
[99711.647273] EXT4-fs error (device md0): __ext4_get_inode_loc_noinmem:4446: inode #17956944: block 71827492: comm smbd: unable to read itable block
[99711.648188] Buffer I/O error on dev md0, logical block 0, lost sync page write
[99711.648200] EXT4-fs (md0): I/O error while writing superblock
[99711.648791] EXT4-fs error (device md0): __ext4_get_inode_loc_noinmem:4446: inode #17956944: block 71827492: comm smbd: unable to read itable block
[99711.649901] Buffer I/O error on dev md0, logical block 0, lost sync page write
[99711.649912] EXT4-fs (md0): I/O error while writing superblock
[99711.683056] EXT4-fs warning (device md0): htree_dirblock_to_tree:1003: inode #34737490: lblock 0: comm smbd: error -5 reading directory block
[99711.695565] EXT4-fs warning (device md0): htree_dirblock_to_tree:1003: inode #40378646: lblock 0: comm smbd: error -5 reading directory block
[99711.707561] EXT4-fs warning (device md0): htree_dirblock_to_tree:1003: inode #34736591: lblock 0: comm smbd: error -5 reading directory block
[99711.979658] md: super_written gets error=-5
[99711.979679] md: super_written gets error=-5
[99712.217440] md: super_written gets error=-5
[99712.217463] md: super_written gets error=-5
[99712.619670] md: super_written gets error=-5
[99712.619692] md: super_written gets error=-5
@setq do you have any idea what could be the problem?
I think i come to the end of the road with this.
I constently get a drive failing, some times it boots up with all four other times just 3 or 2. IT will run for days fine with all 4 drives (once it boots with them all) and then randomly disconnect one or more.
A product like this has to be stable and sadly this is not the experince i have had with it. I am not running raid and tried it on two seperate Raspberry Pi 4’s (4 gig versions)
Sadly i doubt there is any chance of a refund or replacment.
its seems that in the very beginning the raid initialization fails (could also be an issue with the disks itself (e.g. unclean state))
just try with another SD with fresh (and minimal) OS and fresh SATA HAT installation without raid (should not take more than an hour) and if possible other disks - I personal have no issues with DietPi on RPI 4b
[20.754952] md/raid1:md0: not clean – starting background reconstruction
[20.754962] md/raid1:md0: active with 2 out of 2 mirrors
That message was because of previously the HDDs disconnected when I tried to access to my data.
I use Raspbian, I will try a fresh install. The HDDs are okay if the SMART doesn’t lie:
it is 18 sec after rapsi poweron where raspi start to initiate HDDs with its very first contact
2 seconds later at 20 secs it detects that raid issue, user driven interaction will be (enabled) far later
New dmesg (it’s still running, but who know how long) with UAS enabled:
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.10.17-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1403 SMP Mon Feb 22 11:33:35 GMT 2021
[    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
[    0.000000]   Normal   empty
[    0.000000]   HighMem  [mem 0x0000000030000000-0x00000000fbffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x000000002fffffff]
[    0.000000]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
[    0.000000] On node 0 totalpages: 966656
[    0.000000]   DMA zone: 2304 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 196608 pages, LIFO batch:63
[    0.000000]   HighMem zone: 770048 pages, LIFO batch:63
[    0.000000] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
[    0.000000] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 964352
[    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=DC:A6:32:76:2E:65 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p7 rootfstype=ext4 fsck.repair=yes rootwait usbhid.mousepoll=0
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x0000000017cc0000-0x000000001bcc0000] (64MB)
[    0.000000] Memory: 3472776K/3866624K available (10240K kernel code, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 131704K reserved, 262144K cma-reserved, 3080192K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 33942 entries in 67 pages
[    0.000000] ftrace: allocated 67 pages with 3 groups
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
[    0.000008] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[    0.000036] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[    0.000107] bcm2835: system timer (irq = 25)
[    0.000772] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[    0.000794] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[    0.000817] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[    0.000836] Switching to timer-based delay loop, resolution 18ns
[    0.001101] Console: colour dummy device 80x30
[    0.001823] printk: console [tty1] enabled
[    0.001892] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[    0.001947] pid_max: default: 32768 minimum: 301
[    0.002134] LSM: Security Framework initializing
[    0.002340] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.002386] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.004007] Disabling memory control group subsystem
[    0.004151] CPU: Testing write buffer coherency: ok
[    0.004648] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.005901] Setting up static identity map for 0x200000 - 0x20003c
[    0.006119] rcu: Hierarchical SRCU implementation.
