Updated FFMpeg with mpp
Hello Everyone,
After months of work, i think this is the best this decoder can do with this kernel and panfork.
In above branch you can find the latest updated decoder where you can 8k@60fps HDR for hevc and h264, 8k@30fps for vp8/9 and 4k@60for AV1.
to test it with mpv run with
mpv --hwdec=rkmpp pathtofile
note: you might need to use latest mpv from git, otherwise you might get false positives like
Mapped surface with format 'nv12' has unexpected number of planes. (0 layers and 0 planes, but expected 2 planes), please use latest from git
to use it with kodi, run kodi with:
kodi.bin --windowing=gbm --audio-backend=alsa
make sure you select
settings->player->videos->render method
Allow using DRM PRIME Decoder=enable
Allow Hardware Acceleation with DRM PRIME=enable
Prime Render Method=EGL
and below is a demo showcase of 8k@60fps HDR file being played with mpv
https://streamable.com/e/kk2zm4
Known Issues:
Encoder is not working in this branch
When libyuv conversion is active there is 1 pixel of green line at top
Error handling is not the best, it might segfault when unexpected things happen.
NV20 is not yet supported but can easily be adopted.
Any test and feedback is wellcome.
