For the first issue that sounds like a power supply problem. Please make sure your USB hub (if it has one) and Zero’s power supply is sufficient.
For the second issue make sure you installed the required driver and pressed the USB boot button firmly when plugging the cable. You can attach a serial cable to confirm it is in the right mode.