[    0.007089] smp: Bringing up secondary CPUs ...
[    0.008376] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.009800] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.011268] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.011427] smp: Brought up 1 node, 4 CPUs
[    0.011474] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[    0.011504] CPU: All CPU(s) started in HYP mode.
[    0.011531] CPU: Virtualization extensions available.
[    0.012393] devtmpfs: initialized
[    0.026658] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[    0.026944] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.027000] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.034415] pinctrl core: initialized pinctrl subsystem
[    0.035567] NET: Registered protocol family 16
[    0.039754] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.040571] audit: initializing netlink subsys (disabled)
[    0.040887] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
[    0.041460] thermal_sys: Registered thermal governor 'step_wise'
[    0.042199] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.042253] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.042686] Serial: AMBA PL011 UART driver
[    0.078360] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[    0.090939] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-02-25T12:10:40, variant start
[    0.100949] raspberrypi-firmware soc:firmware: Firmware hash is 564e5f9b852b23a330b1764bcf0b2d022a20afd0
[    0.146111] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[    0.150405] vgaarb: loaded
[    0.150894] SCSI subsystem initialized
[    0.151475] usbcore: registered new interface driver usbfs
[    0.151552] usbcore: registered new interface driver hub
[    0.151659] usbcore: registered new device driver usb
[    0.152044] usb_phy_generic phy: supply vcc not found, using dummy regulator
[    0.154001] clocksource: Switched to clocksource arch_sys_counter
[    1.156361] VFS: Disk quotas dquot_6.6.0
[    1.156501] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.156707] FS-Cache: Loaded
[    1.156916] CacheFiles: Loaded
[    1.158041] simple-framebuffer 3e3cf000.framebuffer: framebuffer at 0x3e3cf000, 0x7f8000 bytes, mapped to 0x(ptrval)
[    1.158086] simple-framebuffer 3e3cf000.framebuffer: format=a8r8g8b8, mode=1920x1080x32, linelength=7680
[    1.169251] Console: switching to colour frame buffer device 240x67
[    1.179430] simple-framebuffer 3e3cf000.framebuffer: fb0: simplefb registered!
[    1.188271] NET: Registered protocol family 2
[    1.189272] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    1.189505] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    1.189659] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    1.189804] TCP: Hash tables configured (established 8192 bind 8192)
[    1.190037] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.190141] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.190475] NET: Registered protocol family 1
[    1.191301] RPC: Registered named UNIX socket transport module.
[    1.191380] RPC: Registered udp transport module.
[    1.191444] RPC: Registered tcp transport module.
