i have 3 questions
- is there another way to supply the board with 12 V besides the USB-C port ?
- how much current does the onboard 5V converter supply for USB / NVME / GPIO ?
- what is the pin assignment of the PoE connector ?
Best regards,
René
i have 3 questions
Best regards,
René
• is there another way to supply the board with 12 V besides the USB-C port ?
we have no other 12V connector to supply the board
• how much current does the onboard 5V converter supply for USB / NVME / GPIO ?
the usb max current 1A and voltage 5V
the nvme max current 3A and voltage 3.3V
the gpio’s current depends on your software ,there are 4,8,12ma you can choose
• what is the pin assignment of the PoE connector ?
the POE has a two group ,pin 1,2 and pin3,4
Thanks for the Information.
Which of the Groups is Gound and which the 5 Volt ?
Yes.
There are no other connector. But if you dont mind soldering and hacking your board. There is a “hack”.
great Solution … thanks a lot.
suggestion for improvement:
Best regards & Thanks a lot,
René
