I’m currently in the process of upstreaming the Q900 and while porting the device tree there was this one comment:
that would be needed to addressed.
@Stephen @strongtz @Nasca can any of you give more info about it?
I also could not find which DP to HDMI IC was used. Can someone comment that one too?
This should not be required as the vreg_l4c node of lemans-evk.dts in the upstream tree uses regulator-allow-set-load.
Hi Q900 uses the bridge ic, RA620, which is supported. linux/drivers/gpu/drm/bridge/simple-bridge.c at master · torvalds/linux · GitHub