[    1.191508] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.191596] PCI: CLS 0 bytes, default 64
[    1.194812] Initialise system trusted keyrings
[    1.195131] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[    1.203807] zbud: loaded
[    1.205913] FS-Cache: Netfs 'nfs' registered for caching
[    1.206775] NFS: Registering the id_resolver key type
[    1.206893] Key type id_resolver registered
[    1.206956] Key type id_legacy registered
[    1.207153] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.208275] Key type asymmetric registered
[    1.208341] Asymmetric key parser 'x509' registered
[    1.208585] bounce: pool size: 64 pages
[    1.208687] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    1.208981] io scheduler mq-deadline registered
[    1.209048] io scheduler kyber registered
[    1.213786] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[    1.213901] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[    1.214205] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
[    1.214395] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
[    1.276110] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[    1.279447] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[    1.282351] pci_bus 0000:00: root bus resource [bus 00-ff]
[    1.285327] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[    1.288283] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[    1.291443] pci 0000:00:00.0: PME# supported from D0 D3hot
[    1.297933] PCI: bus0: Fast back to back transfers disabled
[    1.301169] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[    1.304179] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    1.307527] pci 0000:01:00.0: PME# supported from D0 D3cold
[    1.313918] PCI: bus1: Fast back to back transfers disabled
[    1.316817] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[    1.319637] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[    1.322500] pci 0000:00:00.0: PCI bridge to [bus 01]
[    1.325340] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
[    1.328574] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[    1.331616] pcieport 0000:00:00.0: PME: Signaling with IRQ 64
[    1.346431] iproc-rng200 fe104000.rng: hwrng registered
[    1.349607] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[    1.353337] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[    1.368742] brd: module loaded
[    1.384216] loop: module loaded
[    1.388786] Loading iSCSI transport class v2.0-870.
[    1.394263] libphy: Fixed MDIO Bus: probed
[    1.398918] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[    1.414067] libphy: bcmgenet MII bus: probed
[    1.504151] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[    1.508189] usbcore: registered new interface driver r8152
[    1.511038] usbcore: registered new interface driver lan78xx
[    1.513858] usbcore: registered new interface driver smsc95xx
[    1.518311] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
[    1.521134] xhci_hcd 0000:01:00.0: xHCI Host Controller
[    1.523833] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[    1.529912] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
[    1.533938] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    1.536625] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.539305] usb usb1: Product: xHCI Host Controller
[    1.541955] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
[    1.544612] usb usb1: SerialNumber: 0000:01:00.0
[    1.547970] hub 1-0:1.0: USB hub found
[    1.550714] hub 1-0:1.0: 1 port detected
[    1.554048] xhci_hcd 0000:01:00.0: xHCI Host Controller
[    1.556725] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[    1.559413] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[    1.562553] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    1.565289] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.567996] usb usb2: Product: xHCI Host Controller
[    1.570633] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
[    1.573321] usb usb2: SerialNumber: 0000:01:00.0
[    1.576773] hub 2-0:1.0: USB hub found
[    1.579504] hub 2-0:1.0: 4 ports detected
[    1.583956] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.586946] dwc_otg: FIQ enabled
[    1.586961] dwc_otg: NAK holdoff enabled
[    1.586976] dwc_otg: FIQ split-transaction FSM enabled
[    1.586995] Module dwc_common_port init
[    1.587468] usbcore: registered new interface driver uas
[    1.590242] usbcore: registered new interface driver usb-storage
[    1.593100] mousedev: PS/2 mouse device common for all mice
[    1.597493] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    1.603785] sdhci: Secure Digital Host Controller Interface driver
[    1.606515] sdhci: Copyright(c) Pierre Ossman
[    1.609888] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[    1.613174] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.618831] ledtrig-cpu: registered to indicate activity on CPUs
[    1.621829] hid: raw HID events driver (C) Jiri Kosina
[    1.624733] usbcore: registered new interface driver usbhid
[    1.627406] usbhid: USB HID core driver
[    1.636185] Initializing XFRM netlink socket
[    1.638929] NET: Registered protocol family 17
[    1.641817] Key type dns_resolver registered
[    1.644878] Registering SWP/SWPB emulation handler
[    1.647644] registered taskstats version 1
[    1.650238] Loading compiled-in X.509 certificates
[    1.653731] Key type ._fscrypt registered
[    1.656620] Key type .fscrypt registered
[    1.659182] Key type fscrypt-provisioning registered
[    1.673301] uart-pl011 fe201000.serial: there is not valid maps for state default
[    1.676325] uart-pl011 fe201000.serial: cts_event_workaround enabled
[    1.678972] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
[    1.689316] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[    1.693062] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[    1.695819] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[    1.734890] of_cfs_init
[    1.737751] of_cfs_init: OK
[    1.745489] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    1.749744] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.754081] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.759629] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    1.763813] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.764070] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[    1.769882] Waiting for root device /dev/mmcblk0p7...
