Update uboot-trust-spi img to u-boot2019.10
Hi all,
Just noticed the u-boot has release the 2019.10 stable, could you update the spi img to the latest version?
Thanks
Hello mko_io,
FYI
You need only idbloader.img on sector 63
and
u-boot.itb on sector 16384
on the micro sd card.
do this
download and extract (or git pull)
make rock-pi-4-rk3399_defconfig
make all
With Rock Pi 4B version 1.4 it is working.
With this way you do not need the trust img anymore
Best Regards
Dondon
That’s awesome, without trust img makes the boot process event simpler, I’ll give it try later, thanks
FYI - I can boot into grub. Loading the kernel. initrd works
For the mainline u-boot, you don’t need the uboot-trust-spi.img, you just use the u-boot SPL for the SPI, write to the SPI flash under u-boot with sf command. With mainline, everything is “familiar” :slight_smile:
@jack Can you provide a little more information on how to do this? I have a Rock Pi 4 v1.4 and have a working uboot I would like to use but I am unclear how to use the sf command to write to SPI. I currently have nothing on my SPI.
@PhoenixMage do you have mainline u-boot or the radxa u-boot?
@jack I have a working mainline u-boot