[    1.808113] random: fast init done
[    1.837569] mmc1: new high speed SDIO card at address 0001
[    1.875582] mmc0: new ultra high speed DDR50 SDXC card at address aaaa
[    1.879094] mmcblk0: mmc0:aaaa SN64G 59.5 GiB
[    1.885949]  mmcblk0: p1 p2 < p5 p6 p7 >
[    1.914078] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[    1.923333] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[    1.926111] VFS: Mounted root (ext4 filesystem) readonly on device 179:7.
[    1.936154] devtmpfs: mounted
[    1.947784] Freeing unused kernel memory: 2048K
[    1.964333] Run /sbin/init as init process
[    1.966852]   with arguments:
[    1.966867]     /sbin/init
[    1.966881]   with environment:
[    1.966895]     HOME=/
[    1.966909]     TERM=linux
[    2.096734] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[    2.099394] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    2.102046] usb 1-1: Product: USB2.0 Hub
[    2.106904] hub 1-1:1.0: USB hub found
[    2.109868] hub 1-1:1.0: 4 ports detected
[    2.430903] systemd[1]: System time before build time, advancing clock.
[    2.546699] NET: Registered protocol family 10
[    2.550766] Segment Routing with IPv6
[    2.626873] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    2.634071] systemd[1]: Detected architecture arm.
[    2.719643] systemd[1]: Set hostname to <raspberry-pi-4>.
[    3.407508] systemd[1]: /lib/systemd/system/winbind.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/winbindd.pid → /run/samba/winbindd.pid; please update the unit file accordingly.
[    3.598818] systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
[    3.630466] systemd[1]: /lib/systemd/system/krb5-kdc.service:5: PIDFile= references path below legacy directory /var/run/, updating /var/run/krb5-kdc.pid → /run/krb5-kdc.pid; please update the unit file accordingly.
[    3.666294] systemd[1]: /lib/systemd/system/fail2ban.service:12: PIDFile= references path below legacy directory /var/run/, updating /var/run/fail2ban/fail2ban.pid → /run/fail2ban/fail2ban.pid; please update the unit file accordingly.
[    3.758094] random: systemd: uninitialized urandom read (16 bytes read)
[    3.784489] random: systemd: uninitialized urandom read (16 bytes read)
[    3.788378] systemd[1]: Listening on udev Kernel Socket.
[    3.796607] random: systemd: uninitialized urandom read (16 bytes read)
[    3.800650] systemd[1]: Listening on Journal Socket (/dev/log).
[    3.808819] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    3.984993] i2c /dev entries driver
[    4.599390] EXT4-fs (mmcblk0p7): re-mounted. Opts: (null)
[    4.749943] systemd-journald[112]: Received request to flush runtime journal from PID 1
[    5.026435] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    5.030467] fuse: init (API version 7.32)
[    5.541513] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[    5.543184] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[    5.543817] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[    5.562002] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[    5.572844] Driver for 1-wire Dallas network protocol.
[    5.613321] gpio-4 (onewire@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    5.618915] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[    5.622762] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[    5.622788] [vc_sm_connected_init]: start
[    5.641016] mc: Linux media interface: v0.10
[    5.642076] [vc_sm_connected_init]: installed successfully
[    5.665451] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[    5.682938] videodev: Linux video capture interface: v2.00
[    5.693562] bcm2835_audio bcm2835_audio: card created with 4 channels
[    5.720068] bcm2835_audio bcm2835_audio: card created with 4 channels
[    5.754120] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    5.759023] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    5.764235] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[    5.766106] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[    5.773814] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[    5.815105] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[    5.815160] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[    5.815700] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[    5.816393] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[    5.816897] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[    5.817321] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[    5.817350] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[    5.817375] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[    5.817398] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[    5.817421] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[    5.817637] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[    5.837378] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[    5.837427] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[    5.854894] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[    5.854950] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[    6.152981] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    6.259801] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[    6.306540] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    6.393548] brcmfmac: F1 signature read @0x18000000=0x15264345
[    6.405347] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    6.407424] usbcore: registered new interface driver brcmfmac
[    6.437373] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[    6.437411] checking generic (3e3cf000 7f8000) vs hw (0 ffffffffffffffff)
[    6.437431] fb0: switching to vc4drmfb from simple
[    6.438164] Console: switching to colour dummy device 80x30
[    6.440099] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[    6.446753] vc4-drm gpu: [drm] HDMI-A-1: EDID is invalid:
[    6.446777]  [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.446792]  [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.446807]  [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.446822]  [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.446837]  [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.446858]  [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.446873]  [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.446888]  [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.594773] Console: switching to colour frame buffer device 240x67
[    6.623122] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
[    6.678163] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    6.690586] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
[    7.075256] rtc-pcf8563 1-0051: registered as rtc0
[    9.344281] uart-pl011 fe201000.serial: no DMA platform data
[    9.712636] 8021q: 802.1Q VLAN Support v1.8
[    9.794404] random: crng init done
[    9.794426] random: 7 urandom warning(s) missed due to ratelimiting
[   10.394184] Adding 2097148k swap on /var/swap.  Priority:-2 extents:5 across:3309564k SSFS
[   10.710923] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[   10.711340] bcmgenet fd580000.ethernet eth0: Link is Down
[   14.874493] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   14.874535] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   16.642555] Bluetooth: Core ver 2.22
[   16.642615] NET: Registered protocol family 31
[   16.642622] Bluetooth: HCI device and connection manager initialized
[   16.642637] Bluetooth: HCI socket layer initialized
[   16.642647] Bluetooth: L2CAP socket layer initialized
[   16.642663] Bluetooth: SCO socket layer initialized
[   16.666585] Bluetooth: HCI UART driver ver 2.3
[   16.666597] Bluetooth: HCI UART protocol H4 registered
[   16.666656] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   16.666818] Bluetooth: HCI UART protocol Broadcom registered
[   16.864650] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[   16.895755] usb 2-2: New USB device found, idVendor=152d, idProduct=1561, bcdDevice=81.36
[   16.895773] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[   16.895781] usb 2-2: Product: External
[   16.895792] usb 2-2: Manufacturer: JMicron
[   16.895802] usb 2-2: SerialNumber: DD564198838B4
[   16.955794] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   16.955803] Bluetooth: BNEP filters: protocol multicast
[   16.955817] Bluetooth: BNEP socket layer initialized
[   16.970640] scsi host0: uas
[   16.971749] scsi 0:0:0:0: Direct-Access     JMicron  Tech             8136 PQ: 0 ANSI: 6
[   16.974725] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[   16.975016] sd 0:0:0:0: [sda] Write Protect is off
[   16.975026] sd 0:0:0:0: [sda] Mode Sense: 67 00 10 08
[   16.975547] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, supports DPO and FUA
[   16.976520] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
[   16.977194] scsi 0:0:0:1: Direct-Access     JMicron  Tech             8136 PQ: 0 ANSI: 6
[   16.979898] sd 0:0:0:1: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[   16.980184] sd 0:0:0:1: [sdb] Write Protect is off
[   16.980194] sd 0:0:0:1: [sdb] Mode Sense: 67 00 10 08
[   16.980708] sd 0:0:0:1: [sdb] Write cache: enabled, read cache: enabled, supports DPO and FUA
[   16.981503] sd 0:0:0:1: [sdb] Optimal transfer size 33553920 bytes
[   17.044783]  sda: sda1
[   17.069412]  sdb: sdb1
[   17.072666] sd 0:0:0:0: [sda] Attached SCSI disk
[   17.072697] Bluetooth: RFCOMM TTY layer initialized
[   17.072742] Bluetooth: RFCOMM socket layer initialized
[   17.072766] Bluetooth: RFCOMM ver 1.11
[   17.073092] sd 0:0:0:1: [sdb] Attached SCSI disk
[   17.143573] sd 0:0:0:0: Attached scsi generic sg0 type 0
[   17.144117] sd 0:0:0:1: Attached scsi generic sg1 type 0
[   18.241392] md/raid1:md0: active with 2 out of 2 mirrors
[   18.250825] md0: detected capacity change from 0 to 1000068546560
[   22.354149] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
[   41.894493] usb 2-1: new SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[   41.925672] usb 2-1: New USB device found, idVendor=152d, idProduct=1561, bcdDevice=81.36
[   41.925686] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[   41.925698] usb 2-1: Product: External
[   41.925709] usb 2-1: Manufacturer: JMicron
[   41.925719] usb 2-1: SerialNumber: DD564198838B3
[   41.969855] scsi host1: uas
[   41.971138] scsi 1:0:0:0: Direct-Access     JMicron  Tech             8136 PQ: 0 ANSI: 6
[   41.972903] sd 1:0:0:0: Attached scsi generic sg2 type 0
[   41.974127] scsi 1:0:0:1: Direct-Access     JMicron  Tech             8136 PQ: 0 ANSI: 6
[   41.974587] sd 1:0:0:0: [sdc] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[   41.974857] sd 1:0:0:0: [sdc] Write Protect is off
[   41.974870] sd 1:0:0:0: [sdc] Mode Sense: 67 00 10 08
[   41.975709] sd 1:0:0:0: [sdc] Write cache: enabled, read cache: enabled, supports DPO and FUA
[   41.976510] sd 1:0:0:0: [sdc] Optimal transfer size 33553920 bytes
[   41.977255] sd 1:0:0:1: Attached scsi generic sg3 type 0
[   41.977661] sd 1:0:0:1: [sdd] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[   41.977998] sd 1:0:0:1: [sdd] Write Protect is off
[   41.978012] sd 1:0:0:1: [sdd] Mode Sense: 67 00 10 08
[   41.978532] sd 1:0:0:1: [sdd] Write cache: enabled, read cache: enabled, supports DPO and FUA
[   41.979379] sd 1:0:0:1: [sdd] Optimal transfer size 33553920 bytes
[   42.066966]  sdd: sdd1
[   42.411064]  sdc: sdc1
[   42.415693] sd 1:0:0:1: [sdd] Attached SCSI disk
[   42.416314] sd 1:0:0:0: [sdc] Attached SCSI disk
[   44.914902] EXT4-fs (sdc1): mounted filesystem with ordered data mode. Opts: (null)
[   45.268219] EXT4-fs (sdd1): mounted filesystem with ordered data mode. Opts: (null)
[  457.963804] xhci_hcd 0000:01:00.0: WARN Successful completion on short TX
[  458.314087] xhci_hcd 0000:01:00.0: ERROR Transfer event TRB DMA ptr not part of current TD ep_index 6 comp_code 1
[  458.314103] xhci_hcd 0000:01:00.0: Looking for event-dma 000000041eea56b0 trb-start 000000041eea56c0 trb-end 000000041eea56c0 seg-start 000000041eea5000 seg-end 000000041eea5ff0
[  464.994634] sd 0:0:0:0: [sda] tag#4 uas_eh_abort_handler 0 uas-tag 1 inflight: IN
[  464.994651] sd 0:0:0:0: [sda] tag#4 CDB: opcode=0xa1 a1 08 0e d1 01 01 4f c2 a0 b0 00 00
[  465.054663] scsi host0: uas_eh_device_reset_handler start
[  465.215393] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[  465.248457] scsi host0: uas_eh_device_reset_handler success
[  465.693608] xhci_hcd 0000:01:00.0: WARN Successful completion on short TX
[  465.723623] xhci_hcd 0000:01:00.0: ERROR Transfer event TRB DMA ptr not part of current TD ep_index 6 comp_code 1
[  465.723633] xhci_hcd 0000:01:00.0: Looking for event-dma 000000041eeba050 trb-start 000000041eeba060 trb-end 000000041eeba060 seg-start 000000041eeba000 seg-end 000000041eebaff0
[  472.734637] sd 0:0:0:1: [sdb] tag#4 uas_eh_abort_handler 0 uas-tag 2 inflight: IN
[  472.734652] sd 0:0:0:1: [sdb] tag#4 CDB: opcode=0xa1 a1 08 0e d1 01 01 4f c2 a0 b0 00 00
[  472.794674] scsi host0: uas_eh_device_reset_handler start
[  472.946404] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[  472.979945] scsi host0: uas_eh_device_reset_handler success
There isn’t any raid problem.
form 16 to 17 the first controller accessing 2 HDDs
with result at 18 in a raid
20 secs(!) later from 41 to 42 the second controller accessing the other 2 HDDs
with result at 44 in two filesystems
is that the intended result?
Yes, everything started correctly!
But yes, the time difference (20 secs) a little bit strange.
googling on that there are more indication pointing on OS issue than device issue
if possible just give DietPi a chance to know if it happens there as well
I did a fresh installl (Raspbian), set up everything from zero (took me a day) but it seems to be fine.
No warnings or errors.
I am going to run it for a few days and after if everything is alright, we can close this problem.
Thank you for your advice!
I did this, raspberry pi OS light, installed the script for the SATA hat, installed OMV and that was it.
All booted up fine then about 48 hours one of the HD disapeared again
Based on following error
I would go in disabling UAS like I did on my DeskPi Pro Raspberry Pi 4 enclosure. Some of USB 3.0 or USB to SATA has faulty UAS implementation.
Hint: If you want to trigger this error create btrfs filesystem on those drives you have. Then fill it with data and do scrub. It should help you to test solutions you applied.
As I wrote before: I tried to disable UAS but nothing changed.
After 1 day I got the following:
[92635.478866] usb 2-1: USB disconnect, device number 3
[92635.479431] xhci_hcd 0000:01:00.0: WARN Set TR Deq Ptr cmd failed due to incorrect slot or ep state.
[92635.479858] sd 1:0:0:0: [sdc] tag#0 uas_zap_pending 0 uas-tag 1 inflight: CMD
[92635.479867] sd 1:0:0:0: [sdc] tag#0 CDB: opcode=0x28 28 00 62 b4 1b f0 00 04 00 00
[92635.479877] sd 1:0:0:0: [sdc] tag#1 uas_zap_pending 0 uas-tag 2 inflight: CMD
[92635.479883] sd 1:0:0:0: [sdc] tag#1 CDB: opcode=0x28 28 00 62 b4 1f f0 00 00 08 00
[92635.479899] sd 1:0:0:0: [sdc] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00 cmd_age=0s
[92635.479920] sd 1:0:0:0: [sdc] tag#0 CDB: opcode=0x28 28 00 62 b4 1b f0 00 04 00 00
[92635.479934] blk_update_request: I/O error, dev sdc, sector 1655970800 op 0x0:(READ) flags 0x84700 phys_seg 128 prio class 0
[92635.480192] sd 1:0:0:0: [sdc] tag#1 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00 cmd_age=0s
[92635.480205] sd 1:0:0:0: [sdc] tag#1 CDB: opcode=0x28 28 00 62 b4 1f f0 00 00 08 00
[92635.480216] blk_update_request: I/O error, dev sdc, sector 1655971824 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[92635.480300] blk_update_request: I/O error, dev sdc, sector 1655970800 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[92635.481283] blk_update_request: I/O error, dev sdc, sector 0 op 0x1:(WRITE) flags 0x800 phys_seg 0 prio class 0
[92635.496570] sd 1:0:0:0: [sdc] Synchronizing SCSI cache
[92636.118936] sd 1:0:0:0: [sdc] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=0x00
[92636.202183] blk_update_request: I/O error, dev sdd, sector 0 op 0x1:(WRITE) flags 0x800 phys_seg 0 prio class 0
[92636.221170] sd 1:0:0:1: [sdd] Synchronizing SCSI cache
[92636.848944] sd 1:0:0:1: [sdd] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=0x00
[92637.321455] usb 2-1: new SuperSpeed Gen 1 USB device number 4 using xhci_hcd
[92637.400566] usb 2-1: New USB device found, idVendor=152d, idProduct=1561, bcdDevice=81.36
[92637.400578] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[92637.400586] usb 2-1: Product: JMS56x Series
[92637.400593] usb 2-1: Manufacturer: JMicron
[92637.400601] usb 2-1: SerialNumber: DD564198838B3
[92637.496911] scsi host2: uas
[92637.498690] scsi 2:0:0:0: Direct-Access     HGST HTS 721010A9E630     8136 PQ: 0 ANSI: 6
[92637.519332] sd 2:0:0:0: Attached scsi generic sg2 type 0
[92637.532405] scsi 2:0:0:1: Direct-Access     HGST HTS 721010A9E630     8136 PQ: 0 ANSI: 6
[92637.533360] sd 2:0:0:0: [sde] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[92637.533619] sd 2:0:0:0: [sde] Write Protect is off
[92637.533628] sd 2:0:0:0: [sde] Mode Sense: 67 00 10 08
[92637.534292] sd 2:0:0:0: [sde] Write cache: enabled, read cache: enabled, supports DPO and FUA
[92637.534317] sd 2:0:0:1: Attached scsi generic sg3 type 0
[92637.535168] sd 2:0:0:0: [sde] Optimal transfer size 33553920 bytes
[92637.535871] sd 2:0:0:1: [sdf] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[92637.536130] sd 2:0:0:1: [sdf] Write Protect is off
[92637.536139] sd 2:0:0:1: [sdf] Mode Sense: 67 00 10 08
[92637.538083] sd 2:0:0:1: [sdf] Write cache: enabled, read cache: enabled, supports DPO and FUA
[92637.540260] sd 2:0:0:1: [sdf] Optimal transfer size 33553920 bytes
[92637.899909]  sde: sde1
[92637.934485]  sdf: sdf1
[92637.937775] sd 2:0:0:1: [sdf] Attached SCSI disk
[92637.938389] sd 2:0:0:0: [sde] Attached SCSI disk
[92640.452105] Buffer I/O error on dev sdc1, logical block 121667584, lost sync page wr        ite
[92640.452116] JBD2: Error -5 detected when updating journal superblock for sdc1-8.
[92640.452123] Aborting journal on device sdc1-8.
[92640.452134] Buffer I/O error on dev sdc1, logical block 121667584, lost sync page wr        ite
[92640.452220] JBD2: Error -5 detected when updating journal superblock for sdc1-8.
[92640.454003] Buffer I/O error on dev sdd1, logical block 121667584, lost sync page wr        ite
[92640.454016] JBD2: Error -5 detected when updating journal superblock for sdd1-8.
[92640.454023] Aborting journal on device sdd1-8.
[92640.454034] Buffer I/O error on dev sdd1, logical block 121667584, lost sync page wr        ite
[92640.454043] JBD2: Error -5 detected when updating journal superblock for sdd1-8.
Maybe now I try to disable UAS again.
Another idea. Can you plug it to normal pc and recreate filesystem? Try USB 2.0 if it fails again.
After the HDDs disconnect, I rebooted the system and the uptime is 2 days, 20:16 without any error, so I think the Raspbian reinstall solved my problem (UAS is enabled).
